Washing Machines Logo
John Hale Posted on Feb 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Elite hf error
The hf error comes on during the wash cycle and stops the machine. I have checked all of the known problems with this error, ie, cycle test, valve operation, flow meter, clean drain, and pressure switch. No fixes yet. Any suggestions?
Chas & Son's APPLIANCE REPAIR
Level 2:
Filmmaker:
Uploaded 5 video answers.
New Friend:
  • Expert 55 Answers
  • Posted on Feb 03, 2014
Expert
Level 2:
Filmmaker:
New Friend:
Answers
55
Questions
Helped
18440
Points
139
May I have the complete model number, so we can get started?
Testimonial: "110.45081 400"
  • 1 more comment
  • John Hale Feb 03, 2014
    Model 110.45081 400
  • John Hale Feb 04, 2014
    Hello, anybody there to answer this problem????
  • That is not the model number right there.
3 Related Answers
Anonymous
  • 125 Answers
  • Posted on Jan 21, 2008
SOURCE: kenmore elite oasis he top loader
Is it an f code followed by a 51?
aborcass
Ron Coons
  • 2651 Answers
  • Posted on Mar 10, 2008
SOURCE: Leaking Kenmore elite he3 washing machine
removethe lower acess panel 3 screws across the bottom , run the cycle and watch to see where exctly the leak is coming from it should be quite apparent
Anonymous
  • 193 Answers
  • Posted on Nov 04, 2009
SOURCE: Kenmore Elite front load washer stops and blinks F35 and locks up
f35 code indicates a pressure switch problem. Try unplugging unit for 2 minutes.Plug back in and test.If F35 reappears,check hose from tub to pressure switch
Kenmore HE3t Washer - code HF running diagnostic cycle yields no water and C:01 what part to replace?
Possible discussion of HF but it may not be your Kenmore Washer. You can use the Comment menu to reply or add more information to your question.
https://www.shopyourway.com/questions/1010755
https://www.hunker.com/12001541/how-to-reset-the-fh-error-code-on-a-kenmore-elite-washing-machine
https://www.ifixit.com/Answers/View/354215/What+does+H+F+mean
Kenmore elite washer
hi
unfortunately the programmer is faulty
1helpful
Kenmore elite he3 washer F02 error during wash cycle
You need to check for a blockage, F02 code indicates -- Drain blocked, kinked, drain filter plugged, or drain pipe exits too far above the washer.
Runs fine but will not engage the spin cycle to remove water. the drum rotates but not at any great speed.
Have you solved your problem? My Kenmore Elite Quietpak2 gives me an error message HF on every wash cycle. Will not complete a full wash. Help please.
Kenmore HE4T washer won't rinse. Valves open to
An HF Code is a Water Inlet Problem- No or Insufficient Water Supply.
Press Pause/Cancel twice to cancel the cycle. Then, unplug the washer.
Run down the list again:
Make sure faucets are completely turned on.
Make sure the fill vavles (screens where water enter machine) aren't clogged.
Make sure the hoses aren't kinked, etc.
Plug the machine back in. Try another cycle. If the problem still occurs, You may need to replace your Water Fill Valve. Let me know if you need any further assistance.
17helpful
Kenmore Elite He3t front load washer - error code reads H & F
the F code is a puwer outige. This is how to fix
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN & SPIN if there is excessive water in the washer.
Re-select cycle and press START. If the problem remains, call
for service.
This is what an HF code is.
"FH" (Water Inlet Problem--no water or insufficient water
supply)
Select PAUSE/CANCEL twice to cancel the cycle. Unplug
washer or disconnect power.
Check the following:
Are water faucets completely turned on?
Are screens at inlet hose connection to washer clogged?
Are water inlet hoses kinked?
Are water inlet hoses frozen?
Plug in washer or reconnect power. Re-select cycle and press
START. If the problem remains, call for service.
Kenmore Elite HE3t
Here's a link that explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
Read through these steps and let me know if you require further assistance. HINT: I'm assuming you have water entering the wash tub since you mentioned the washer will begin a wash cycle. Check for a siphoning issue or Drain Pump problem first. These are the simplest items to check. I hope this helps you.
PS There should be a tech sheet located inside you washer behind the lower panel under the door, or along the interior cabinet wall that explains all the error codes and how to troubleshoot. This may also assist you further.
1helpful
2answers
HF signal code
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Height of exit hose should be approx 3 feet from ground level.
Rate me pl.....if helped.
Kenmore elite front load washer
look for an error code on those washer it will be and f-02 something like that or HF FH it will have an f keep an eye out for that
Alexander
vince
