Question about Acer AL1916W 19" LCD Monitor
Screen rolls I turned my computer on and the csreen was rolling and flickering.I managed to lower the screen resolution and it stopped.Any ideas as to why ?Is it time for a new screen? Thank you....D>
I'm writing to you on a screen that is rolling and sometimes flickering right now. I've tried 3 different screens on the same outlet, and they all have the same problem.
1. If you have any speakers near your monitor, try moving them away, this might help because they might not be shielded enough.
2. Try another screen, if the problem persists, it may be your power outlet.
3. If you don't want to spend money on a new screen, spend some time looking for a 3-prong grounding adapter.
I used the 3-prong grounding adapter, those little adapters that plug into the wall using 2 prongs, and then you can plug a 3 prong appliance into them on the other site, and it helped make the rolls not appear as often, and not as dark.
I think it is something with my power or the plug I am using.
Hope this may have helped a tiny bit
Posted on Nov 04, 2007
My screen keeps flickering and its only two weeks old
Step 1 Change the refresh rate to match the capabilities of your monitor. The refresh rate is a measurement of how many times the screen redraws each second. Although this setting is related to older, desktop monitors, it can affect the quality of the Liquid Crystal Displays found in laptops. Right-click the desktop and choose "Screen Resolution," then click "Advanced Settings" and "Monitor." If enabled, place a check beside "Hide Modes That This Monitor Cannot Display" and choose a higher refresh rate from the list.
Step 2
Update your graphics card drivers. This is the most likely cause if you've always had a problem with flicker. Look for "Hardware and Sound" in the Control Panel and click "Device Manager." Under "Display Adapters," you'll see the exact brand and model of your video card. Go to the manufacturer's driver Web page and search for this model to download the appropriate drivers. Alternatively, you can revert to an older driver if the flicker began immediately after an update. In this case, return to the Device Manager, right-click your adapter and then "Driver." Click "Roll Back Driver" and "Yes" to confirm.
Step 3 Turn on Vertical Sync if the flicker occurs when DirectX or OpenGL is in use, for example, while playing a PC game. Vertical Sync, or VSync, locks the refresh rate of the application to the refresh rate of the monitor. Horizontal flicker is reduced, which improves image quality. For Nvidia cards, VSync is found in "Manage 3D Settings." For Intel, look for "3D Settings" or "Asynchronous Flip." On ATI/AMD cards, turn on "Wait for Vertical Refresh."
Step 4
Lower and raise the laptop screen repeatedly to determine if the flicker is related to movement. Hardware failure is the likely cause when flicker occurs only when the laptop moves. Most likely, the screen cable is loose or damaged, but the inverter and backlight can also cause this problem. The laptop needs to be opened in order to confirm the problem, but do not attempt this unless you are familiar with PC repair and do not mind voiding the warranty. For the best results, take the laptop to a licensed technician or send it back to the manufacturer.
Apr 20, 2015 | Computers & Internet
How do I stop screen flickering
If this occurs within a specific application, it probably has to do with the fact that the application wasn't programmed for double buffering. If your screen is constantly flickering no matter what, it could be bad video drivers. Try updating them. If that fails, it's probably either bad hardware. Try a different video card. If it still persists, it's a bad monitor.
Sep 12, 2014 | Microsoft Windows Vista Home Premium with...
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
When the laptop is turned on, the screen rolls & flickers. I can press on the sides & it stops.
Hello collensdrea,
Welcome to FixYa.com!
Sorry to hear what's happening to your laptop. I would lke to ask you to follow a few steps to check and see if this is a faulty display or not. Please follow the following steps:
1. Turn the laptop off 2. Unplug the AC adapter (if connected) and remove the battery 3. Press & hold the power button for 40 seconds w/o the battery installed or the AC adapter plugged in 4. Let go of the power button, reconnect the AC adapter and put the battery aside for the meantime 5. Turn the laptop on by pressing the power button and the second you turn the laptop on, tap F2 several times to load the laptop's BIOS.
What is a BIOS? This is a special screen that let's you make changes to your laptop's motherboard. Please do not wander around as it may cause the more problems if you are not sure of what you are doing.
The reason why we went here is to see if we can still recreate the same issue i.e. the screen rolls & flickers.
If it still rolls & flickers, I'm afraid you need to contact Acer to have your computer sent to Depot or serviced.
Regards,
Deathschythe33
Aug 22, 2011 | Acer Extensa 4620-6402 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
Flickering screen Toshiba P105
Flickering, always cause by LCD cable. Change it at any computer shop or service center and its not so expensive
May 08, 2010 | Toshiba Satellite P105-S6104 Notebook
Toshiba Satellite M300 screen problem
Hi, I can't guaranty this will help the problem, but for a quick try I say its worth it. On the Desktop, right click to open Personalize, select Display Settings; by adjusting the resolution it helps with the "Flicker effect" aswell, by selecting different settings, you can "view" the best Monitor Display. "If the solution helped, rating it is appreciated, thanks."
Mar 28, 2010 | Computers & Internet
Screen won't stop rolling out
There is a rubber grommet on the left top of the projection screen, insert the supplied Allen key and turn anticlockwise and adjust turn by turn till the screen rolls out with just 2 to 3" of the black border shows on the top
May 16, 2009 | Draper Baronet 106 in. diag HDTV MW...
Picture flickers
Check your power supply. Is it plugged in to the wall or a powerstrip? You might be overloading the powerstrip. Could be a source signal problem. Does this just happen when watching cable TV or does it do it on dvd's as well? Through the PC it is probably the viseo card,try reducing the resolution output from the computer.
May 26, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Acer AL1916W 19" LCD Monitor Logo
288 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
