Question about Sony Ericsson T610
Will not charge at all
Phone will not charge when plugged into either car charger or regular charger, no response at all.  My other SE phone works fine with either charger. Is it old, too damaged (dropped a few times), battery problems?
  • 1 more comment
  • SolarGraham Oct 27, 2007
    I was able to find a great page that detailed how to disassemble my T610 and clean the connectors between the circuit board and plug receptor.  With an eraser I cleaned the contacts and I even dusted the LCD too. All good, it charges with out hiccup.
  • SomeGirl Nov 05, 2007
    Same issue.
    Could you give a link to the webpage that helped you disassemble the phone?
    TIA
  • Anonymous Aug 19, 2008
    not charging at all
  • 38 Answers
Will the unit power off the two adapters. Ie when you remove the battery will it still power up? If it doesn't you have a bad charge jack. If it does you have a bad battery.
Posted on Oct 25, 2007
My phone stopped charging and it wont work where the charger part is.
get a new charger..if it dont work..your plug on your cell needs repair
Jan 08, 2014 | Nokia Lumia 820
My phone SE T303 ran out of battery so i plugged it in to charge, the red light came on. When I came to turn the phone on it didn't work. so i plugged in the charger without the battery inside, then put...
short answer is your battery is dead and needs to be replaced. It is hoped you didn't short out the charging port within the phone itself... It is doubtful but can happen..
Jun 02, 2017 | Sony Ericsson T303 Mobile Phone (Shadow...
Galaxy Note slow charge. Holds battery well though.
try this ..get a qtip and dip in 99% rubbing alcohol. not too wet. just damp. clean contacts on the charger port. use a magnifying glass and light to check if its clean. let it dry for 20 mins. it will also help if you have airplane mode on but its optional. use oem charger and cable or ipad charger works fine with samsung cable. hope it helps
Jun 10, 2017 | Samsung SGH-i717 Galaxy Note HD LTE 16GB...
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
Wont charge
Try a car charger. If the car charger works, then it is either
A) Your power outlet
B) Your wall charger Power Supply unit
C) The phone connector on your wall charger.
If it doesn't work on the car charger, then it is most likely your phone charging system or the connection for charging on your phone. Either way, you will most likely need a new phone. Sorry.
Sep 23, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Phone won't charge
check charger pins and charger socket and its contacts and the fue in the board. if anyone fails in this charger wont work.
Feb 06, 2009 | Sony Ericsson W660i Mobile Phone
Motorola v3 car charger
check your cigarette lighter, it may have a blown fuse , check to make sure its not the problem.
Oct 14, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Cell phone not responding to charger
This is not a fix per se, but if you feel it gets you a rock solid answer go ahead and rate it otherwise, please don't bother to rate this. I'm just giving your some guideance.
You phone in question needs replacement as there is a clear malfunction. You can call your provider or go to the phone store. You shouldn't have any problem having it replaced. They may even offer to upgrade you to a Razor or some such higher end model if its better than yours.
Best Regards,
Worldvet
Jun 17, 2008 | Samsung Cell Phones
The following
Hi how old is the charger often the wires inside the charge fray and short either try somebody elses charger or try you charger on someone elses phone if the charger is working ok then it could either be that the battery needs replacing or that the board is warped on the phone first of all i would try someone elses charger this way you kno the charger is working or not let me know how you get on ok
Dec 01, 2007 | Nokia N73 Cellular Phone
Sony Ericsson T610 Logo
37 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
