Question about HP OfficeJet 6210 All-In-One InkJet Printer
HP 6210 Officejet All-in-One
This unit has the command  "Shutting Down'' that appears in the Printer  screen and the Button will not turn Off the Printer.  It seems to be 'stuck.'
The message on the computer screen is:  "Print Cartridge Error"  and I have removed the cartridges several times and replaced them and the cartridges each seem to be installed properly.  The Carriage moves back and forth, but nothing initializes to start any process.
Any ideas?  Thanks.
  • 1,601 Answers
COPY WILL NOT PRINT OR COPY. roger every thing else works fine when you use copy it takes up a pice of paper then all you get is nothing if you punch any button it says busy . every...
Hello there, I am the Expert that will be helping you today. My name is damnor01.
Welcome to Fixya.
I suggest downloading and installing the latest available drivers for your HP OfficeJet 6210 All-In-One InkJet Printer.
Click here to download and install the latest drivers for your HP OfficeJet 6210 All-In-One InkJet Printer.
Follow the instructions given by HP on their website.
You will need to select the operating system that you are using, the version of Windows that you are installing this printer on.
Remember you need a driver!
Turn OFF your computer and your printer, then power it on in a minute.
Next up is to navigate to the control panel and double click printers and faxes.
On the bottom right of the box that appears click the button that says Print Test Page.
A test page will then be printed, from this you will be able to tell if your printer is working or not.
Do you think it might be the ink is low or empty?
Tell me how it goes!
Thanking you kindly
Feb 15, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do i set time
Hi There,
Please follow the below steps to change the date and time on HP OfficeJet 6210 All-In-One InkJet Printer :
1. Press the setup button on your printer, then use the arrow down button to scroll down.
2. Look for TOOLS, then press okay.
3. Under TOOLS menu, you will have an option "DATE and TIME". press okay on that to start setting up the date and time.
Thank you.
Enjoy and Cheers !!!!
Please click the YES option to vote for me if this solution fixes your issue :)
Nov 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
My HP officejet 6210 all-in-one just stopped working. When I try to fax, copy, or scan, the process starts (i.e. menu acknowledges, hear clicking, etc) but then stalls. The green (on/off) light blinks and...
You can try Full Reset on printer
Disconnect power cord from back of printer ( while printer is on )
While holding the # and 6 button connect the cord back and release the # and 6 after 3-5 seconds..
The printer will turn off and will turn on again.. follow the Alignment process
Note : By doing this Full Reset - you may loose any Speed Dial/Group Dial entry from the printer
Also try changing the Printer Socket, Connect to walljack directly or another socket on the Surge strip.
Jun 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
The beeper on my HP Officejet 6210 All-in-one unit is on all the time on or off with power button. The only time the beeper stops is when it is unplugged from the wall outlet. I got an auto reply to try to...
I want you to try NVM (Non Volatile Memory) reset for this printer. Perform the printer is connected directly to wall outlet with now Surge protectors.
  1. Remove the ink cartridges.
  2. Disconnect the power cable from back of the printer while its ON.
  3. Press and Hold OK and CANCEL button, while holding the button insert the power cable and continue holding it for 20 seconds
  4. Printer will turn OFF.
  5. Turn ON the printer and insert cartridge when it prompts.
Jan 20, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Our HP Officejet 6210 All-in One is printing only black and white. The test page prints color blocks. Is there a setting that I can adjust?
yes when you give print command you can choose the option in printer propertis colour mode instead of grayscale.
Nov 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
6210 Stuck in self test mode
Perform the steps provided below.
  1. Unplug the power cord from the HP All-in-One.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while plugging in the power cord to the HP All-in-One.
  4. Release the buttons after the HP All-in-One starts up.
  5. The HP All-in-One will now be reset to factory defaults.
  1. Press the Power button, and turn off the HP All-in-One.
  2. Unplug the power cord from the wall outlet.
  3. Unplug the power cord from the back of the HP All-in-One.
  4. Wait for 20 seconds.
  5. Plug the power cord into the wall outlet.
  6. Press and hold # and 6 while plugging the power cord back into the HP All-in-One.
  7. Turn on the All-in-One by pressing the Power button (c01150476.jpg ).
Aug 21, 2009 | HP OfficeJet 6210 All-In-One InkJet...
HP Officejet 7410 All-in-One
Make sure the printer is connected directly to the wall outlet.
Check it again....
if you still got the same issue....
Disconnect the power cable from the back of the unit.
While the unit is off, press and hold the # and 6 keys on the keypad. While holding the keys down with your other hand connect the power cable back in. Continue to hold down the keys until the screen goes black. Press the On button to turn on the unit. Follow the on screen instruction and see if the issue is resolve.
If not then you will have to service the printer as it is a hardware issue.
May 30, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hp printer does not print out when command is issued
not specific enough, is the error on the pc or the printer?
in any case here is the manual check here for connections and trouble shooting.
Dec 06, 2007 | HP OfficeJet 6210 All-In-One InkJet...
HP OfficeJet 6210 All-In-One InkJet Printer Logo
128 people viewed this question
Ben Johnson
