Question about Kicker Solo-Baric L5 Car Subwoofer
Snaped speaker wires
My problem is that i snaped the contact wires that power the speakers i want to know how do i fix those wires inside the speakers
Solder the two ends together or sell the speaker to me wakesslide12@aol.com
Posted on Oct 26, 2007
The speaker it self is fine the speaker wire broke loose, how do I fix?
there is two wires and two point of contact, in better speakers it is relevant where these are connected in standard speakers it is not.
just solder them in and that is all, you should find small connection plate (insulated!) on the back of the membrane crate, that is where they go.
Feb 07, 2015 | Logitech Audio Players & Recorders
The sound on my daughters Mobigo has suddenly stopped working.
Have you tried taking changing the sound blaster{speaker}...the fault is clearly not from the mobigo but the speaker in it...good luck
Dec 28, 2011 | Vtech Mobigo Learning System
No sound from rear speakers. Mustek DVD V600RZ tks giuliano
This is almost always due to a bad speaker connection in the speaker output terminals on the back of the receiver unit, or the speaker input terminals on the back of the speakers. Check your wire connections at these points and fix as necessary. If the plastic wire insulation is pushed inside the terminals, it will prevent the wire from making contact in the terminal.
May 29, 2011 | Mustek V600RZ Theater System
Comes up when switched on protection
Protect occurs when 1 or more of your speaker wires is touching somewhere. Power off the receiver, connect speaker wires to receiver and speakers again, power back on, should fix the issue.
Protet mode is a special diagnostic mode that starts when a fault is detected.
When in protection mode the unit is prevented from starting by protection circuit, so to prevent further damage.
Check the speakers and speakers wiring, a contact in speaker wires, or faulty speakers can send the unit in protection.
Try unplugging power cable for one hour or so. then connect cable back and see if you get rid of protect state. Sometimes accumulation of electrostatic charges inside circuit capacitors can kick in protect mode. In that case unplugging the unit from main for some times can get rid of electrostatic charges, and reset circuits by draining power completely.
If that was the problem, you will not get Protect when plugging back power cable.
If you do all the above and still get Protect, then there is a real fault.
In that case the unit may be disassembled and tested to find the fault.
If that is the case I suggest contacting the manufacturer at the number listed on the owners manual, or asking a quote on repair to a local technician.
Also use the link below..
http://www.youtube.com/watch?v=h9SPYjPBg4M
Take care..
Mar 21, 2011 | Audio Players & Recorders
The Power Switch no longer stays on. How can I fix it?
These are $5 speakers, I would throw them out and get a new work pair of speakers.
Mar 08, 2011 | Altec Lansing ACS 90 Computer Speakers
No power light on my speaker
It's possible that the power adapter that gives power to the speakers, is faulty. It's also possible that some electronics inside the speakers is faulty, this could also be the power button on the speakers.
Take your speakers and the adapter to an electronics store in the market and ask the shopkeeper to try an exact adapter and check if it powers up the speakers.
If the speakers power up, then buy the adapter. If they don't, then the problem is with the speakers and you may have to contact an electronics repair shop. Or, just get new logitech speakers. They are cheap nowadays.
Hope that helps,
Regards,
Raspal
Mar 26, 2010 | Dell A425 Computer Speakers
Two of the speakers just aren't producing any sound. Could they just be blown, or might I be able to fix them?
not gonna lie your right chance are they could be blown. i would check the wiring or even if you feel comfortable enough unplug the speakers and check the wires on the INSIDE of the dead speaker to see if they are still soldered on there ok.
Nov 04, 2009 | Logitech X-530 Computer Speakers
My Stereo Is Always On Protect Can It Be Easily Fixed
May 27, 2009 | Sony Audio Players & Recorders
Marathon 2000 amp... PROT light
Ok this means the AMP is in protection mode!..most likely the cause is a short in your wireing from the speaker wires! check all wires going in and out of amp! Look for stray wires touching metal or other contacts! (If this does not fix it the short may be inside of amp!
(This has nothing to do with a fuse!)
Please rate this FREE response!
THANK YOU!
Jan 19, 2009 | Marathon DJ-2000 Amplifier
Is there any way to take these apart?
Is it a powered speaker? If not then if you know how to solder ,sure open her up and move around the wires while shes playing and see if you can duplicate the fault. If you dont know how to solder then take the unit in to be serviced as a loose connection inside a speaker can certainly blow out an amps output circuitry. Good Luck
Jun 25, 2006 | Cambridge Soundworks Center/Surround IV...
Kicker Solo-Baric L5 Car Subwoofer Logo
62 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
