Question about Durabrand DWT2405 24" TV
Switch from AV to regular TV viewing
My daughter has lost her remote for her television and now it is stuck on AV and can't switch back for regular television viewing. I've tried the menu but nothing there seems to help.  Is there any way to switch this w/o the remote?
Re: Switch from AV to regular TV viewing
You try pressing the AV button on the side, sequentially until it changes back to a Channel Number. It should cycle through AV1, AV2, RGB, etc
Posted on Nov 17, 2007
0 characters
3 Points
Can i change the input settings without the remote
pls check from channel one to zero you can see AV input.
Aug 17, 2009 | Insignia IS 20" TV040919 TV
TV stuck on Video
I had this problem, I replaced the remote and it works now
Feb 27, 2009 | Sanyo DS31590 31" TV
Universal remote works for basics but won't change input
good day , what button can you see infront of your TV screen?
Not familiar with this model but if you'll manage to locate a button marked as "TV/AV" or "AV" press this button until it the display switch to A/V mode (audio/video). Or if this is a really old model, from Tuner mode or channel model. set the channel station to 1 then press the " - channel " button and see if it will change from tuner mode to A/V mode
Jan 31, 2009 | Toshiba 32A33 32" TV
Old Sylvania model #6420FB lost remote how to switch to av mode
Unless the TV has a front-panel menu button and allows you to switch modes from there, you are out of luck. There are two possibilities. One is to try another replacement remote. If you get a universal remote made by the TV manufacturer (Magnavox), it may have buttons that will work. The other option is to purchase an RF converter, which will cost around $15. This will take the video/audio signals from the game and convert it to a channel 3 or 4 signal you can then tune in on the TV. The picture won't be quite as bright and clear as with direct AV input, but it will do the trick.
Jan 11, 2009 | Durabrand BH1304D 13" TV
Hitachi C28W440N can't switch over AV channels no remote
have you tried buying a universal remote? you can get a decent one for £10 these days from any electrical store, such as curry's or maplins. it gives you a 3 digit code for the tv to link up with the remote and then you can switch over to av. some hitachi tv's also link up to av automatically if you connect your game station via scart socket (in the back of the tv) if you turn the tv off and link your wii up to the back and make sure the power is turned on before the tv is switched on, there's a chance the tv will auto detect the av channel. not all do but it's worth a try. hope this helps!
Dec 25, 2008 | Symphonic ST419E TV
Sanyo tv stuck on "video 2"
I had the same problem and had to buy a new remote. Just Google Sanyo remote--it's the more expensive one with more buttons. Good luck.
Apr 13, 2008 | Sanyo HT32744 32" TV
Av mode?
well if you change the channel to the highest it goes some TV can be changed to a/v mode
or the lowerest number under 2 sometime a/v might be there
remote stop working due to batteries or drop remote, might have to be replaced either abtteries or whole remote.
Mar 03, 2008 | Emerson SpongeBob SquarePants TV
TEAC Television -CT-M809AV -no picture
Maybe it's something with NTSC/PAL settings, or SOURCE SELECT. Check troubleshooting in your manual.
Oct 11, 2007 | Sylvania 6419TE 19" TV
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Durabrand DWT2405 24" TV Logo
268 people viewed this question
Top Durabrand Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Durabrand Standard (CRT) Television Expert? Answer questions, earn points and help others
