Question about Ricoh Aficio 450 Copier
Copier help What is an OU code on a Ricoh 3513 copier?
  • 69 Answers
Hi im can reset that in program,1st press clear all yellow button 107 in the number panel then press and hold clear orange collor,wait until 1 blinks in the lcd.then then turn it off for 5 seconds then turn it onn,if that doesnot work check all door including the output door and the side door just below the bypass tray in indicate a door is open
Posted on Nov 16, 2007
Ricoh mp 1600 error 194 ricoh mp 1600 error code 194 how do I solve the problem
Having problems finding your error code. Here is a complete list of all codes for your printer:
I do find the error code for a different Ricoh model (Aficio 1018).
Please verify your model number and error code.
Apr 21, 2015 | Ricoh Aficio Mp-1600 Copier
Error code PJ10 on Ricoh FW870
hi i have a ricoh fw870 copier cant fix it error code is 0j08 ,i need help in this
thank you
Dec 20, 2013 | Ricoh FW870 Black and White Copier
Ricoh Aficio SP 4210N- Code SC 543
This is a common error code for Ricoh copiers, Savin and Gestetner copiers that need service. Recently Ricoh has purchased Lanier and now is naming all their new machines Lanier instead of Gestetner, Savin and Ricoh. However, the copier service error codes have remained he same.
When you get this copier printer service code it means the fuser or fixing assembly (same part) has thermistor problem. The copier fuser's thermistors help regulate the temperature of the fuser assembly. The fuser assembly on all copiers including Canon, Kyocera, Ricoh, Sharp and other brands is the part that melts the toner onto the page.
Getting back to the repairing the copier on Ricoh, Savin, Lanier and Gestetner models that have the fuser or fixing code error. The majority of the time the fusers' thermistors (Middle and read) need to be replaced. Just cleaning them will not solve the copier repair service code.
It is usually, depending upon the machine, its a 1 to 2 hour copier repair job because the copier repair service technician will need to dissemble the fuser, insert the two new thermistors, re-assemble, reset the error code and test the copier machine repair. Also, ask the copier technicians to to do a copier cleaning maintenance while on site.
Aug 18, 2011 | Ricoh SP 4210N Laser Printer
My ricoh FT4418 wont copy at all error code E70. what does that mean?
It means the toner overflow sensor was tripped:
Mar 14, 2011 | Ricoh FT5832 Copier
Ricoh 2045 erro sc546; a cada 30 copias, o que faco, nem o codigo 107 adianta ,mais
Change the thermistors in the fusor (2).
1. Press the Clear Mode key.
2. Use the keypad to enter .107..
3. Hold down Clear/Stop for at least 3 seconds.
4. Enter the Service Mode.
Turn off and on the copier to reset the code.
Mar 06, 2010 | Ricoh Aficio 450 Copier
Probleme de fonctionnement du copieur,rapporter le code panne lors de votre appel technique. SC101
Le niveau blanc normal était not detected correctement en balayant
plaque blanche.
Lampe d'exposition défectueuse
Stabilisateur de lampe défectueux
Connecteur de lampe d'exposition défectueux
Plaque blanche normale encrassée
Miroir de balayeur ou lentille de balayeur hors de
position ou encrassé
SBU défectueux
Exposure lamp error
The standard white level was not detected properly when scanning the
white plate.
Exposure lamp defective
Lamp stabilizer defective
Exposure lamp connector defective
Standard white plate dirty
Scanner mirror or scanner lens out of
position or dirty
SBU defective
Sep 14, 2009 | Ricoh Aficio 450 Copier
Error code
You're right, it cross references to a "Ricoh FT4727". You need to press the "." key to read the last 2 digits, however "1xx" codes all relate to the optics section: For example, exposure lamp, scanner motor, lens, etc. You'll need a technician to fix this one.
Mar 28, 2009 | Ricoh Aficio 450 Copier
Ricoh color copier service code
Hello sir; Let's try to reset;
1, press "clear mode", "107", then press and hold down "clear/stop" for about 3 second.
2, touch copier SP,
3, enter SP5-810-2 pres enter.
4, press 1, then turn power off and back on .
Jan 15, 2009 | Ricoh FT3713 Copier
About ricoh copier problem
sc541 is a fusing unit error code. Can you reset the code in service mode?
Apr 22, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio 450 Copier Logo
67 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
