Question about RCA HDLP50W151 50" Rear Projection HDTV
No picture my 50 rca dlp rear projection has no picture or sound, power light blinks 5 times, replaced lamp, still no pic, tv is 1 year old...help
  • 3 more comments
  • firebyrd Nov 28, 2007
    I have the same problem. I tried to Ohm my bulb out but it is fine. I suspect the color wheel.. have you fixed yours yet?
  • garret Dec 04, 2007
    Same problem. Replaced lamp still blinks 5 times then shuts off. Any solutions yet ?
  • Anonymous Jan 08, 2008
    same problem. it just happened and i haven't done anything yet. i turn it on, it has no picture or sound, and the power button blinks, what do i do!!!!!
  • Anonymous Nov 19, 2008
    same problem replaced lamp was working for a minute and then countinued to make noise and coler changing then the tv eventually goes blank
  • sunny947 Dec 13, 2008
    My set is only 14 months old and I have the same problem. Replaced the lamp and work for about 2 months and out again. Replaced with new lamp and sound comes on for only about 5 seconds, but no picture ever appears. Is there a reset button or anything on these tvs?
  • 3 Answers
Sounds like it could be the entire light engine.  The part is available on the Internet, but it runs $700 - $1200 without the lamp (although it sounds like you could use your existing lamp without a problem). These parts, however, are notoriously hard to find and may be backordered for months.
May not be worth the cost, but that's up to you.
Posted on Jan 08, 2008
Cable hooked up right...turned on this morning sound no pic
Ur tv been in use at least 1 1/2 or 2 years.On about 4 or 5 hours a day on this tv?The LED light indicator "LAMP" flashes?The projection bulb life is over.Require a new bulb.
May 27, 2010 | Samsung DLP HL-P4663W 46" Rear Projection...
Replace lamp on 50' rca dlp and still no working.
Before replacing the Ballast I would look at the power-supply and see if you notice any of the electrolytic capacitors tops being bubbled. It is not uncommon for the capacitors to go bad as the lamp draws more current as it ages and fails. If you do see capacity's bubbled, Replace them or have them replaced and the set will probably work fine afterwards.
Hope this helps,
Skyassoc
Jun 28, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
Lamp light no pic
yes yes yes.the lamp needs replacement. you are very correct.that is the indication of lasmp replacement which your tv is signalling.replace it quickly.
howto replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Dlp 50 inch
sounds like the DM3 isnt powering up the ballast to light the lamp or the ballast may be faulty. i would suggest trouble shooting the DM and ballast voltages.
May 28, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HD50LPW175 50 in. HDTV Television
Yes I should be able to help you figure it out. First look on the rear of the set to check what the chassis number is. Should be an ATC 336 but it might be a ATC323 let me know the chassis number and we can go from there on diagnosing the problem
Feb 15, 2008 | Televison & Video
Rca 50 dlp hd50lpw175
Yes but did you find a fuse open and changed it?
Jan 08, 2008 | Televison & Video
DLP Powering Off after 5 minutes
Chances are the cooling fan for the lamp is bad, or the temp sensor for the lamp might be defective.
Jan 04, 2008 | Panasonic PT-50DL54 50" Rear Projection...
RCA HDLP50W151 50" Rear Projection HDTV Logo
350 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
