Question about Ricoh Aficio CL3500N Laser Printer
Vetical lines printing on page
I get vertical lines printing down the length of both sides of the page.
  • LibraryLib Nov 07, 2007
    Blue lines down the length of the page are so noticable that the page cannot be used. Is there a setting in the menu to address this?
    Problem Solver:
  • 7 Answers
Print a coulr sample page from internal memory and if issue is present it is a physical issue with the colour pcu, if it doesnt happen on sample page, then check driver versions- update
Posted on Feb 15, 2008
  • 4 Answers
Did you re-fill the black toner cartridge with genuine Ricoh toner or from somewhere else? It might be the wrong granularity.
Posted on Feb 09, 2008
If the lines are blue, check the color PCU.
Posted on Jan 16, 2008
Transfer Belt Leaving Color Streaks on Pages
Try replacing color toner of the same color that are the lines.If the void was in the same place all of the time then I would say use a Q tip dipped in 90 proof alcohol and clean laser.
Apr 21, 2014 | Brother BU300CL Transfer Belt, 50,000...
Horizontal line running through the middle tv screen, no picture but has sound. TV is a Toshiba.
You haven't vertical deflection.
The ff caused the problem.
1. Dry joints on the vetical section.
2. Blew Vertical ouput IC
3. Open yoke vetical winding.
4. No vertical output from jungle IC.
5. Open supply for vetical ic due to open fusible resistor.
I've suspect that you have #1 and #2 fault. This is not Diy so I've advice you to send to repair shop or look for a qualified tech to isolate the problem.
Thanks for using fixya.
Jan 26, 2011 | Toshiba Televison & Video
Vertical line printed length of page
I had this problem. It is normally one of the drums. Pull out each drum and clean and look the the bottom. If you see a scratch going all the way around the drum you have located the problem. Replace the drum.
Jan 21, 2010 | OKI C5500n Printer
Canon MX700 printer - vertical lines aren't straight
Have you tried to do an alignment. Also check encoder strip
Aug 19, 2009 | Canon PIXMA MX700 All-In-One InkJet...
HP LaserJet 2430 prints vertical grey bands
It is a bad Toner Cartridge or Fuser. Most likey a bad toner cart.
Mar 07, 2009 | HP LaserJet 2430n Printer
Black vetical lines on the screen. how do u fix
You need to flash or update your computer's bios. if you have an inspiron 1501 go here:
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R174470&SystemID=INS_PNT_1501&servicetag=&os=WLH&osl=en&deviceid=13120&devlib=0&typecnt=0&vercnt=9&catid=-1&impid=-1&formatcnt=1&libid=1&fileid=236967
read the installation instructions or print it. then download the file and follow the instructions. after restart. see if you still get the vertical lines.
Mar 02, 2009 | Dell Inspiron E1505 Notebook
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Light grey vertical line printing on left side of paper used the cleaning cycle and line in now doubled There is a black vertical line down left side of the page. I used the cleaning page but the line is...
I believe there are 3 possible causes for this issue; toner drum, fuser or transfer roller - more than likely I would dismantle the printer and check for lines on the fuser. But just in case remove the toner and carefully release the flap to reveal the toner drum - if that is scored and the lines correspond to those on the print-out thats the cause.
Rgds Colin
Dec 09, 2008 | HP LaserJet 2420 Printer
99% of printed page has light grey water mark-as if water-washed
Are you saying it is this problem?
Gray Background Print Quality Defect
Here's another error that might fit the bill:
Vertical Lines Print Quality Defect
If these documents don't quite describe the issue, please post back with more details. Thanks.
Oct 14, 2008 | HP LaserJet 1020 Printer
VERTICAL PRINT LINES
Check the front paper exit rollers for fit and alignment also the paper deck guides close to the planten area, if the printer is dropping print vertically down one side of the page, this can be caused by debris or anything that lifts the caridge assy the slightest bit, also check the print head seating and ribbin cable for proper alignment
Apr 04, 2008 | Canon PIXMA iP3300 InkJet Photo Printer
Ricoh Aficio CL3500N Laser Printer Logo
787 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
