Question about Fuji Printpix CX-550 Thermal Photo Printer
While tryiny to print an error message says that I am using the wrong paper
Only not really.  Everytime I go to print the cx-550 tells me that the wrong paper is being used, but I am using the right paper.  What do I do?  I have loaded - reloaded - repositioned - used another new roll.  I am at a complete loss.  I have called Fuji who tell me that they do not make printers and transfered me to every department there.  This is my last hope - after this I am going to throw the thing in the garbage - and it is relatively new!
  • sickoffuji Oct 26, 2007
    Sorry - that does not seem to be the problem.  When I open the printer up after it has "aligned" the paper is at a much higher position than what it should be at, and that is why I think that it says it has the wrong paper in it.  I went into the paper size and it was appropriate for the machine.  There were no roll paper choices only 4x6 etc.
  • 78 Answers
I am guess you having Windows XP. I do not have this printer but it sounds like the paper selection is what windows is telling it to select. on your computer go to Start/ control panel / Printers / printer and fax. right mouse click on your Printpix printer icon and select properties.  under general click on Printing Preferences/ here where it could get a little different. you may have basic or advance chooses. and under one of these you should see paper type. select your correct paper such as roll paper or it may have a paper number. if you need more help reply here with where you are on this step
Posted on Oct 25, 2007
  • Paul
    Paul Oct 29, 2007
    Sorry I couldn't help. If you could give a Rate such as thanks for trying, so they will not charge for support in 1 week.
I cannot print with windows 7 I have fuji film cx-550
You need to download the UPDATED VERSION of your printer that supports win7 64 or 32 bit.
Jun 02, 2011 | Fuji CX-550 Printer
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Close the scanner unit.
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
Mar 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Everytime I try to print an envelope using my Canon imageRUNNER 1023iF I get an error message. I'm using a Microsoft Works Word Processing program. I have loaded the envelope tray and nothing happens...
To get rid of error, unplug machine.
Sett. the correct paper size ( size of envelope ), paper type (envelope ), both on printer properties ( when you prompted to print ) and on machine ( when you put envelope on bypass, machine auto ask you ).
Do not forget to tell printer that he needs to take paper from bypass ( printer properties )
Hope that helped
Jul 04, 2010 | Canon imageRUNNER 1023 Black and White...
The card cover of my printpix 550 is broken how can i print since the message see manual when your card cover come off
hey im having a problem with my computer printer i conect it and i cant see anthing on the sreec it blacks out/
Feb 16, 2010 | Fuji Printpix CX-550 Thermal Photo Printer
Printer is loaded with paper but get message
Although you really haven't given me enough information, I will posit and response for you.
A "Load Paper Error can be caused by the application telling you to change the "TYPE or SIZE" of paper that is in your paper tray.
For example, The application thinks you want the page printed on "Letterhead" paper, but it know that you have plain bond paper installed.
So you are sent a change paper type message.
The fix is to hit go and skip around that error.
The actual fix is to make sure that your printer driver, application and the printer are all set to the same size paper and type paper.
Don
Nov 05, 2009 | HP Hewlett Packard LaserJet P1005 Printer
Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Jul 03, 2008 | Lexmark T640 Laser Printer
Wrong paper size message
Choose the correct paper size from the setup and change the paper type to 'plain paper'.
Hope this help.
Apr 17, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Scaner Epson CX-5400 error message
What is the error message? SCANNER ERROR?
If that is what you getting, turn printer off then open scanner cover- on the left hand side there is a toggle log for scanner, position it to unlock then turn printer on then try scanning/copying again.
if your having a different error message pls indicate the exact error that you are getting.
Feb 22, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Can't print faxes due to error messages
Please check rear door area for paper, can you use manual feed slot? Power off machine with all jams removed and paper loaded, then power on, can you tell us exact error message/lights that are shown in this state?
Oct 15, 2007 | Brother IntelliFax-2820 Laser Fax
Fuji Printpix CX-550 Thermal Photo Printer Logo
66 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
