Question about Dishwashers
Door assembly, Jenn-Air (Maytag) dishwasher
The "soft drop door" on my Jenn-Air (Maytag) dishwasher, model # JDB6510AWP, has stopped working.  The components managed to disassemble themselves and now the door just drops open.  All the parts appear to still be there.  When I tried to fix it I couldn't figure out where the cable and spring attach.  It seems to loop around a plastic wheel that is part of the soft drop mechanism, but I can't figure out where the ends of the cable and spring attach.  I found a parts diagram online, but not an assembly diagram.
Any help is appreciated.
  • 473 Answers
SOURCE: Icemaker flap/door does not mechanically open
The description says you have an LG fridge?  I may need the entire model # from the sticker inside the fridge to tell for sure, but there is a motor behind the dispenser controls that opens the door.  Let me know if you need more help.  Also, you can view parts and diagrams at
Posted on Oct 21, 2007
  • 1314 Answers
SOURCE: Ice Maker does not open rubber flap in door to let ice out........
need your model numbers
Posted on Dec 31, 2007
  • 145 Answers
SOURCE: Whirlpool refrigerator ice dispenser
The front cover is snapped on. There should be two slots in the bottom of the cover. Put a wide screw driver in the slots one at a time and pry out. It snaps off very hard.
Posted on Apr 24, 2008
SOURCE: Jenn-Air Glass Door - How to Clean
Sounds familiar. I saw this thread this afternoon while trying to clean my own oven window. My sense is it is definitely a design flaw. It's just too easy to drip something down the top door vents onto the inside of the multiple glass panes.
Here's what I did. I removed the door, following the manual instructions. Open the door to 1/4 and lift it up. Then I put it down on a soft surface and started removing screws until it came apart. It wasn't too complicated though it took some time. Be sure to keep track of your screws as you do this as there are a few different kinds.
Posted on Aug 12, 2008
SOURCE: kelvinator Opal CS 390 F door has dropped down on handle side.
My sister has the same fridge model. We've removed the door and the bottom bracket supporting the hinge had collapsed up inside the door. We're going to cut out a piece of steel (3-4mm thick) and glue it along the bottom of the door in order for the door hinge to insert into something solid. Looks like it's a weak point in the door construction. Pity Kelvinator wouldn't acknowledge the problem and come up with a solution (other than replacing the door at $340 - which is what we were quoted).
Posted on Nov 08, 2009
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Jenn-Air dishwasher, model JDB6510AWP dishwasher won't turn on
Hello, sport
I was trying to help you out here. I was going back to some customers that asked questions in the past and it appeared that no one answered them, so I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your dishwasher, from repair to trouble shooting it,pictures, video's. Just scroll around and you will see tons of information to almost any question you might have on your dishwasher. If you go to this link and click around, I am sure you will find out so much about your dishwasher, you will know more that the company that made it. Here Is the link for you to click on>>
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
Sep 09, 2011 | Jenn-Air JDB6510 Built-in Dishwasher
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Broke Glass door for Jenn-Air 701642K
Hi, Go to and tyoe in the model # located on a tag either around the door opening or around the bottom drawer.
I hope this helps you.
Jul 11, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Soft drop door mechanism came undone The soft drop door tub wheel
It's held in place by a soft drop nut (99002192). If damaged, the tub wheel part number is (99002183), and the soft drop bolt is (99002189).
May 02, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
The reason why i asked you for the make and model no. was that the rinse aid dispenser was actually banned on many older dishwashers because of a fire hazard.As far as the dispenser, try using bleach, not too much, 1/2 cup and run with out dish washing soap. it should work.
Sep 13, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Jenn-Air (Maytag) Dishwasher Leaves Film on Everything
Make sure you are using rinse aid like jet dry. All newwer dishwasher are made to only work properly with this in it.
Apr 23, 2008 | Jenn-Air 24 in. JDB1080AWS Built-in...
Won'r run unless I push the door
Probably a broken latch assembly.. UNPLUG UNIT!! Remove inner door panel to access. Also check for broken tabs on onside of console where latch assembly rests.
Nov 16, 2007 | Jenn-Air 24 in. JDB6900 Built-in...
Dishwashers Logo
87 people viewed this question
Top Dishwashers Experts
