Question about Toshiba Satellite A15-S157 Notebook
Problem with Toshiba
When I turn on my laptop it says "Insert system disk in drive Press any key when ready" It is on the command prompt and wont even start up to windows it will stay on that command promp..Help..
CGF
it is a Toshiba PAS259U-C  i couldnt find it on the product list so i just picked something
  • 1,006 Answers
Just buy new hdd sir or check the cable or jumper
Posted on Oct 26, 2007
Maxdata pro 5000 ir
There are many good reasons for booting your computer from a USB drive.
For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer.
However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on.
Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware.
The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor.
The POST only lasts a few seconds; therefore, press the "Delete" key quickly.
Enter the administrative BIOS password if prompted to do so.
Once you enter the correct password, you will see the main BIOS screen.
Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key.
Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option.
Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option.
Press the "F10" key to save changes and exit the BIOS setup program.
When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive.
Award or Phoenix BIOS
Connect the USB drive to the computer.
Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS.
Enter the BIOS password if prompted to do so.
Tap the right-arrow key until the cursor is over the "BOOT" menu option.
Press the "Enter" key.
Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list.
Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility.
After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
1. Insert your USB (4GB+ preferable) stick to the system and backup all the data from the USB as we are going to format the USB to make it as bootable.
2. Open elevated Command Prompt. To do this, type in CMD in Start menu search field and hit Ctrl + Shift + Enter. Alternatively, navigate to Start > All programs >Accessories > right click on Command Prompt and select run as administrator.
3. When the Command Prompt opens, enter the following command:
DISKPART and hit enter.
LIST DISK and hit enter.
Once you enter the LIST DISK command, it will show the disk number of your USB drive. In the below image my USB drive disk no is Disk 1.
4. In this step you need to enter all the below commands one by one and hit enter. As these commands are self explanatory, you can easily guess what these commands do.
SELECT DISK 1 (Replace DISK 1 with your disk number)
CLEAN
CREATE PARTITION PRIMARY
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
(Format process may take few seconds)
ASSIGN
EXIT
Don't close the command prompt as we need to execute one more command at the next step. Just minimize it.
5. Insert your Windows DVD in the optical drive and note down the drive letter of the optical drive and USB media. Here I use "D" as my optical (DVD) drive letter and "H" as my USB drive letter.
6. Go back to command prompt and execute the following commands:
D:CD BOOT and hit enter. Where "D" is your DVD drive letter.
CD BOOT and hit enter to see the below message.
BOOTSECT.EXE/NT60 H:
(Where "H" is your USB drive letter)
7. Copy Windows DVD contents to USB.
You are done with your bootable USB. You can now use this bootable USB as bootable DVD on any computer that comes with USB boot feature (most of the current motherboards support this feature).
Note that this bootable USB guide will not work if you are trying to make a bootable USB on XP computer.
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/
boot from a usb drive
Jun 22, 2013 | Computers & Internet
How to boot from usb flash drive
There are many good reasons for booting your computer from a USB drive. For instance, if you want to try out another operating system without disturbing the main hard drive on your computer, then installing the new OS on an external drive is a great way to run the system through its paces and decide whether you like it.
This approach will offer you the flexibility of being able to run both operating systems on your computer. However, before you can boot the new operating system from the USB drive, you will need to change the boot order for your computer in the system BIOS.
Connect the external USB drive or pen drive to the computer before you power it on. Press the "Delete" key as the computer performs the "Power On Self Test" (POST) to enter the BIOS area of the computer firmware. The POST performs a diagnostic of components on the motherboard and does a cursory check of the hard drive, memory and processor. The POST only lasts a few seconds; therefore, press the "Delete" key quickly. Enter the administrative BIOS password if prompted to do so. Once you enter the correct password, you will see the main BIOS screen. Use the right-arrow key to navigate to the "BOOT" menu option at the top of the screen, and press the "Enter" key. Press the down-arrow key until the cursor is on the "Boot Device Priority" label. Hit "Enter," and press the down-arrow key again to highlight the "1st Boot Device" option. Press the "+" or "-" keys to scroll through the available boot options until the "USB Drive" or "USB-HDD0" label is the highlighted option. Press the "F10" key to save changes and exit the BIOS setup program. When the computer restarts, wait for the "press any key to boot from external drive" prompt to display, and then press any key on the keyboard to boot from the USB drive. Award or Phoenix BIOS Connect the USB drive to the computer. Wait for the POST to display on the screen, and press the "Delete" key to enter the BIOS. Enter the BIOS password if prompted to do so. Tap the right-arrow key until the cursor is over the "BOOT" menu option. Press the "Enter" key. Press the down-arrow key until the highlighted cursor is on the "Removable Devices" option. Press the "+" key until the "Removable Devices" label is on the top of the boot device list. Press the "F10" key to save the changes for the boot order in the BIOS and to exit the utility. After the computer restarts, press any key on the keyboard to boot from the USB drive when prompted to do so.
also
Bootable USB guide, here we assume that you are using either Vista or Windows 7 to create a bootable USB.
