posted by dwcrist on Oct 25, 2007
I'd like to shorten the 54 inch shaft. Is this possible?? And is it a complicated job if it can be done?? thank you
Best Solution
posted on Oct 25, 2007
It is not recommended to cut the transducer cables as they are sensitive to outside interference. Most trolling motors have adjustable shafts so you can set it at the depth you want. Look for a locking mechanism where the shaft attaches to the mounting bracket.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Minn Kota 55 AutoPilot 54" Universal
Email this problem
Email this problem
Can you Help with these GPS Devices problems?
Minn Kota 55 AutoPilot 54" Universal Sonar...
my motor had smoke exerted
my motor had smoke exerted from... Answer This...
I have a corded foot
I have a corded foot pedal that... Answer This...
Broken composit carbon shaft on
Broken composit carbon shaft on... Answer This...
Minn Kota lower unit leaking.
Minn Kota lower unit leaking. ... Answer This...
Repair Service
Find GPS Device Repairman Near You:
