Question about Maxtor DiamondMax Plus 6800 (91366U4) 13.6 GB Hard Drive
Gateway Hard drive replacement
I have a Gateway ATX Micro Select 360 that has no Hard Drive. What Can I use to replace it?
  • Birdy176 Jul 07, 2008
    Want to use my 250 giga HDD from Gateway 831GM as external drive (slave) on my new E-Machine (both XP!) because opening the case of the latter would void my warranty. It would be my preference.
    Have a large number of files that I want to use on the new unit and am not comfortable with using a cable transfer.
    What case would you recommend with regard to Pata, Sata and any other alphabet salad? Or does it matter since both are relatively new machines (The Gateway is barely 3 years old and I lost both optical drives - hence the new one).
    Have tried to "revive" those drives but the Dev. Mgr keeps showing them with yellow marks. Any help/advice is appreciated.
    Novelist:
    Champion:
  • 382 Answers
Any PATA hardrive. Parallel also known as IDE. I would go for SEAGATE barracuda, simple, effective, and a 5 year warranty.
So, you will be looking for a 3.5 parallel hard drive. Check if your computer has a partition limit, ie, pre firewire 800 machintosh G4 towers cannot take single drives larger than 120 GB.
ATX is your motherboard form factor.
Keep me posted.
Posted on Oct 28, 2007
Graphics card crash
Does this MB have a onboard video card or are you using a add-0n card? If onboard then either replace the MotherBoard or add a video card that is compatible with your MB.
Mar 08, 2014 | Jetway JMI5G41SGMD2LF LGA 775 Intel G41...
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Can't detect hard disc
First - re-seat the harddisk and reboot the computer. If this does not work then reboot and go to theBIOS configuration to see if the BIOS detects the hard drive. If it doesn'tdetect the hard drive then it could be faulty. Next - to determine if thehard drive is faulty, remove the hard drive and insert it into an USB hard drive adapter and connect it to a workingcomputer's USB port. If this computer cannot see itas an external hard drive and you cannot open the various folders and files,this confirms the hard drive is faulty. Then the hard drive needsto be replaced in the computer, Windows installed and the computer's device driversplus your programs etc. to get a functioning computer again.
May 11, 2011 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
What size hard drive goes in a micro atx bry essential 466c
It doesn't matter what size the drive is (in GB, not physical size) and anything over 20 gigs or so is acceptable for just checking email and using office. You will need an IDE drive and just in case you were asking for physical dimensions they are standard for PCs... 3.5 x 5.79 x 1.03 inch
May 05, 2011 | Gateway Essential 466 PC Desktop
Im having display issuse with my GIGABYTE GA-880GMA-UD2H AM3 AMD 880G HDMI SATA 6Gb/s USB 3.0 Micro ATX AMD Motherboard .. everything is plugged in and when i turn it on everything lights up but i cant...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
also
click start control panel administrive tools computer management device manager scoll to ports(com&lpt)right click to scan for hardware changes or scroll to monitors + to expand plug and play monitor right click where you have options to update driver,disable.uninstall,scan for hardware changes or select properties where in the general you have the option to troubleshoot also in the driver tab you have the same options as when you first right click on monitor
also
click start control panel,display,desktop you can select a different desktop from the drop down list also settings you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
hope this helps
Apr 16, 2011 | Gigabyte GA880GMAUD2H AM3 AMD 880G HDMI...
It wont read on my xbox 360
If you already have the Spring 2010 Dash Update for the Xbox 360 console this can be configured( go to Setting up your Xbox 360 with your USB Flash Drive).
The update allows you to configure a flash drive to hold up to 16GB of Xbox 360 games, gamertags, videos, and other information. You can connect two USB storage devices to your console at once.
  • If you don't have it yet, you need to download the update:
To install the update through Xbox LIVE
1. On your Xbox 360 console, sign in to Xbox LIVE.
2. Select Yes, updated now when prompted.
3. When you see the new Dashboard, you're done.
Setting up your Xbox 360 with your USB Flash Drive: 1. Plug the USB flash drive to the Xbox 360 console.
2. On your console, go to My Xbox, and then select System Settings.
3. Select Memory.
4. On the Storage Devices screen, select USB Storage Device.
For detailed instructions you can visit: http://kb.sandisk.com/app/answers/detail/a_id/2777
Nov 25, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
No boot.no window.but powersupply is run.
One bad/faulty lead can cause a computer with lots of problems
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Oct 23, 2010 | ASUS P5KPL-AM - Motherboard - micro ATX -...
My hard drive can't be read by my motherboard
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Sep 12, 2010 | Gigabyte GA880GMUD2H AM3 AMD 880G HDMI...
Xbox 360 not reading cd
It could be because your CD/DVD drive is dying, the best fix is to replace it. I can replace your Drive cheap and fast if you feel it has come to that point.
Jan 17, 2010 | Microsoft Xbox 360 Console
Gateway gt5404 reads no bootable device pc seemed to siow down some then went black was after micro. soft update ? unpluged twice pulled batt. reconected it worked set clock back worked awhile went black...
Any hard disk that makes clicking or metallic noises is faulty, especially when POST error message no bootable devices detected.
To confirm go into the BIOS setting and see if the hard drive is detected, if it cannot detect the hard drive then it is definitely faulty.
Replace the hard drive and install Windows on the new hard drive to get the computer working again.
Jul 31, 2009 | Gateway Computers & Internet
Maxtor DiamondMax Plus 6800 (91366U4) 13.6 GB Hard Drive Logo
325 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