CLEAN
SELECT PARTITION 1
ACTIVE
FORMAT FS=NTFS
ASSIGN
EXIT
http://www.howtogeek.com/howto/16822/boot-from-a-usb-drive-even-if-your-bios-wont-let-you/ boot from a usb drive
Apr 16, 2013 | HP s3700y PC Desktop
I need to reset my laptop
Hello, here are the steps to resetting your computer.
Reinstall Windows from a Disk
1 Turn on your Toshiba Satellite. Insert your recovery disk or the original Windows operating system DVD
into the Satellite's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba Satellite. In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba 173" Satellite L555S7008 Intel...
My hard drive burnt out. The hard drive test says failed and the operating system won't boot. I placed a leftover hard drive from my Playstation 3 into the laptop and now it says no operating system found....
Try the recovery console from a windows xp recovery/install disk:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
1.Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select the operating system you want to repair (you may have only one option).
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation. From here I would try "chkdsk /r" and "fixboot"
For a list of commands that are available in Recovery Console, type recovery console commands or help at the command prompt, and then press ENTER.
For information about a specific command, type help commandname at the command prompt, and then press ENTER.
6.To exit the Recovery Console and restart the computer, type exit at the command prompt, and then press ENTER.
Once you've done this restart the computer and see if it boots up.
Apr 08, 2010 | HP Compaq Presario V6000T PC Notebook
My t43 won't start up windows. Freezes on ibm logo screen
People need to understand that you can't even get to the windows bootup if it freezes at this screen. Honestly if you have never dealt with this SPECIFIC issue then please don't answer. From what I have seen so far, you need to remove the HDD, reboot, enter the BIOS, reset it to optimal config, power off, reseat your HDD, then power back on. Seems to be a issue with the HDD itself. I had 6 of these laptops with the same issue and it is hardware based and has NOTHING to do with Windows.
Apr 06, 2010 | IBM ThinkPad T43 Notebook
My toshiba L500 wont boot up when i turn it on it starts to load files then stops and tries to repair the problem but it does not
There are so many reasons boot up; i.e if system files corrupted by virus or hard disk index tables corruption or hdd partions corruption.
So as a initial trouble shooting try to do following things to resolve problem.
Option 1:
1. Power ON your computer and Press F8 key to have Windows boot menu option
2. Select "Safe Mode with Command Prompt" and Press Enter
3. When command prompt loaded then type follwing command and press enter
chkdsk /r c:
(If this command is not working in "safe mode with command prompt" then start computer with Bootable CD and Press "R" key when first time asked. It will open recovery console and type this "chkdsk /r "command again to repair disk.)
This command will scan your hdd and repair disk errors.
Option 2 :
To repair your windows without losing your data.
Start Computer with bootable CD
Press R when it is asked to press.
It will repair windows.
Note : Please read Status Bar and screen messages /nstructions carfully (while Booting computer thru Bootable CD)
Mar 28, 2010 | Toshiba Satellite L505ES5015 NoteBook
How to install window XP on CQ40 laptop .
check your boot setting first in the cmos/bios of your laptop, look for the boot order from there choose your cd/dvd rom as your first boot device then the hard drive 2nd, you will need to this because in order for you to install xp, when you are done save the setting that you have made then restart the machine, insert your windows installation disc, it will prompt you to press any key to boot from the cd rom, from it will check you system config, then just follow the instruction given to you by the installation process read it carefully then it will be easy as 123, windows will guide you thru the installation process and will ask you for the lincense key, just make sure that you use a genuine copy of window if not you wont be able to register your o.s and you wont get the updates from windows
Nov 26, 2009 | Compaq Presario Notebook
I have a toshiba laptop 1996 and it keeps saying insert system disk in drive pree any key when ready
it needs inf from os disk (xp )
so insert your windows disk and press any key.if you do not have a windows disk borrow a friends it doesnt matter whose disk you use as long as you have a valid cd key.
Jan 23, 2009 | Computers & Internet
Satelite laptop (toshiba)
make sure that there is no cd or floppy disk in the drive and try again
Nov 21, 2008 | Toshiba Satellite A100-S8111TD Notebook
HELP!!
Buy new hdd sir it is CAPUT;)
Oct 25, 2007 | Toshiba Satellite A60 Notebook
Toshiba Satellite A15-S157 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
