Question about Intel Motherboard
Gigabyte 8s66ifxm-rz my computer just stoped and will not boot, opened case all fans working,ide drive light stays on thats all it just sits there.all help greatly recieved
  • 661 Answers
You may have received a power spike (if you are not protected)
Spikes can Blow the poly fuse in the PSU, and if not protected they can seriously damage your system,  to reset the fuse the system needs to be unplugged from the power for a few minuites.
If this does not resolve the issue check your cables for any irregularities.   If still having problems you may have incurred some damage which will require further testing to resolve.. I am happy to give further support on this is the first part of this resolution does not fix.
Posted on Oct 26, 2007
How to install windows 7 32 bit in my gigabyte 8vm533m rz motherboard
You need the installation DVD, or download the ISO and copy to a bootable USB pen drive.
Boot from the DVD or pen drive and follow the on screen instructions.
You will need the licence key to activate the software.
Nov 13, 2013 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Gigabyte 8s661fxm-rz motherboards (x3) No video output on start up.no bleeps
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
if this fails to fix the problem
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
May 07, 2011 | Gigabyte GA-8S661FXM-RZ Motherboard
When i switch on the cpu ,fans are running ,what no display on monitor,pls give solution for this problem
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 24, 2011 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
Dear Technical Team, I have CPu with motherboard of GIGABYTE 8S 661 FXMP-RZ. The hard disk is working on IDE . But when I conneted another HDD connected with its SATA slot, it is not working. Would...
Can you see the sata drive in the bios? Also, are you tring to boot from the sata drive, or is it an additional drive for data storage. If the sata drive is brand new, then you probably need to partition it and format it.
Boot into windows (from the ide drive) with the sata drive connected (data and power cables). Once in windows, right-click computer (my computer in xp) from the start menu, and left-click 'manage'.
Now, click on 'disk management'. If the drive is new, you will see it in this window, and you can partition it and format it.
Please let me know if this works or not. If not, I can help some more.
Regards,
Joe
Jan 02, 2011 | Gigabyte GA-8S661FXM-RZ Motherboard
Hi. i have no signal to monitor, keyboard flashes lights then nothing, mouse stays lit, can hear drive attempt to start..! Motherboard ?
make sure this hard drive is getting power
Test or replace your PSU power supply unit
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Nov 22, 2010 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
It hangs up after press any key to boot from cd
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 17, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
7NF-RZ Motherboard not go on
Is the cpu ok? Without the fans the life of the cpuis very little.
Stelios.
Feb 22, 2010 | Gigabyte 7NF-RZ (GA-7NF-RZ) Motherboard
Not deteck hdd & cdrom
Power down you're system and remove the power cable from the PS.
Open you're case. First clear the cmos jumper. See bottom of page 14 in manual. The GA-8VM533M-RZ motherboard was made Jan-1-2004. It is very likely that the cmos battery needs to be replaced. Average life span is 5 years or less. Pull the cmos battery and check its voltage with a voltmeter, it should read no less than 2.7volts DC.
I'm guessing it’s the bios that’s not seeing the CD-ROM drive and the hdd? Suggest you check both the data cables and their power cables.
Since the GA-8VM533M-RZ motherboard only supports ATA IDE hdd's, check the drives jumper. (It should be jumpered as a Master) and so should the jumper on the back of the cd-rom drive. See the link provided; http://www.easeus.com/resource/install-ide-hard-drive.htm
The link above helps but you're hdd may be different. See the sticker on
you're hdd for the correct jumper setting.
If you are using a single data cable to connect both cd-rom and hdd to the motherboard don't. Use an 80-pin data cable for the hard disk drive. You can use a 40-pin data cable for the cd-rom but if you have a spare
80-pin data cable connect the cd-rom drive to it.
Connect the hdd to IDE1 and connect the cd-rom to IDE2. See motherboard layout in the manual page 5. Need the manual? Download it from Gigabyte; http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1766
To view the manual you will need to download and install Adobe reader;
http://www.adobe.com/products/reader/
Re-connect the power cable to the PS. You can leave the case opened for now. Power on the system and press the Delete key every 2 seconds until the bios menu opens. (Make sure the time and date are set current). See page 19. Than turn to page 23. Make the settings as follows;
First Boot Device [Floppy] - (if one is connected)
Second Boot Device [CD-ROM
Third Boot device [HHD-0]
Password Check [Not needed]
CPU Hyper-Threading [Enabled]
Check all settings while in the bios, save and exit. The system will auto re-boot. If after replacing the bios battery (If needed), and the bios still
does not see either drive than the problem is either the bios or the motherboard's controller. The bios can be flashed but the MB controller can not be repaired.
Cheers'
Mike
Feb 15, 2010 | Gigabyte 8VM533M-RZ (GA-8VM533M-RZ)...
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Not booting
Check your monitor,if it is running fine.Switch off your pc and monitor both.Switch on again.If u are not getting any display on screen ,u may need to repair your monitor.in between press on capslock or numsluck key.If keys are giving lights then 100% it is a monitor problem.
Jul 21, 2008 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Intel Motherboard Logo
161 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
