Question about Toshiba 65HX81 65" Rear Projection Television
Black spot inside projection screen
Remove black spot behind screen on projection screen
0 characters
1 Points
I have a mitsubishi 63 inch 1080pi and and at the bottom of the screen it has a black spot about 1 inch on it...what is the cause of it and what need to be did to fix it?
it might be a dead bug or something inside the projection area behinb the screen. If you gently shake theTV (with it off) does the spot then move when you turn it back on? If so, you can get inside the projection area and vacuum it out.
Aug 30, 2015 | Mitsubishi Projection Televisions
Round black spot in middle of the picture/screen
Hi :-)
The round blotch your seeing on the screen is the melting of an acrylic lens inside the light engine. Its a design flaw which unfortunately Infocus will not stand behind. To fix this problem requires opening the light engine and putting an equivalent lens in place. This task is very involved, but this problem is repairable and you need a glass smith to cut the right size lens from the original.
Sep 23, 2009 | InFocus ScreenPlay 61" Rear Projection...
Black spot in bottom of tv
I just had my caps replaced and after the tech put it back together there was a spot. He tok the screen off and cleaned the mirrors around the bulb and the large mirrors(they were reaaaalllllly dirty. It did brighten up the picture and it looks crisper, oh and the spot was gone.
P.S.. Like nettiser stated. If it's unde warrenty have them do it. If you drop something "you will be pissed" if you don't !
Aug 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Hazy yellow spot in the left lower corner of the screen
It could be a cob web inside the tv or something laying on one of the guns, like a dead bug. If it's a cob web, you should be able to move the tv a little side to side and see it change from the moving air current. I would remove the back and vacuum off the lenses of the guns and look for cob webs. It's safe to touch and clean the lenses, just don't touch any electronics.If this doesn't fix it, it's probably fluid starting to cloud up in the guns or IC chip problems.
Jan 08, 2009 | Hitachi 53SBX59B 53" Rear Projection...
Remove screen from Hitachi Ultravision
underneath screen remove screws holding screen in place ,it should then slide upward and off.
Dec 08, 2008 | Hitachi 61SDX01B 61" Rear Projection...
yes you can remove the screen by removing the front plastic trim and the removing the screws that hold the screen in. clean the screen and put it back together.the front plastic trim should just pop off
Aug 30, 2008 | Sony KP-51HW40 51" Rear Projection...
Water stain on the front of our Akai PT5499 Projection TV
Hmm... should evaporate on its own. The only way to access behind the screen is to take the whole back off the TV, and then inside theres another panel that covers the main reflector and screen. I wouldnt recommend doing that just for water tho.
Dec 30, 2007 | Akai PT5598HD 55" Rear Projection...
JVC 61" Rear Projection HD61Z456. Need to take the front screen off.
IF this is in the screen... there has been issues where the entire light engine has to be replaced...
Dec 03, 2007 | JVC HD-61Z786 61" Rear Projection HDTV
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Screen spot
Since you have a black spot,you need to look at the mirror or inside screen. If it were a certain color, like purple or yellow, for instance, I would suggest a lens or picture tube, but, since it is black in one spot, I would suspect debris in those areas.
Dec 12, 2006 | Toshiba 51H84 51" Rear Projection...
Toshiba 65HX81 65" Rear Projection Television Logo
512 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
