SOURCE: Juice on keyboard - Acer Aspire 5633WLMi
This is a toughie. I had a Sony Vaio last year which popped a key off one day, and I never could get it popped back in. you might try it with one key, but that wouldn't guarantee that another wouldnt break. Call Acer telephone support (if you go online for support, they don't even list their telephone number, but try to trick you into thinking you have to use their hair-tearing lousy self-diagnosing troubleshooting programs online, which are worse than useless). If you get a rep who won't help you, demand to speak to a supervisor. Acer customer support is 800 816-2237, 8 to 5:30==not certain if they are open weekends. Good luck.
SOURCE: Laptop Acer Travelmate 2300 Sticky Left mouse button HELP!
If you have the disk remove/reinstall the mouse
no disk , search the make and model
No mention of which OS your using so let me know if you need more assistance
If your using XP try this
Go to start
control panel
add/remove
device
remove
reboot
reinstall
Hope this helps , let me know outcome thanks
SOURCE: Spilled coke on the touchpad and keyboard of Acer Aspire 5920
Not so sure on the touch pad, but the keyboard is easy to remove. Make sure the laptop is switched off first.
There are a series of little clips holding the keyboard on. Look along the top above the F keys you will see 3 or 4 little clips, push each of them in and up (away from the keyboard) using something thin and blunt so as not to cause any damage.
There will also be some little clips each side of the keyboard, these do not push in, you need to manoeuvre the keyboard past these.
Lift the keyboard from the top as it slots into some grooves at the bottom.
There will be a ribbon cable connecting it to your laptop, this is easily
undone and the keyboard is off.
SOURCE: Laptop keyboard needs cleaning
I had a client with that problem--we removed the keyboard and tried to clean it. Turns out that our cleaning job was less than perfect because the laptop keyboard is mostly sealed. There was liquid that seeped down onto the motherboard as well--that we could clean up. The long and short of is--you will probably need to replace the keyboard. Of course, with nothing to lose, you could wash the keyboard and let it dry out thoroughly, plug it in, and see if it works. The key here would be the thorough drying. If you decide to try this chancy procedure, don't dry it with high heat. A hair dryer set on low might be the answer.
SOURCE: keys are sticking the keyboard. Can i clean underneath the keys?
Depending upon how sticky the keys are, it might be easier to buy a cheap replacement keyboard. Trust me, it takes a whole lot of patience and a steady hand to take apart the keyboard key by key and then put it back together.
