Question about HP PSC 1410v Printer
Printer keeps printing test page
Ever since we moved the printer to our new Gateway with Vista, we cannot stop it from printing a test page each time we turn the printer on. We have done everything that HP has in theie solution section.
    Can anyone help???
  • AllanB Dec 13, 2007
    I want to stop printing a test page each time I turn my printer on.
  • HP Master
  • 1,113 Answers
Check and clear print que in this printers driver on server, ensure that the hp drivers also been updated to vista
Posted on Oct 28, 2007
Canon BJC printer keeps printing test pages
Printers with USB are so inexpensive and think you have an incompatibility issue with your BJC-80 and the usb to serial convertor is not helping.
Hope that helps.
Mar 19, 2014 | Canon Office Equipment & Supplies
I have an hp 3150 all in one printer. Every time I turn it on to print a document it prints a test page. I am out of color ink so it doesn't print the additional numbers and lines to align the printer. I...
I know your problem and i want to know that have you changed or refill your cartridge?.
if yes
place one plain paper in the tray.
it will print the test paper
print it and place it on the scanner with the printed side down.
press the scan button from the printer
printer will blink the light for some time and stop blinking
now it didn't print test print every time you print
Jun 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
My printer keeps printing the test page everytime its switched on, How do I stop this as wasting ink ?
Remove and reinstall the printer driver. Make sure you have the latest driver consistent with your operating system.
Feb 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
My printer keeps printing the test page every time it's switched on. I have C3180 all in one printer.
That is a "configuration-option" -- navigate through the controls on the printer itself to disable that option; or, just leave the printer on -- it will go to "power-save" mode after a few minutes of non-usage.
Dec 14, 2009 | HP PSC 1315 All-In-One InkJet Printer
Alignment page prints every time printer is turned on. HP1315 on Windows Vista Home Premium.
Take the test page ( also called : alighnment page ) that always prints when you switch on the printer and place it face down in the scanner.
Then press the scan button on the printer itself.
(this is the button at the bottom of all the buttons on the printer/scanner.)
Make sure that the printer scans the test page.
( sometimes you press the butoon and it doesn't scan )
( it makes a scanning noise when scanning succesfully )
Then it will stop printing the test page ( alignment page ) ever again.
Sep 18, 2009 | HP PSC 1350 All-In-One Thermal Printer
HP All-in-One Printer Series 1300 prints blank copies
Have you tried printing a test page from the printer itself. usually holding down the power button will instruct the printer to print a self test by itself.
Mar 10, 2009 | HP Officejet Pro L7680 All-In-One Printer
Unplug the printer and leave it for three minutes and then plug it back in. This will reboot it and it may cure the problem.
Feb 05, 2009 | HP Photosmart C3180 All-In-One InkJet...
Printer prints multiple pages with DPR1260 print server
I was having the same problem when I added a Windows Vista PC to my home network. My older XP systems workd fine, but the Vista system would keep printing. The following fix worked forme in vista, may work in XP also.
1. First, be sure you have the latest firmware in your DPR1260. Version 1.24 is what I am using.
2. From the printer window (or via controlm panel) select your printer, then select Properties (either right click, or from the menu via File-Properties)
3. In the Properties Window, select the Ports tab. You should see your printer highlighted and checked, under the port heading next to thcheck box you'll see IP_192.168.x.x, under descriptio Standard TCP/IP Port, and undr Printer, the name of your printer.
4. Click the "Configure Port" button, be sure "LPR" is selected, not "RAW". Under LPR Settings, check that the "Queue Name" matches that in our DPR1260 status screen, and be sure SNMP Status Enabled is not checked.
The problem on my Vista machine went away when I changed from "RAW" to "LPR" settings.
Hope this helps.
Jul 28, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Test and scanning the alignment page
we have a link on how to fix your own printer through this link(check for search box further down page)
Mar 08, 2008 | Lexmark X2470 All-In-One InkJet Printer
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Open Questions:
HP PSC 1410v Printer Logo
99 people viewed this question
Ben Johnson
