Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
Can't detect my HD properly
I own a Transcend StoreJet 2.5 . I was happy with it untill one fine day as usual I plugged the USB drive to my laptop & while scanning for files it shows an error message saying "$MSft"(or similar file) got corrupted. After than I pressed ok. And since then any computer/laptop doesn't recognise my USB drive. I can see the drive letter (e:\ assigned for it, but when I look at its properties it says 0 bytes used space & 0 bytes unused space. But when I see the status of the device, it always gives me device working properly. I tried uninstalling & reinstalling the drivers. But still no use. Can somebody please help me.
  • 1 more comment
  • gauravgps Mar 05, 2008
    The driver given with storejet 2.5 portable HDD supports Windows 98 and is not getting installed in windows xp. The HDD is recognised as a usb device and nothing more. It is not accessible due to No Drivers. Please give the driver for windows xp.
  • ChandU32 Aug 27, 2008
    Hi this is Chandu..I had transcend Store Jet 2.5series...i got a problem in opening the hard disk...In my laptop it is detected and showing the drive in My Computer..But when Iam trying to open the drive it is showing the error message like Didk drive is not accessible..The wrong diskette is in the drive..Insert (Volume Serial No:) into drive :..What is the solution for this....
  • Anonymous Jan 19, 2009
    I have the same hard drive on windows xp but xp doesn't even recogniseit when i plug it into my usb port. I tried on every other USB port available, and every single combination, but still no success.
  • 1,006 Answers
Possibilities:
1) One of your USB devices have faulted, or is causing a resource conflict (or similar)
-- Remove all USB devices, and reboot.
2) Your USB chip/ports have been damaged.
-- Find a spare HardDisk or bacjup your data and re-install Windows and see how that goes.
3) Your Power Supply Unit (PSU) isnt supplying enough power to your PC (usually caused by a Video card upgrade). Try a more powerful PSU ... 400watts should do the trick
4) Bad memory (RAM) can cause wierd problems. run memtest for an hour to make sure your memory is ok
It seems that many people are still getting the 'USB Device not Recognized' problem from time to time. Unfortunately there is no easy fix.
Firstly, it's recommended that you make sure every one of your motherboard drivers are completely up-to-date, but you probably already knew that.
In XP, after a USB port isn't used for a long while the USB driver built into the OS sets the OHCI controller to suspend. When you plug a device back in, it can sometimes fail to 'wake up' properly. This problem was supposedly fixed in SP1 but there is a related registry hack that may still be able to help.
Run regedt32.exe and navigate to;
HKEY_LOCAL_Machine\SYSTEM\CurrentControlSet\Services\Usb
Create the Usb key if it doesn't already exist. Under this key, create a new DWORD value called DisableSelectiveSuspend and give it a value of 1. Then restart the PC.
A long shot perhaps, but I recall having similar problems with a USB hub built into my Microsoft keyboard and adding this key seemed to solve it. It wouldn't hurt in trying .
Alternatively, removing all entries relating to USB in Device Manager and all associated USB drivers will force XP into refreshing the USB driver stack.
Begin by unplugging all USB devices, then use Add/Remove Programs in Control Panel to uninstall any USB driver software. Next, boot up into safe mode and go to Device Manager. Once in device manager make sure 'Show hidden devices' is checked under the View menu. Uninstall all device entries in this order;
1. USB peripheral devices (printers etc.)
2. HID and/or Composite USB (Human Interface Devices) You're using PS/2 input devices so you may not have this entry.
3. USB Root Hub(s)
4. USB Host Controller(s) (Universal or Enhanced Host Controllers)
Then boot back into Windows (not safe mode) and it should populate the Root Hubs & Host controllers again. Proceed to plug your USB devices back in, starting with your powered hub. Be aware that most USB printers and scanners need to have their drivers installed first before you plug them in.
Hopefully some of this may be of help, let us know how you get on.
Posted on Oct 26, 2007
MY PC WINDOWS XP ASKS TO FORMAT MY STOREJET 25 320 GB TRANSCEND PORTABLE HARD DRIVE
If it's asking to be formatted you need data recovery help. For remote data recovery and do-it-yourself data recovery see http://FreeDataRecovery.us
Sep 04, 2012 | Transcend StoreJet 25 Mobile - Hard drive...
My transcend storejet 25m2 does not detect my xp sp 2 pc what the **** i can do
Good day..!!Try to check at the disk management,then change drive path or mount,then ist already detected in my computer..thanks
Aug 17, 2011 | Transcend StoreJet 25 Mobile 500GB USB 20...
Describe your Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Problem
I have Problem with the Transcend StoreJet 2.5 120 GB USB 2.0 Hard Drive.
I didnot register it on line.in time i was presented this nice device..
because it was working ok .when i just connect it to LapTop.
NOW..After almost 2 years .it s became not RECOGNISED BY MY pc.
And i cant find any driver for it.I have all my important documents in Transcend.
WHat can i do.friends.. Any help?
Please help old Lady.
Thanks if responded.
dearme9@yahoo.com is my mail and this is banner i see.
Jul 26, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
My laptop XP is not detecting Transcend StoreJet 25 External HD 500GB, but in desktop XP it is very well detecting and working. Pls let me know the solution for my laptop
USB devices draw electrical power through the USB cable.
Sometimes, the power-output from a USB port on a laptop is _less_ than that of a USB port on a desktop computer.
Hence, there are "Y" cables -- connect to two USB ports on your computer, and to the USB device at the other end, to draw more current.
Which manufacturer of laptop?
Which model-number?
Which Operating System?
Do other USB devices work when connected to the laptop's USB ports?
Nov 09, 2010 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Hdd not detecting
are you able to see the hd detected in the storage section of the bios setup?
try scanning for new hardware changes in the device manager
else try connecting the hd in some other system and try if it is getting detected in that...
Aug 31, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend external hard drive not working.
Contact Transcend Support:
support@transcendusa.com
Jun 09, 2008 | Transcend Computers & Internet
StoreJet 2.5 Spinning properly(sounds) but not detected
try the drive in a new case. if that dosent work the drive is dead.
May 07, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
1,274 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
John Porter
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
