Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jun 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spin speed slow
Duet washer is not spinning to correct speed, and removing the water from the garments in the load
Anonymous
Level 2:
  • Expert 44 Answers
  • Posted on Jun 06, 2009
Anonymous
Expert
Level 2:
Answers
44
Questions
0
Helped
21993
Points
163
Sometimes this is a problem with the drain pump filter. It will get clogged with debris which will cause unit to spin slowly. The panel at the front bottom of unit will grant you access to the filter on the pump. Get a bowl or bucket and get ready to catch some water. Good luck
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
I have a whirlpool duet steam front loading washing machine model # WFW9600TA01. recently when my wife starts a load of laundry at night when she wakes up in the morning the washer is still turning at a...
I would assume the load in the washer is a small load and the washer has a difficult time adjusting the load to spin. I would push pause, wait for the system to unlock the washer. Check the load for how much water in the garments. If heavy, the unit has a unbalance issue, just try to continue the load. If the clothes are light than unload the washer into the dryer. Was the unit ran on delay? This may be a non issue if the unit ran on a delay and just never finished yet.
Give those a try and get back to me, I and interested in the status.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
2helpful
The Whirlpool duet washer I have is a WFW8300SW. The problem I am having is that now when it goes into spin cycle I don't think it is spinning as fast as it should be. How can I fix this?
Most common to cause slow spin is slow draining. Remove the lower panel (3 screws) and remove the pump filter. It simply unscrews and can be cleaned of debris to facilitate fast drainage and good spinning results. Be sure to have a few towels handy to catch the little bit of water that remains in the lines when you unscrew the filter.
2answers
My clothes is wrinkles by my front loader washer
SPIN SPEED IS TOO HIGH- USE A CYCLE WITH A LOWER FINAL SPIN SPEED.
2helpful
Whirlpool duet series washer spins really slow
no high spin speed will ever be acheived if the water cant drain out,, remove th elower acess panel (3) screws acros the front of unit, from there youll see a drain clean out, unscrew the plastic and remove the dbris,, BE WARNED THER EWILL BE WATER BEHIND THE SCREWOUT DRAIN PLUG!!!!! i usually grab a trash bag and hold under to catch the gallon or so of wate rthat will come out
Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Control Lock
Code to restart washer Duet
Answer Is the Delicate or Hand Washables cycle selected?
Spin speeds can vary by the cycle that is selected. Your washer is designed so that in certain cycles, such asDelicate or Hand Washables cycles, the spin speeds are slower. In these cycles, more water is retained in the load at the end of the cycle to keep delicate fabrics from shrinking and wrinkling. Select the appropriate cycle based on the fabric being washed.
Was an Extra Low, Low or No Spin option selected?
Select the highest spin speed for the fabric being washed. If extra low spin or no spin was selected, the washer may not remove enough water from the load.
Were you washing one bulky item, such as a rug or large blanket?
Consider adding more items to help balance the load during spin. Select $FL-drainspin cycle and restart the washer. Your washer is designed to detect an unbalanced load and automatically lower the spin speed. Unbalanced conditions are more likely to occur with a single, bulky item.
Are excessive suds present?
Use only HE High Efficiency detergent. Using non-HE detergent or more than the manufacturer's recommended amount of detergent can cause excessive suds. The excess suds can cause the washer to run at a reduced spin speed, which will result in very wet loads.
See also: Why HE High Efficiency detergent is required.
Is the drain hose kinked or is the drain clogged?
Make sure the drain hose is not kinked. Straighten the hose for adequate water flow. Remove any blockage from the drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm) maximum and 30" (76.2 cm) minimum. Your washer will not be able to adequately pump the water out of the washer if the drainpipe (standpipe) exceeds 96" (244 cm). In this case, the water may flow back into the washer. See the Installation Instructions for details; find them by entering your model number in the Manual and Literature search below.
Is your outlet voltage low?
Check electrical source or call an electrician.
Duet Washing Machine spin cycle is spinning slow
make sure u are not under loading the washer with just one or two items and that the load is fairly balanced or else the machine will not go into high speed spin as to not go completely off balance and walk across your floor if that doesnt fix it you might need a new ccu or motor control board probably the second one and make sure u are using HE detergent and not too much because suds will lock the pump up which will not spin with water in the unit
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
