Question about LG GSA-5163D DVD±RW Dual Layer Burner
DVD not spinning
When I put a DVD in, it doesn't seem to be spinning to read it.  The light blinks when it attempts to start the reading but I can hear that there isn't any real movement inside.
Is my writer broken or does it need to be cleaned?  My laptop is able to recognize the dvd writer though.
  • LG Master
  • 1,886 Answers
2 suggestions its a microswitch thats under the disctray to find that should give a sign that the tray is closed so that the laser must begin to focussing if a dvd is inside to give the spindle motor a turn to read the TOC table of contents on the disk , is a frequent problem , the rubber belt of the mechanism
slips through so its not-time finishing anymore
and the dvd - tray will close but the total traject of the mechanism will not come in the play mode it hangs if the belt is slipping,
Posted on Nov 30, 2017
    Top Expert:
  • LG Master
  • 8,213 Answers
HI nIKITA2471.
If its a faulty drive try this.
Step Remove the top of the unit, using the appropriate-sized Philips screwdriver. Consult the manufacturer's warranty details to determine if this will void it.
Step Apply power to the unit, and eject the tray. Lay two paper towels over the internals of the unit, with the paper resting on the sides of the chassis. Power will remain on during this procedure.
Step Spray three short bursts of WD-40 (or similar lubricant) under the plastic disc that grabs the DVD and pulls it into the motor and drive shaft (it will be a quarter-sized black or gray disc that is attached to the spindle motor). Let settle for a few seconds.
Step Place a commercial DVD into the tray, and allow it to spin up. If it does not, your player may require professional service.
Step Gently clean up excess lubricant sling (throw off that occurs when the motor spins up) with paper towels and cotton swabs, paying special attention to the laser assembly.
Step Re-attach the top of the unit.
do not let any spray get on to the little lens that reads the disc.
or you could try just buying a lens cleaning disc and see if that works first.
  • 624 Answers
SOURCE: Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Posted on Jan 01, 2007
sandrew
  • 2961 Answers
SOURCE: I am having a LG DVD writer GSA-4167B currently stops reading or writing disks after few runs
as with all writers eventually they fault at the lens and it gets out of line and cannot read discs, you can try the usual thing of checking LG for any firmware updates, but first:- Go to my computer>right click>hardware tab>device manager, then down list to cd/dvd drives and click '+' sign and highlight your writer, right click on it and select uninstall. Restart PC and it will be automatically re installed, try again and if no change you will need to replace the drive as they are cheaper nowadays.
Posted on Jun 19, 2007
  • 749 Answers
SOURCE: DVD Writer does not respond when DVD movies are inserted..
Check the box or manual of your DVD writer... See if it support the DVD format of the DVD disk... There are a lot DVD formats nowadays, like DVD, DVD4, HDVD, HDVD-9, etc...
DVD Formats explained
I hate them too, for some DVD works only on a DVD-Player not on computers.
Posted on Jan 17, 2008
  • 108 Answers
SOURCE: my gsa h54n dvd writer cd not reading but dvd
Sounds like the drive either doesn't like the disk you are trying to use or the cd laser has burnt out. Try the disk in another machine if you can, if it works ok then replace the drive.
Posted on Jun 08, 2009
  • 145 Answers
SOURCE: lg DVD writer can not read DVD but CD . what's the
Dear,
This is a usual issue. You have to replace it. May be issue on DVD encording circute.
Get it replaced....
Posted on Oct 17, 2009
Won't read regular dvd's
I think local disc cannot read your DVD. Put quality disc into your DVD.
Feb 21, 2014 | LG BD610 BRay Disc Player
I have a Sony DVP-NS57P DVD player, The disc doesn't spin unless I give it a light touch; then it spins, reads and plays fine. If I stop it, eject it and reload it, the same thing happens again and I...
Problem seems with spindle motor that needs little bit lubrication of WD40 contact cleaner spray.
Let me know if you are willing to take apart dvd player and have WD40 spray.
Thanks.
Jul 29, 2011 | Sony DVP-NS575P DVD Player
CDC-655 was put in storage (in orig box) and brought back out and plugged in. It loads each CD and fails to read each one. The lighted numbers go out, one by one, as it fails to read them.
This seems to be a "Dust on Lens" problem. No issues... It happens when you keep your CD/DVD players unattended for a long period of time. Even if packed well enough, dust/moisture does tend to gather on the lens and cause this type of an irritating problem.
If you have a lens cleaning CD (if not, go buy one) then just insert it and let it spin regardless of whether or not it reads it. The spinning action will clean off any finely deposited dust particles on the lens. Repeat th process till the Lens Cleaner CD starts playing its audio. If this happens then all your other CDs should read. One more thing, make sure that the motor is indeed spinning. How can you know???
1. Buy listening carefully for a whirring sound the moment you put in your CD/DVD
2. By feeling for minor vibrations on the front panel (CD tray front cover)
3. Putting in a CD/DVD with a label straight as you can read it and see if it comes out differently on ejecting it. I hope you understand what I mean...
If this doesn't then it could be a blown lens circuit or a dead drive motor. In that case your player needs to be taken to a service center.
Hope it answers most of your query. Good luck.
Nov 05, 2010 | Yamaha CDC-655 CD Player
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
Device stopped to read any disc
for EnzoMolinari
u r drive is having an hardware problem just contact nearby service center
Apr 27, 2008 | Sony AW-Q170A-B2 DVD RW Dual Layer Burner
DVD stopped playing all DVDs
Reset you player by doing the following:
With the player on, hooked properly to your television, and on the correct station:
Open the tray
Close the tray (with no DVD inserted)
Hold the stop button down for a full 5 seconds
The CyberHome screen should appear. You should be able to play your dvd's now.
Feb 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Will not read DVD-ROM
Computer DVD Support.
Good Luck, Please dont for get to Vote, Follow instructions.Thank you.
Dec 26, 2007 | Compaq Armada M700 Notebook
Wont spin
cdfreeze, DVD drives spin up the platter and attempt to read from it. If the read fails, they stop spinning the drive. So, I think the problem you have is that the device won't read. DVD drives have some very small plastic pieces that can break and cause failure. They also have a read head that can get out of alignment. If you're ambitious, look at the drive and see if you can find any other damage. Don't run the drive open, though, because there is invisible laser that can blind you (there should have been a warning on the top of the drive when you opened it). I checked eBay and this DVD player sells for under $20 (including shipping), so don't spend too much time on it. Definitely let me know if you have questions or comments.
Aug 22, 2007 | Philips Magnavox DVD Player MWD200F
LG GSA-5163D DVD±RW Dual Layer Burner Logo
76 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
