Question about Cell Phones
How to wire a headset to stereo phone jack.
I need to wire a headset with mike to a stereo phone jack.  So we have a common ground, a wire for the mic, and a wire for the mono speaker.  Which one gets soldered to the shaft, which one gets soldered to the ring, and which one gets soldered to the tip? Is there a standard for this or does it vary by manufacturer?
  • Paul Hyde
    Paul Hyde Nov 01, 2007
    Still waiting . . .
  • f4fariha2000 May 01, 2009
    wiring diagram for headset and stereo jack
Http://en.wikipedia.org/wiki/TRS_connector#Tip.2Fring.2Fsleeve_terminology
the table shows u what u need i think
Posted on Apr 08, 2009
I believe the ground goes on the shaft/sleeve, the mic on the ring and the speaker on the tip.
Posted on Aug 21, 2009
How to connect the mono headset
If you're trying to convert a STEREO output to feed MONO headphones, the best is to use a resistive splitter network as shown.
There are adapters out there that simply short the two L/R signals from the stereo, but you run a risk of overloading the output stages of your amp.
The resistive network places a current-limiting resistor on each stereo output in series, so eliminating shorts and overload.
If using a mic-enabled headset, the jack has 4 connectors, the back one nearest the plastic case being for MIC.
Mono: Tip, Sleeve.
Stereo: Tip, Ring, Sleeve.
Incl Mic: Tip, Ring, Sleeve, Mic.
Tip is Left, usually Green.
Ring is Right, usually Red.
Sleeve is common GND, usually bare copper or black.
Mic can vary according to manufacturer. Seen striped colors, white, red, purple.
These thin shellac-coated wires are sometimes difficult to solder, so here are some tips:
Using a combination of fine emery paper, craft-knife and flame, try to burn/scrape/clean about 5 mm from each wire.
Copper should be shiny without shellac color showing at end.
To burn the shellac off, best hold the wire 5 mm or so back with pliers or fingers. The shellac varnish may ignite the whole wire if you don't block it first.
Diagrams and drawings should help to clarify the text.
872c3844-2630-46b9-86e4-869f044bad22.pngstereo plug connection -amwsxm2bpytpyryuvmyoeb4d-4-3.png
Oct 12, 2017 | Radio Communications
I have 2 2.5mm jack ends each with different colored wires. Red and green on one and black white and orange on the other. I am hooking up a mic/ headphones. What wires connect to what
honestly the pinout for the adapter depend on what you are planning to plug it into. as manufacturers use standard plugs in different ways, usually the shoulder / body point is the shield / common connection, the others depend on what you're connecting to.
for instance I made a similar connector myself for use on a xbox 360 controller (to connect a gaming headset mic to the headset socket), I believe in that instance the mic's connection was between common and tip.
Jan 28, 2016 | Lands Phones
Mic only producing static noise
look at the plug on the end, two black insulator circles means its stereo and needs to be plugging into a stereo jack, 1 black circle means mono and you can get a mono to stereo adapter at the dollar store
Apr 05, 2014 | SteelSeries Siberia V2 Headset Frost Blue...
I am hooking up a Behringer xenyx 1002B Mic/Line Mixer to my Toshiba Satellite c885-S5194 laptop to broadcast online via meridix. I'm using Audio technica BPHS1 Headset Microphones with XLS plugs and 1/4...
IF your Laptop has a stereo LINE 1/8" INPUT jack, you can take the Stereo ( Left & Right ) LINE outputs on your mixer and feed into this jack on your PC. You will need a 1/4" dual plug for the mixer end to a single 1/8" stereo plug on the PC end. I suspect the problem you are having is either related to your PC only have a MIC input jack or you have something set wrong in your PC's sound config. file. More information is needed to properly solve the problem.
Oct 18, 2013 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Why do I only hear static
Hi Cathy.. it sounds like you might be connected to the wrong jacks instead of the output that the headphones need.
Most high quality stereo headphones have a single 1/4" stereo plug that would readily plug into a 1/4" jack on the front of the stereo labeled "PHONES" or HEADPHONES".
