Is there an adjustment for pincushion?
The problem I am having is a slight pincushion. The top and bottom of the screen are stretched, the center is normal. The sides are not dark, it does not look like an hour glass, so I am not sure if this is a true pincushion or not. My computer monitor has a front panel adjustment for this problem, as well as several other common picture problems. Does a television have the same type of internal adjustment or is it more of a component problem?
  • Anonymous Aug 09, 2008
    The Picture looks like an hour glass
    Normal in the middle but streched out top and bottom
  • friend helpe Aug 12, 2008
    I have an hourglass picture that the center is 1/2 the width of the top and bottom.. manufacturers used to have a menu code to get into adjustments like this... does Toshiba have this ? if so I need it
    thanks
  • 93 Answers
CHECK THE CAPACITOR IN THE PINCUSHION SECTION OF THE TV MAIN BOARD
Posted on Oct 25, 2007
Samsung TSL2793HF - Slight Right Side Pincushion and Horz Line Bottom to Top Until the TV Warms up
Yes, this is rare but I have seen it before--not fixable if it is what I think it is----It is what is called a Dome effect---the shadow mask in the picture tube is actually contracting and or expanding depending on temperature---
Directly behind the phosphor coating (the stripes that you see on the screen) is a metal screen--the holes or perforations in it line up with the stripes on the phosphor screen.
Some masks either have a material or a defect causing the dome effect----Not likely to be anything else---a Pin amp problem will not usually act the way you describe but a shadow mask inside the picture tube will act exactly that way.
Dec 02, 2012 | Televison & Video
My screen is stretched
Try adjusting your resolution or resetting your monitor.
May 22, 2012 | Compaq Computers & Internet
Ws55809...curve at top and bottom of screen
You should have some adjustment for Kine bias and pincushioning. Look for these in settings and readjust the screen
Mar 02, 2010 | Mitsubishi WS-55807 TV
Big Screen Projection receiver TV vertical pincushion problem
the aliment is out need a profession to adjust it for you
Jul 24, 2009 | Televison & Video
My screen is stretched with a 1 and ahalf inch black space on the top and bottom
Most LCD monitors have a couple of control buttons at the top or on the side. Inside the menu, there should be an option called "Auto Adjust" which senses the input signal and resolution, and then shifts the monitor to match it. Have you tried to auto-adjust the screen? There may even be a button called "Auto" on the monitor.
May 13, 2009 | Computers & Internet
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Monitor resolution
Sounds like either the trapazoidal is off or the pincushion is set improperly. You should be able to find those settings via the monitors onboard menu. Either one can create such a problem.
You might also check into finding the factory defaults selection. This will reset all of the resolutions and refresh rate settings.
When you adjust your screen follow these steps in order...
Pincushion : Makes the screen look like ( ) or ) (
Trapazoidal : Makes the screen look like / \ or \ /
Horizontal : Basically stretches the screen wider or skinnier to fit the monitor
Vertical : Basically the same as Horizontal, only with the up and down properties
Contrast / Brightness : Use this to find the perfect white and blacks
Color : Finish your setup with adjusting to the perfect color.
This way you can always have your monitor set like you want it.
Sep 12, 2008 | Gateway FPD2275W LCD Monitor
Convergence Problem
have you checked the resistance of the pico fuse
Sep 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hourglass shape on screen
you might tyr adjusting the eprom setting to correct the e/w pincushion fault,or call for service to adjust.
Nov 06, 2007 | RCA 32F531T 32" TV
Pincushion Problems
check the cap that couple the horizontal transistor, this could be bad replace the flyback.all caps and transistors in that circuit should be cheked.good luck.
Apr 03, 2007 | Proscan PS27108 TV
Televison & Video Logo
741 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
