Computers & Internet Logo
b
busakailash0 Posted on Feb 03, 2014
Choose any six out of 7 part of internal technology framework
melvinchunter
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 05, 2014
melvinchunter
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
200
Points
The 7 factors as per the framework can be defined as follows:
  1. Strategy: It is defined as an action plan working towards the organizational defined objective.
  2. Structure: It is defined as design of organization-employees interaction to meet defined objective.
  3. Systems: It is defined as information systems in which organization has invested to fulfill its defined objective.
  4. Staff: It is defined as workers employed by the organization.
  5. Style: It is defined as the approach adopted by the leadership to interact with employees, supplier and customers.
  6. Skills: It is defined as characteristics of employees associated with the organization.
  7. Shared Values: It is the central piece of the whole 7S framework. It is a concept based on which organization has decided to achieve its objective.
Here 7 factors are used for internal technologies.Have you heard about new personal networking gadget package.It is a wonderful technology.That is made in simple pen style model. Latest Pen Style Technology for Personal Networking Gadget Package
tip
Microsoft Framework Error's
Hello , Welcome to Fixya.com
I decided to start a new tip because of the confusion over Microsoft Framework.
Say your system just got blown away and you reinstalled your operating system, Weather its 32/64bit Windows 7, Windows Xp, Windows Vista.
Here is a quick way to reinstall Microsoft Framework without having to Run windows update or search around the innterweb.
1. Open up your web browser
2. Click on this LINK
3. Click the Download button on your right hand side
4. Choose Run on the dialog box.
The program will download and install the correct Framwork without any hassles. This will also help you reinstall programs that need a updated version of Framework without errors.
Thanks for using Fixya.com
on Dec 11, 2010 • Computers & Internet
How instal net framework 3.5 for windows Tecnical preview 10
Net Framework is a Microsoft update . Go to windows upadte and check to see what updates you need to install.
Hit the START buttom on the computer and then choose ALL PROGRAMS and then go to the folder for WINDOWS UPDATE. That is for Windows 7. If you are using a different version of Windows it will be slightly different.
2answers
I got an acer travelmate 5720 wich was configured with vista, so when i uninstaled vista and replaced it with windows seven i lost my empowring technology utility; so i ask you to help with saying me what...
Have you tried going to acer.com? Most companys post the up to date drivers for their products there. You have to look under the Downloads/Support tab.
2helpful
Can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
1helpful
Im trying to enable my acer enet management
e net management must fist be installed together with the empowering technology framework. If you don't have the software you may download it here: http://support.acer-euro.com/drivers/downloads.html
Note: make sure you choose the right specs for your system. :) f9b0e40.png
How can i get acer empowering technology framework?
The framework is used for the other acer utilities that are build on top of it, it is required for the acer utilities that are on acer laptops, they may not work at all without the framework.
you can get the framework and the utilities related to your laptop (or desktop) from http://support.acer-euro.com/drivers/downloads.html
ACER ASPIRE 9302 WSMi erased programs,cannot use eRecovery
Click on Start choose Run and type in the box msconfig go to Startup tab un-tick the e-Recovery monitor
1helpful
2answers
I closed my Eclipse editor after usual work; and i came on next day to office,try to open it ,but not getting opened by saying "An error has occured .see the log file"
Start by looking at the last line:
MESSAGE Missing required bundle org.eclipse.gef_0.0.0.
Looks like it can't find the GEF (graphical editing framework) libraries. They should be in your eclipse/plugins directory - if not, download a fresh copy from http://www.eclipse.org/gef/downloads/ and extract into the plugins directory.
Can you post the output after doing this, so we can see if the Quantum / OSGI libs are missing too?
Grand Canyon Tech
Grand Canyon Tech
