Question about Canon imageRUNNER 550 Printer
Fan on copier
The fan on the copier went out. How long does it take to get a replacement?
    Sergeant:
  • 199 Answers
When they not work perfactly, until u don't want replacement
Posted on May 14, 2009
Cooling fan
Then fan will not come on until the coolant temps gets over 220 degrees. Are you sure the coolant temp is getting that hot.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Sep 08, 2013 | 1999 Chevrolet Cavalier
Canon ImageRunner 330s Error E805, Can't Enter Service Mode
FM1 Heat discharge fan Cools fixing unit.E805 0000 Fan failure
only one in this copier>
The fan is faulty. -
Check the fan connector.
- Replace the fan.
- Replace the DC controller PCB.
Switching between full-speed rotation and half-speed rotation is controlled as described below.
1) Full-speed control
When the CPU on the DC controller outputs a fan full speed signal (FAN_FULL), the fan drive voltage switching circuit supplies a +24 V fan drive voltage to turn
the heat exhaust fan at the full speed.
2) Half-speed control
When the CPU on the engine controller outputs a fan half speed signal (FAN_HALF), the fan drive voltage switching circuit supplies a +16 V fan drive voltage to
turn the heat exhaust fan at the half speed.
E805-0000 (Main body fan error)
When the cooling fan of the main body starts, the fan lock detection signal (FAN_LOCK) has been held at the "H" level for longer than the prescribed time.
also check your low-voltage power supply
Apr 22, 2012 | Office Equipment & Supplies
My copier is having a system error E-805
- Replace the fan.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
May 31, 2011 | Canon iR 2016i Black and White Copier
Cooling fans not working on a buick regal 1992?
First check fuse in engine compartment. Use a test light to check for voltage at the fan connector. If no voltage at fan with engine running and hot, replace fan relay in engine compartment relay box. If there is voltage at fan, but fan doesn't run, replace fan. Any questions, please reply.
Sep 09, 2010 | 1992 Buick Regal
ImageRUNNER 400S Copier: what is e805 error & how to clear...
Its a fan related error, basicaly you should check all the fans in copier, clean the filters, reconect the connectors, try to find a bad fan,... When you find the bad fan you can also replace it with new matching PC fan
Pls. rate
May 03, 2010 | Canon Office Equipment & Supplies
A/c fan and radiator fan not working
Try the fan fuses,to see if they are blown,if they are,most likely a bad fan motor.Check the fan relays also.to see if they are getting power to them .If the relay is not getting power to it when the fans are supposed to come on,then replace the coolant sensor.the fans surly are not both bad.But if one is the fuse may have went bad.If it has a module instead of the old fashion relay,it most likely went out.Replace the module and the one of the fans will be bad.If I can help,let me know.Let me know the out come.
Aug 29, 2009 | 2004 Honda Accord
E805 error in canon ir 400
E805 error code means failure of one of the many fans inside the copier. If there is not a dash with four numbers after the 805 code on the display, it is one of two fans - FM1 the transport bed fan or FM9 - the reversing fan just below the fuser assy. There are several checks that can be done but a too lengthy to be described. A tech maybe the best answer depending on your mechanical ability.
Jul 21, 2009 | Canon imageRUNNER 400S Copier
Over heat cooling fan load noise remove and replace
A bearing more than likely has went bad causing your fan to stop properly cooling your unit. Replace with a compatible fan and you should be all set. Hope this helps.
Jun 03, 2009 | Sony Computers & Internet
Fan went out
Bought a fan at Radio shack 12.99. Pricy for such a small fan but it worked.
Feb 10, 2009 | Mad Dog Multimedia MegaSTOR...
Canon imageRUNNER 550 Printer Logo
35 people viewed this question
old marine
old marine
