Question about Kenwood KDC-7024 CD Player
Control panel will not open when pressed in lower left corner
     having just had my player back from repair (new ribbons) after connecting it back to the vehicle it seems to be exactly the same problem.There is power getting to the player because when I turn on the ignition you can here it power up, and the small led flashes in the bottom right corner.Any ideas what this may be?
                                                Thanks
                                                          Rob
  • 78 Answers
There are a few problems with these units including the flexible pcb's and also the detector micro switches and also the plastic gears getting sheared, I suggest you bring it back to where you had it repaired as it seems they haven't fixed it properly yet.
Posted on Dec 08, 2007
How to Open the Control Panel?
Click the bottom-left Start button to open the Start Menu, type control panel in the search box and select Control Panel in the results. Way 2: Access Control Panel from the Quick Access Menu. Press Windows+X or right-tap the lower-left corner to open the Quick Access Menu, and then choose Control Panel in it
Oct 18, 2016 | Computers & Internet
Samsung 1080p player is not opening to release disk
To unlock the Blu-ray player, follow these steps:
  1. Press the Stop button to place your Blu-ray player in stop mode.
  2. Press 4-8-2-7-3 on the remote control. Lock Off will appear in the upper left corner of the TV screen.
  3. Press the eject button on the remote control.
  4. The disc tray opens on the Blu-ray player.
If this does not resolve your issue:
  1. Unplug the player and hold the power button for about 20 seconds.
  2. Connect the power cord again and with no disc in the player, press and hold the Stop button on the panel until your TV displays the message, "Resets all settings to the default values". After a few moments the Player will turn itself off.
Jun 30, 2014 | Samsung Televison & Video
Replacing pressure switch
1) Unplug the machine. 2) At the head, or control panel, find the two screws that hold it to the case. Some are on the left and right front lower corners of the panel, and some are vertical facing s on the rear left and right side. Also on some models they are in the front but you have to pull the end caps off the sides of the control panel. Further more in some of the newer models you have to take a thin paint scraper and slide under the left and right normers to press the clips in to release. 3) Remove the 2 screws and then pull the panel from the lower part of it towards you and roll it backwards. 4) Disconnect the lid switch connection in the the middle where the two grey wires and the green wire block connects to the body of the machine, usually near the middle under the panel. 5) with a flathead screwdriver pop out the two brass retainer clips on the right and left side. 6) Open the lid slightly where you can grab the case, not the tub, just the case, and pull forward and surprise!!! You just took the complete top, sides and front of the machine off.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 29, 2012 | Kenmore Washing Machines
Does anyone have a diagram on how to take the cabinet apart
I don't have a diagram but I can give you a walk through that I believe will help. The type of machine you have falls into the direct drive catagory. Here is the walk-through:
May 17, 2012 | Kenmore Washing Machines
Where is volume control on dell laptop
Hi there! this might work :)
1.Click once on the speaker icon in the lower right corner of the laptop screen on the task bar to open the volume control.
2.Click and hold the slider control with the left mouse button or the left button on the touch pad, then drag the control higher to increase the volume on the built-in speakers.
3.Click the "Start" or Microsoft flag button in the lower left corner to access the Dell's Control Panel. Click twice on the Control Panel.
4.Click "Hardware and Sound" then click "Adjust System Volume" under the "Sound" listings.
5.Click and drag the slider control to adjust the sound level, then click the "X" box in the upper right corner to close the application.
Sep 30, 2011 | Dell Tablets & eReaders
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
How do I set up my email server
If you have Windows, do this:
Press Start (lower left corner)
click on Control Panel
Look for "Mail" (sometimes the Mail icon is under "other Control Panel Options"
Click on "Mail"
That should open an "Internet Accounts" window where you can add, delete and edit your connections.
Is this what you were looking for?
Mar 26, 2009 | Yahoo Mail
No audio in right ear unless you press on the lower left corner of screen
Has your ipod been dropped/sat on/run over??
Normally I'd think it was the headphone socket, however if your LCD is leaking and you are having problems with with volume I think your ipod has suffered an impact which has damaged the logic board.
The bad news is logic boards, while easy to source, are quite an expensive part. If you are not bothered about replacing your LCD I would suggest buy an ipod off ebay with a broken screen and take the logic board out of that, it should work out quite a bit cheaper and of course when you will have a hard drive and a casing left over from the scrap ipod to resell.
To open your ipod use two small flat bladed screwdrivers inserted between the metal shell and the plastic top of the ipod and gently prise apart. Once inside, all the major components are connected with ribbon cables, there is no soldering involved replacing a logic board. Some of these cables are quite fiddly though and the connectors are easy to damage so if you are not confident doing this I'd suggest getting it repaired by a pro.
Nov 26, 2007 | Apple iPod nano
Pioneer DV-C36 disc tray will not stay open
Solution for Pioneer DV-C36 Multi Disk DVD player - tray door will not stay open.
My player would open the disk tray when the open button was press but when the tray was fully open it would retract
back into the unit leaving no time to change or load disks.
I found a poor connection at the ribbon cable connector was causing this problem. A seven conductor ribbon cable
connects the main unit with the travelling tray. A position switch (S21) senses when the tray is fully extended and retracted.
On my player pin 1 of the ribbon cable connector on the travelling tray was not making an electrical connection which
causes the control system to retract the tray. The fault lies in the connector - the tang was not pressing against the ribbon cable conductor.
I was able to desolder the connector and pull the contact out just far enough to reform the tang with fine needle nose pliers.
This is very tedious and required an eye loupe for magnification.
Tools required:
#1 and #2 phillips screwdrivers
Soldering and desoldering irons (or other desoldering tools)
Fine needle nose pliers.
Remove the tray ribbon cable
1. Remove the cabinet cover - 6 screws. Open the tray. To keep the tray from retracting pull the power cord when the tray is extended.
2. Remove the front bezel from the tray. Gently pry up the bezel by relesing the catches with a small screwdriver. Allow the tray to retract.
3. Remove the front panel - undo large ribbon and wire connections on right, remove screws left and right, release
two catch tangs on bottom edge using a small screwdriver on the inside of the unit.
4. Remove the white plastic cover over the laser mechanism ( 2 screws) Remove the disk carrier by removing the center screw.
5. Extend the tray again. When the tray is out the small ribbon cable is visible below the tray. Undo the ribon cable where it attaches to the main unit unit.
6. To slide the tray off the main unit use a small screwdriver to depress the stop catches (2) in the tray. They are molded into the tray.
Pull the tray out further then lift up.
7. Flip over the tray and find the small circuit board the ribbon cable goes to. Desolder the motor wires (red and black) and remove the 2 screws
holding the circuit board and position switch.
Use a multimeter to confirm there is an open or poor connection in the ribbon cable connector.
Remove the ribon cable and inspect the connector with an eye loupe or other magnification device. On my player contact #1 was not positioned properly
to press against the ribbon cable conductor. You can either replace the connector or repair it.
Warning: repairing the connector may damage it.
To repair the contact desolder the connector from the circuit board. Bend the circuit board prong straight and push it into the body of the
connector which will extend the contact out and the contact can be reformed. Be very gentle. Bending the contact may cause it to break.
Reassembly is the reverse. Don't forget to solder the motor wires with the proper polarity. Red and Black are labeled on the circuit board.
May 28, 2007 | Pioneer DV-C36 DVD Player
Kenwood KDC-7024 CD Player Logo
62 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
