ASUS P5GC-MX/1333 - Motherboard - micro ATX - i945GC - LGA775 Socket - UDMA100, Serial ATA-300 - Eth... Logo
A
Anonymous Posted on Feb 03, 2014
ASUS P5GC-MX/1333 - Motherboard compatible with ddr3 graphics card
ASUS P5GC-MX/1333 compatible with ddr3 graphics card
4 Related Answers
Anonymous
  • 548 Answers
  • Posted on Mar 27, 2010
SOURCE: COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS
Yes you can put a 1 gb card. The motherboard has PCI Express so you don't have to worry to much. The older AGP cards are almost gone.
You could buy a GeForce 8500, 8600, or 8800, or the 9 series. You can also buy a Radeon HD 5870 or 5570.
If you need further assistance, please post. And do not forget to rate.
Thank you for using FixYa
RAHUL715094
  • Posted on Oct 28, 2010
SOURCE: What could be the recommended
Anonymous
  • 1027 Answers
  • Posted on Mar 08, 2011
SOURCE: what is the best nvidia 1gb graphics card within
Yes, if is a PCI-E video card.
ghost2233
Hans Pedersen
  • 3606 Answers
  • Posted on Nov 15, 2012
SOURCE: COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS MOTHERBOARD.
Hello you can read the spec.here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GCMX1333/#specifications
Your mainboard uses PCI-E socket this is the new standard for graphic cards.
Your local computerdealer can advice you a good graphic card
but it depends what you have to use it fore.
If you use the pc to seach at the internet a cheap card will be great
but if you use the pc for games you might have to spend 200 dollars.
Good luck
Testimonial: "Thank you..I'll try for sure>>>:) "
2helpful
Good luck
1helpful
Is a 2gb video card compatible with ASUS P5GC-MX/1333?? Also what is the max ram size the motherboard can take???
The motherboard's max memory supported is 4GB. The 2GB part of the video card is not really what decides if it is compatible or not; it is the interface of the video card. The motherboard in question has slots for PCI Expressx16 and PCI Expressx1.
Details of the motherboard
P5GC-MX/1333 Will my GeForce GT430 2GB 128-bit DDR3 work?
Hi, you can download a manual
and drivers here for the mainboard:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GCMX1333/#download
Please select your operating system.
Select manual and click on global for download.
Unzip the file before installation.
You can use the graphic card as long it is for
socket PCI-E.
You can download the latest graphic drivers here:
http://www.nvidia.com/object/product-geforce-gt-430-us.html
1helpful
I VE purchased N-Vidia GE Force 210 series(1GB) graphics card . I ve got ASUS P5G-MX motherboard on my pc. is it compatible? Please reply
Yes the graphics card is compatible as it is a PCI Express card and the motherboard has a PCI Express slot.
Install the card and enjoy.
Regards.
21helpful
4answers
COMPATIBLE GRAPHICS CARD WITH P5GC MX/1333 ASUS MOTHERBOARD. Whether 1 gb card can be fitted
1helpful
Mobo Compatibility and tech/spec variations
All Asus P5GC-MX/1333 mobos are "X-series" boards.
If you put higher speed ram on that mobo, it will just run the ram at lower speeds.
The board will not take 1333 speed DDR3, because it is only DDR2 compatible.
OVerclocking is complicated and risky, here is neither the place to teach or learn overclocking.
Some newer core 2 chips will automatically overclock, when all but 1 core is in hibernation (which will never happen if you are using vista). Other than that overclocking involves setting the bios to increase the memory buss speed, as well as slightly increasing the cpu and ram voltages as needed for stability. There is a great risk associated with manually overclocking and adjusting voltages, and should not be attempted by beginners on machines they value.
1helpful
P5GC-MX/1333 cannot support recovery card?
I have installed win XP I have problem loading realtek HD audio driver
my MOTHERBOARD is P5GC-MX/1333
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
