Question about Microsoft Windows Vista Ultimate Edition
Modem busy 797 error on Vista.
I've had this modem working fine on the same laptop before. I had to reinstall vista on the laptop and since then it won't work. It installs fine, there's no drivers need updating. When I try to connect it says the modem is busy. I installed the modem on my desktop and it worked straight away, so the modem or the software isn't broken. I've uninstalled/installed.. turned the firewall off... stopped windows defender starting and bulldog incase that was stopping the connection. I tried to ping google, nothing. I don't know what else to do. Can anyone help please?
  • 37 Answers
Re: Modem busy 797 error on Vista.
Hello sir, this might be an driver issue since u have reinstalled the modem.the modem might have came with some driver installer plz check the driver and install the driver by inserting the cd and searching the driver from cd.
Posted on Oct 27, 2007
0 characters
3 Points
Hallo! I have a problem with my 3G modem (Huawei E1550) When I try too connect It says: error 797! Computer: Netbook MSI wind, OC is windows 7. This modem works perfectly on another computers!
Try the following steps bellow -
  1. Click Start and then click Control Panel.
  2. Double-click Phone and Modem Options.
  3. Click the Modems tab.
  4. In the The following modems are installed list, click the modem that you want to remove, and then click Remove.
  5. Click Yes in response to the "Are you sure you want to remove the selected modem(s) from your system?" message.
  6. Restart the computer. Found New Hardware Wizard will starts. Follow the instructions in the wizard to reinstall the modem.
Nov 03, 2010 | Operating Systems
Error 638 while connecting through modem on
Sir, error description is of "The request has timed out".
First, Try once by restarting the system
Second, You can try diagnosing the modem if the diagnosis results some text. Then modem should be working. Else, check for proper cabling.
To diagnose modem
1.Click “Start” then “Settings > Control Panel” or “Control Panel”.
2.In Control Panel select the “Phone and Modem Options” icon.
3.Select the “Modems” tab in the top middle, of the new window that opens..
4.Then on the next screen select the “Properties” button in the lower right.
5.You should now select the “Diagnostic” tab in the top of the new window..
6.Then click on the “Query Modem” button in the middle of the window
Lastly, try unstalling an installing & reinstalling the modem driver
Hope this helps
May 19, 2010 | Microsoft Windows Vista Home Premium...
Laptop Toshiba L501 win vista home premium got problem RAS error code 608 when use with vodafone internet model K3765. This internet key work with other laptop run xp or vista... Could anyone please tell...
Error #608
Error Message: The device does not exist.
1. Check that the right modem is set in the dialer
2. Ensure that you are using the right modem drivers by checking the modem diagnostics. If it’s not the case, set up the correct drivers.
3. Remove and install the dialer again
4. Your modem might not be working properly; try to install it again.
5. You should then consult your computer manufacturer if the problem persists.
Apr 12, 2010 | Operating Systems
What does mean error 797
A certificate could not be found that can be used with this Extensible Authentication Protocol.
Apr 12, 2010 | Microsoft Windows? Vista Home Premium...
What dose error 797 mean
plz give ratrings..
Feb 07, 2010 | Microsoft Windows? Vista Home Premium...
USb SXC -1080 modem of tataindicom causes problem with vista
the usb modem you are using is compatible with windows vista but for that u need to install the driver software ie sxc 1080 vista dialer 32 bits . you can download this software from the tataindicom site which is windows 98 and vista have different software compatibility.
Oct 01, 2009 | Microsoft Windows Vista Ultimate Edition
Error message Vista Fax setup
Right Click on My Computer icon and go to manage. Go to event viewer and under the System (and also Application) categories, check for errors.
In the same window, go to Local Users and Groups->Users->Your user profile->Member Of and check whether you have sufficient rights(are you an Admin???), then go to Seervices and check whether the Service can be started in your profile.
Good Luck.
If the solution is helpful, please rate the answer kindly.
Jul 06, 2009 | Operating Systems
Facing ploblem while using TATA indicom USB modem in Vista Home Basic
Hi I'm Sathiya. I use Windows Vista Home Basic platform. I recently bought a TATA Indicom Plug to Surf connection. It had issues with drivers. I went to Tata indicom site and downloaded the latest driver for Vista. After installing the drivers, my connection is working fine. Make sure that you choose the right version.
Jun 27, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Ultimate Edition Logo
684 people viewed this question
Top Microsoft Operating Systems Experts
Brian Sullivan
Brian Sullivan
Scott Fryer
Alex Krenvalk
Are you a Microsoft Operating System Expert? Answer questions, earn points and help others
