Question about ATI Atlantis RADEON 9000 (128 MB) Graphic Card
Using my tv as a monitor
How do i hookup and use my video card to use my tv as a monitor
  • 4 Answers
Right click on desktop, then go to properties. Click on the settings tab. There should be two boxes, labeled 1 and 2. Click on box 2 and select:
Use the device as the primary monitor and Extend my Windows desktop onto this monitor. Also go to advanced -> Monitor and make sure that the screen refresh rate will not damage your tv. For older tv's it's usually 60 Hz for NTSC and 50 Hz for PAL.
After getting your settings where you want them, click apply. This will transfer all video output to the auxillary screen and will leave your primary monitor blank until you change the settings back to the primary screen.
Posted on Feb 02, 2008
Trying to hookup a samsung tv last yrs. model to an older desktop pc. get the message, do not reconize devise
well are you using a blue vga cable? if so after you hook it the cable up on both the tv and computer you need to switch the TV input to vga and then after that in some cases you need to change the computer settings to turn on remote monitors tell us more about the computer and what operating system you have then we can assist you further
Jan 24, 2018 | Samsung Computers & Internet
How to install software to gfive g111 mobile
Computer Monitors
Nintendo home consoles are designed for use through home televisions and VCRs, using standard A/V, S-Video, component, or RF connectors (for older systems). Computer monitors typically do not have these connections. There are however two ways a hookup to a computer monitor could be accomplished:
With a PC TV Card:
A TV card inserted into your PC may allow you to connect your system if the card has the proper connections (such as RF, A/V, S-Video, component, or Coaxial). However, we have found that the image quality is not as clear as it is on a TV, in most cases.
With a Direct Connection (RGB or DVI Cables):
Nintendo does not manufacture any cables to make an RGB or DVI connection. While other companies may manufacture wires that can make this possible, we are not able to recommend them, as they are not licensed by Nintendo.
May 19, 2012 | Nintendo Super NES Console
How to install china mobile software
Computer Monitors
With a PC TV Card:
Can you hookup a computer to the sanyo ds32224
Yes, if you get the appropriate converter. You will need either a VGA to component video or VGA to composite video converter. Some of these are available here: http://www.svideo.com/pctocomponent.html . Since the computer VGA port provides an RGB signal and the component video is a YPbPr signal, the converter is essential.
However, the cost of the converter may not be worth using this method when replacement monitors are fairly cheap. (Christmas sales had 19" LCD monitors for under $100 with VGA input.)
I hope this helps.
Dec 27, 2010 | Sanyo DS32224 TV
How do I plug in the super nintendo to my computer? I don't know which cable goes into the "out" place.
Computer Monitors
With a PC TV Card:
Oct 26, 2010 | Nintendo Super NES Console
PC to tv VGA cord hookup. Installed but it said it has no single, will be used as main monetor. Workes but I ca'nt use my keybord to try to get single to tv. a1600n has onley one VGA port and nothing else...
First idea to try: make sure the TV is on (saying no signal) before you turn on the computer. Several TV/monitor units will not respond if the computer is already on when the TV is turned on. Check that you have a good cable (they do fail) and well-seated connections. Then double check that your VGA port is sending a signal out; use another monitor to check. You may have to change your BIOS or graphics card settings. If no signal at the port, you should also check, if using a graphics card, that you have sufficient power to the card from your power supply and it is well-seated in the slot.
I hope this helps.
Dec 20, 2009 | HP Pavilion a1600n (882780776265) PC...
How do i hookup my ilo tv monitor to my computer?
ur VGA card must have video out jack of any type latest cards have HDMI that would work with any new LCD TV
Sep 22, 2009 | Televison & Video
What to hookup wireless camera and dont have connections on compu
u need a port on PC at which u can hook up the output from ur wireless reciever those red and yellow rca pins if u dont have a tv card yet, cheap solution is either u buy a PCI TV card normally it comes with an input port for video capturing check it out when buying, u can watch ur transmission live on software tv screen and plus u can enjoy watching tv on ur PC as well if u hook up ur RF cable to it but if u need specifically for monitoring purpose then u can go for DVR card for more func of rec the feed and hook up multiple cameras and watch them together
choice is urs
let me know and pls do vote me if u find me fixing ur problem
Feb 21, 2009 | HP Compaq Presario SR1123WM PC Desktop
DVI CABLE AND AUDIO CABLE. NO EXPLAINATION OF HOOKUP OR USE
Plug the audio cable into the LIME GREEN port on the computer.
You can onlly use a DVI cable if your Video Card has that kind of connector.
Trust me, you don't need one. Use the D-shaped 15 pin connector.
Feb 09, 2009 | Soyo DYLM24D6 LCD Monitor
Wiring problem
waste of time.
if you need a monitor, buy a monitor.
if you need a tv, buy a tv.
Sep 27, 2008 | LG Studioworks 700S 17" CRT Monitor
ATI Atlantis RADEON 9000 (128 MB) Graphic Card Logo
230 people viewed this question
Top ATI Computers & Internet Experts
David
David
Computer Links
Alun Cox
Are you an ATI Computer and Internet Expert? Answer questions, earn points and help others
