Question about Heidelberg Linocolor Jade 2 Flatbed Scanner
Vibration of scanner causing misaligned image scan.
Recently my Jade2 scanner started having vibration problems during a scan. The vibration is not constant, sections of the scan are fine then a section will have misaligned scanning due to the vibration of the scan head as it travels down the rod.
Is there an fix or is it time to retire this old horse?
Brian
  • 20 Answers
Drop some lubricant grease should work
Posted on Oct 25, 2007
I have 2008 Kia Sportage, with a vibration during acceleration, I have new complete axles and drivers side hub bearing? This started after having a front end alignment done? I checked Drive line?
The location of a vibration will depend on the frequency, general direction, type of vibration or general sensation.
If it is felt principally under your feet, throught the steering, the pedals, the gear lever, etc. it is probably at the front. If it is a general shaking at transmission speed it is probably driveline. If it is at wheel speed it is probably hubs or axles. A slow sideways vibration could be wheel or tyre related and so on.
It is difficult to suggest any one thing or even an area unless you can paint a picture with words so I am almost experiencing it as you are.
It would be unlikely having the tracking checked/adjusted would be the culprit and it is probably coincidence.
A few possible causes are misaligned propellor shaft, bad viscous coupling, limited slip differential partially seized, excessive axle wind-up...
Apr 01, 2017 | The Computers & Internet
What causes steering wheel vibration at40 mph and below
Steering wheel vibration during braking points to warped brake disc/rotors your other problem could be loose engine mounts
Oct 18, 2014 | 2007 Nissan Versa
Toyota corolla vibration
could be worn down rotors (the big metal disc). The thinner rotor will not dissipate heat during braking and the pads get too hot to be able to grip the rotor and while braking you get a shudder effect
Check also the rear suspension as this can cause font tire wear un evenly
Nov 05, 2017 | Cars & Trucks
LG WM0642H washer "excessive" vibration
sounds like damper rods are getting worn. they support bowl underneath.i think if u change them it should fix problem. is it noisy during spin?if u need more help please reply. please turn power off b4 working on it do not want any accidents.
Apr 08, 2010 | LG WM0642H Front Load
Vibration at 60mph
Hi vibration at 60 is normally wheel balance not the alaignment, get the 2 front wheels weighted and balanced, if they are wearing unevenly then it could be suspension bushes,track rod ends.
But most likely the wheels just need balancing only cost about $20 to 30 max
Hope this helps
Regards
Dan
Feb 14, 2010 | 2001 Mercury Sable
Vibration during acclerating .ford f150 91
Believe it or not check your engine and transmission mounts. They are reinforced rubber and they may be giving, causing misalignment, creating vibration.
Feb 01, 2010 | 1991 Ford F150
Vibration in handlebars/forks??
Front end vibration can be caused by front rim/tire out of balance, worn wheel bearing(s), bent front rim, or fork misalignment.
Since you recently had fork work done, I would first check the forks for proper alignment, then have the bike on a stand and spin the wheel to see if there is wobbling. To check for bearing wear, while the front is off the ground, try to rock the wheel from side to side. If you can feel or see movement, you will need new bearings.
Hope this helps
Mar 17, 2009 | 2000 Harley Davidson FLSTC Heritage...
Damaging vibration over 70mph
If this started after the rear wheel replacement recheck the allinement of the wheel it could have slipped.Then check condition of the drive belt for hard spots or missing teeth.If all this checks out have the wheels balanced and check steering head tension
Jan 23, 2009 | 2000 Harley Davidson FXDWG Dyna Wide Glide
DR-9080C intermittent stops during scanning which last 3 to 5 minutes
Do you have enough hard disk space? Reinstall your driver software. Run Scandisk on the Comp.
Is the problem coming on after a set time interval, any heating smell?
S. Mohan
Jun 22, 2008 | Canon DR-9080C Path-Through Scanner
Heidelberg Linocolor Jade 2 Flatbed Scanner Logo
123 people viewed this question
Top Heidelberg Office Equipment & Supplies Experts
k24674
jasbo
jasbo
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