Many lower quality "computer headphones" or headsets have two 1/8" plugs. One is often black or red and is for an included microphone that may be a boom type (shown below) connected to one of the speakers or an "in-line" type built into the cord itself. The headphone speakers in the headset get their signal from the other plug - which is usually green; but could be any color really. There should be 3 metal parts on the stereo headphone plug. The tip, the middle ring and the bottom ring. Many times the mic is mono (not stereo) and only has only a tip and a bottom ring on the plug. You can see stereo headphone and microphone plugs he picture below:
Computer Headphones or "Headset" with mic and phone plugs.
Your Yamaha stereo will probably NOT have 1/8" jacks to directly plug the headphone into. You can buy an adapter that you would plug your headphones into and then plug the adapter into the 1/4" jack on the stereo. One is pictured below:
Front and rear views of a "1/4" to 1/8" Stereo Adapter Plug" The front plugs into the stereo and the the smaller 1/8" headphones plug into the rear.
I hope this helps & good luck!
Jan 21, 2012 | Sennheiser Audio Players & Recorders
I have 2 plugs on my Logitech ClearChat Stereo Headset Headset I have a table top computer where do I pug them
The headphone plug goes into the green jack on the computer. The mic plug goes into the red jack on the computer. The headphone plug with have three segments on the jack, the mic plug will have two, and they'll both be marked. If you're computer doesn't have color jacks, the mic will go into the one with a picture of a mic, the headphones will go into the one with a picture of a headphone or speaker.
Jul 07, 2011 | Logitech ClearChat Stereo Headset Headset
I've just purchased a Genius HS-04SU set - plugged it in to the jacks - nothing, zip zero.. I have tried fixing it from the control panel - no options offered other than realtek input and...
First, excuse my answer/question, but you are plugging mike and phones into correct ports?
I once cursed my headphones & software only to realize that I had foolishly plugged phones into the MIC jack!! :rolleyes:
I haven't seen the jack-plugs on your model, but are they separate, stereo 3-way jack for 'phones and mono 2-way jack for mike?
I'm thinking of a 4-way all-in-one phones/mic jack not matching with stereo 3-way output socket of sound-card.
Working from tip at end of jack-plug,
Mic: Tip=mono signal out, Sleeve=GND
Stereo Phones: Tip=Left in, Ring=Right in, Sleeve=Common GND
Multi: Tip=Left, Ring1=Right, Ring2=Com GND, Sleeve=Mic sig.
May 25, 2017 | Genius HS-04SU Headset
I have a cobra 148gtl with 5 pin side plug for mic.Im trying to wire a superstar dm 1000 echo mic to it,red,yellow,blue,white,& unsheilded wires dont know were they go.???????
ALLways start with ground. Find ground on radio pin with ohm meter. EVERY thing operates off ground. Once you find ground on radio....solder your ground wire on mike cord to corresponding # on mike jack. Once you have ground on proper pin then all else is elementary......use ohm meter to see which wires are TX and RX on mike.....last wire is audio wire.
Jan 20, 2010 | Cobra Radio Communications
Headset Microphone doesn't work
Plugged in? Is it a stereo plug? does your computer allow speaker and mic on the same wire? Does the outlet say Mic or Headset of Both? Had it worked in the past.
Some computers have a place for a mic - some for headset - some might have both. On a desktop, I would expect to find separate connections. Laptop, Id have to look.
A 'stereo' plug will have a tip, ring and barrel connection.
A 'mono' plug will have a tip and barrel connection only.
A stereo plug would allow a mic and head phone connection ujsing a 'common' for the return.
A mono plug would allow either a mic or a headset, not both.
If you could peer into the jack inside your computer, you could tell if it privides for three wire (stereo) or two wire (mono) operation.
I hope this helps ... If I missed your question, please reask.
We are "paid" here by positive comments where we earn "bragging rights" If you are satisfied, please post positive comments
thanks
a
Oct 12, 2009 | Computers & Internet
Can convert a stereo headset to a telephone headset?
hi only if you have some experience on how to add a mic in fact is a electret mike and are very cheap you joust cut one wire to hook the mic and thats set.....as you do this take a especial attention on which wire be the mic and the ear.......so you connect right..................saludos
Nov 18, 2008 | Portacom Porta-Com COM-60FC 6 Headset...
Cell Phones Logo
2,768 people viewed this question
Top Cell Phones Experts
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
