Car Audio & Video Logo
Posted on Oct 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wont turn on
My amp wont turn on but when the ground cable is connected the protection light turn on.
why wont it turn on.
  • jeebs Nov 19, 2007
    i have the exact same amp and i assume the same problem in detail here it is...... the amp was working fin ...i had to take out my L7 for more trunk space so i disconnected everything properly and when i hooked it up again the amps protection light blinks red like its trying to turn on but won't and it keeps blinking until i shut off the vehicle or disconnect power, ground, etc.. is there some sort of reset button or did i some how short it out.
  • tt22 Mar 12, 2008
    my amp wont turn on and the protect light is on
Ot Tap
Level 2:
Sergeant:
Champion:
  • Expert 253 Answers
  • Posted on Jul 21, 2008
Ot Tap
Expert
Level 2:
Sergeant:
Champion:
Answers
253
Questions
16
Helped
81598
Points
641
There is a short some were check all hot wirs for any bare spots . If that is not it most likley when you installed it you blue italways hook main hot wire last.
3 Related Answers
Anonymous
  • 631 Answers
  • Posted on Oct 25, 2007
SOURCE: amplifier wont turn on.
Generally, when an amplifier goes into protection when you attempt to power it up, it means that the output transistors have failed.
Measure the DC voltage across the B+ and ground terminals as well as across remote and ground. If you have less than 11 volts when the amp tries to power up, the amp could be shutting down due to low voltage.
If the voltage remains near or above 12v, disconnect all speaker wires and signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Anonymous
  • 631 Answers
  • Posted on Jan 16, 2008
SOURCE: lightning audio B300.4 amp protect light
The most likely reason for it to go into protect is shorted output transistors.
Anonymous
  • 113 Answers
  • Posted on Aug 09, 2009
SOURCE: amp overload protection mode
it sounds like the ground is bad to begin with and check the positve cable for oxidisation on the battery terminal and at all other places that the power wire is connected to
2helpful
2answers
I have a kicker 500.2 red protection light is on and red light on top of amp flashes every couple seconds. Have checked all connections and other amp in truck works good. I bought two of these amps and...
Disconnect all the wires except the three main power wires, ground, 12v battery and remote. Now, turn on your radio, if the protect light is still on then there's an internal short in the amp. If the light turns green, then there's a short in either the auxiliary cables or the speaker outs. If it turns green, then troubleshoot the other wires that plug into the amp by connecting them one at a time until the protect light comes on, which will tell you that there's a problem with that speaker/aux wire.
My lanzar 1600 watt amp wont turn on at all why
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . .A thumbs up would be greatly appreciated if this answer is helpful to you. Might be time to invest in a new amp. lanzar-1600-watt-amp-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
2answers
I have an a8000t amp with the protection light on, is the amp broke?
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
-david
Power cap has power amp protect light is on ?
If there is a protection light then you have a bad power or ground connection. First thing I recommend you do is to get a regular test light with a ground alligator clip and test for a ground on your power cable. The way to do this is to place the alligator clip to either your amp turn on wire which is the small blue wire coming from your radio to turn the amp on or another powered wire and place the tip of the test light to the main power cable that powers the amp or the Capacitor and if your test light lights up then you have to trace the power cable from amp back to battery + terminal and see where the power cable is pinched or making a ground contact also check your blue amp turn on wire and see if it has a ground to it. If all this checks out then check your cars battery terminals, make sure they are not loose, corroded, rusty or damaged check fuses or take out amps fuses and reinsert to see if it resets, check all ground connections on amp and cap,if none of this works for you then you might have a defective cap or amp.
Good luck.
2answers
Protect
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Send to Rockford Fosgate for repair .A thumbs up would be greatly appreciated if this answer is helpful to you. protect-zb4bomd1rt4qms0dqd12kkt2-3-0.jpg
When i turn it on the green light turns red and it wont play
you should check your cabling and make sure your ground cable is connected properly to the chassis on a part where it makes contact with bare metal. your amp is going into protection mode, but its mostly caused by incorrect cabling or contact
Protection light wont go off
try checking the ground cable it migth be loose.. this happen to me once and it was a bad contact ground make sure the area is clean and tigth
1helpful
2answers
My amp stays in protection mode
Does it go into protect in the vehicle if you disconnect the speaker wires from the speaker terminals of the amp?
2answers
Amp wont turn on
New amp sounds messed up... grounds are bad and sometimes the amp tries to draw power but cant... So it immediately goes to protect... All jacked up... Audio specialist could help... Repair shop if local ..
Amplifier wont turn on.
Top Kicker Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
