Maytag LA882 - Leak from top
Sporatically our Maytag washer will leak water from the top back left.  Water will pour from the bottom of the washer and from seam of the side and top panel.  It happens maybe once a month.
I suspect the water is coming from a plastic (clear square) piece on the inlet hose(see picture).  Is this a broken piece or some kind of a check valve? What can I do to fix the problem?
Thanks
Kregg Sims the
  • Anonymous Nov 24, 2007
    Are washer leeks like that all the time now..
  • kegger01 May 21, 2008
    Update, I fixed the problem by replacing valve. Not sure why there is a need for the valve or why the old one was causing a problem, but have not had a problem since replacing.
  • 1294 Answers
SOURCE: Maytag Washing Machine leak
First plug off the wall. Open up the top by unscrewing screws at the back of machine or wherever. Check out the tubes........
Posted on Sep 16, 2007
faggly
  • 74 Answers
SOURCE: Washer has a water leak.
Hiya....... It is more likely to be the drain pump... check the hosing and fittings, obvious but make sure no electric on first
Regards faggly
Posted on Mar 25, 2008
  • 3 Answers
SOURCE: washer Maytag
To get access to internals you have to remove back panel of machine and then other 3 sides that then exposes the parts you need to get to eg. drainage hose,s
Posted on Jun 01, 2008
docjohn174
  • 943 Answers
SOURCE: maytag washing machine mod # LA882 top loader
HI. thanks for the question. well, not good news for you. the transmission has failed. has broken a gear inside. very costly .suggest buying new. A roper washer. good price. good washer. thanks the appliance doc. please rate my answer thanks.
Posted on Oct 08, 2008
aborcass
  • 2651 Answers
SOURCE: water leak
you would acess ut from under the main top. alittle involved but acessable,.. you need to remvoe teh four phillipsscres from with in the soap dispensor area. then remove the front door as well as th e2 screws oppisite t eh door hinge, then pop off the front cover. from there youll find 2 more 5/16 screws holding the top to the frame assy. then the main top can be flipped backward allowing you acess to the valve
Posted on Nov 03, 2008
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Leak
You have 3 areas to check. Drain hose, water pump and hot/cold water valves. Any of those 3 areas can be the cause. Most often leaks are caused by loose hoses, but neptunes use a plastic water pump that can clog and lose bearing water seals as well. Try the easy options first, then if those solutions don't point to the cause, remove the front cover and check the water pump for moisture.
Mar 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Water pours from bottom of tub as soon as water goes in.
Common cause is leak in drain hose as hose outlet must be above water level and if damaged water will run out straight away ( syphon ) but tip it up ( carefully ) and check
Please - Please be carefull as water and electric are not friends
Aug 31, 2009 | Maytag PAV2300 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
My daughters maytag has water leaking from the bottom.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
Nov 25, 2008 | Maytag PAV2300 Top Load Washer
Washer Maytag
Apr 20, 2008 | Maytag Dependable Care LAT9706
Washer leaking water on floor
Need to check drain pump and its hose connections. If its not from the drum seal then that's usually where the leaks occur.
Mar 30, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Water leaking out front of maytag washer
Remove the top cover of the machine. Check to see if the three tubes going into the dispenser drawer hv not come loose. Tighten well.
Sep 11, 2007 | Whirlpool WTW6400SW Cabrio Washer
Washing Machines Logo
218 people viewed this question
Top Washing Machines Experts
