Question about Microwave Ovens
Sensor touch to microwave oven
Ewave under the counter microwave Model KOT-151S Serial # 2020 396  The finger touch sensor is very difficult to wwork.  We usually have to warm the numbers with a cigarette lighter in order for the touch to work and that is after several times.  It was made in Feb. 2002.  Please advise. Thanks Jan Kraft
  • 2 more comments
  • glennskitche Nov 28, 2008
    I have the same problem
    Have had problems as long as we have owned it.
    Where can I get a replacement key pad and how much
  • Anonymous May 02, 2009
    KEYPAD SENSOR REPLACEMENT PARTS
  • Anonymous May 23, 2009
    It has developed another problem too where it responds with a 2 when the zero is pressed and turns the turn table on and off when the start button is pressed. It doesn't do it all the time, so several attempts eventually gets it to start. Sometimes it turns the light on when you press the cancel button.
  • Anonymous Apr 01, 2014
    NEED TO FIND WHAT TO DO
  • Microwave Ovens Master
  • 9,098 Answers
Sounds like a bad keypad.
For parts see: https://www.mcappliance.com/orderparts.aspx
For support help:
http://www.mcappliance.com/contactus/contactus.asp
Posted on Nov 18, 2007
What is the Serial Number for the EWAVE KOT- 17sb? It does not display it in the information panel.
Hello, Marisel -
Do you mean the Daewoo KOT-170SB microwave oven, instead?
The manual for the KOT-170SB microwave I found online (PDF format):
pdfstream.manualsonline.com/1/1d0dd7b3-990b-4256-9519-fa2dc1e7c2bf.pdf
shows a "data plate" on an interior wall of the microwave (page 7.)
That may be where the serial number (S/N) for the microwave is printed.
If not, there may be a label or tag at the back of the microwave oven where the serial number (S/N) is printed. Or, there may a label on the back of the microwave oven, look on the bottom.
Best wishes.
Feb 08, 2018 | In Microwave Ovens
My EWave Microwave cuts off before time is done.
you have problem with a) power diode b) high voltage capacitor short, c) Magnetron defective.
you must consult to qualified tech for repair. or go to some repair shop TV for fix it.
God bless you
Jul 10, 2012 | Microwave Ovens
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Dec 10, 2009 | Microwave Ovens
Ewave panel is on lock
As per the owner's manual:
The oven operation can be locked to prevent the microwave from accidentally being turned on. All oven functions can be locked.
To Set: Touch and hold the CANCEL/OFF Pad for three seconds. The Display shows “LOCKED” and the oven beeps.
To Cancel: Touch and hold the CANCEL/OFF Pad for three seconds. “LOCKED” disappears from the Display and the oven beeps.
If this does not work, then try a hard reset: Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails, you probably have a problem with the controller.
We regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week or so with a one-year guarantee. It may cost a little more if you need parts, such as a new keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Aug 26, 2009 | Frigidaire Microwave Microwave Oven
Touch Control panel of my daewoo KOT-151S microwave needs to be replaced. I have to push control pad several times to get it to operate. Sometimes it will go on after just a few pushes, other times it...
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
prototech@usa.net
Jul 31, 2009 | Daewoo Microwave Ovens
Ewave OTR Microwave Oven, Model KOT-153UW. Light
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
Jul 13, 2009 | Daewoo Microwave Ovens
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Microwave Ovens Logo
467 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
