Question about Arris SURFboard SBG900 (49402201900) Modem
Cannot change wireless channel
Every time I try to change the wireless channel to anything else but 1, the AP disappears completely for all clients (3 laptops with different wireless cards), and can't even be reached if I enter the new information manually. Problem is, channel 1 receives too much interference to be usable in my location
Is there a workaround for this, or is this a known problem?
    Problem Solver:
  • 7 Answers
Try to configer the same data in all 3 Lap Top.make sure
IP should not be the same.
Regards
Posted on Jan 06, 2008
Ap dropout
Things That Affect Wireless Router Signals
1. Many wireless routers are using the same wireless channel. Many manufacturers choose channel 6 as the default. Change to another channel. 2. Analogue video senders used to send audio and video to other TVs in the home. 3. Microwave ovens emit interference in the 2.4GHz band. 4. Wireless speakers and console controllers can cause interference with the wireless router. 5. Bluetooth devices, newer Bluetooth devices can jump to different frequencies if there is a connection problem. 6. Power cables located near the wireless router can cause dropouts and speed reduction. 7. Fish tanks will cause massive Wi-Fi shadow on the other side of the tank from the wireless router. 8. Depending upon the location of large mirrors will reflect wireless signal away your computer. 9. Building materials will block wireless signals such as plasterboards with metal foil, reinforced concrete walls and floors. Also objects near the wireless router such as metal filing cabinets and other electrical appliances. 10. Blinking Christmas lights can reduce Wi-Fi performance by 25% when it is close to the wireless router.
Oct 07, 2012 | Buffalo Technology WLS N150 RTR AP BRG
I have a HP ProCurve MSM 410 AP. It will accept clients and then in 20 minutes it starts dropping connections..and will not let them back on with a restart. I have poured over the specs for both AP and...
I'm having a very similar issue with 5 MSM410's (at 2 differant locations), purchased at the same time, from the same vendor.
With 2, when connected using PoE Injector, the AP gets hot (at the Data/Poe port), and only permits 3 devices to connect before the devices start losing the ability comminicate beyond the AP (i.e. I can logon to the AP with the Web Interface (WI), but cannot ping the DHCP server or even the Gateway device on the other side of th AP from the devices, but can ping both directions without issue from the AP's WI). HOWEVER; when connected using the PoE from a Cisco ASA-5505 (port 0/6 or 0/7) the devices work flawlessly.
- For this site, I replaced the Power Injector first, then replaced the AP. No change
- When connected to the PoE on the Cisco the unit does not run "Hot".
With 3 others at another location, they only allow 3 devices to connect and will disconnect any devices previously connected. These 3 are supplied PoE from Dell PowerConnect Gigabit Switches (also used to supply power to the VoIP and PoE Security Camera's), and also run Hot at the Data/PoE ports. We have not tried power injectors at this site.
I've tried to find any indication of how to adjust the PoE and Data Port settings to resolve this, but cannot find anything, and this appears to be a unique issue, as noone I have contacted has ever experianced it.
- Mike
Mar 28, 2011 | HP ProCurve MSM410 (J9426A) Pre-802.11n...
I have a netgear WGR14 v9 router and my xbox360 wont let me play NBA game because i have NAT is strict and i need to open NAT. I have tried everything i can read on it and nothing seems to work.......can...
Try:
Plug the AP+4 directly into your computer via Ethernet cable. This is usually a yellow cable that is provided with the AP+4. Plug on end of that cable into the computer you are setting up the AP+4 and the other end into one of the four numbered ports on that AP+4. (Note: Make sure to have your computer off. If your computer has a wireless connection to your network disable it. If you computer has a static IP be sure to set it to DHCP.)
Next, open up your web browser (we recommend using Internet Explorer or Firefox). Delete the address that is currently present in the Address Bar.
Once the address is deleted, type http://10.0.0.200 into the Address Bar.
Press Enter.
2 You will now be logged into the Status Page of the AP+4. On the left side, click the option that reads Setup Wizard.
Click on the Next button to get started on the wizard.
3 You will now be on "Choosing an Operating Mode" screen. Here you will select Ethernet Client.
Click on Next to continue.
4 The next page is "Selecting a Time Zone." You can skip this and click Next to continue.
5 This will bring up the "LAN Interface Setup" screen.
On this page, you will need to change DHCP to Client. Once that is done, click Next to continue.
6 You will now be on "Setting up Internet Connection."
WAN Access Type needs to be set to DHCP Client. Once it is set to DHCP Client, you can click Next to continue.
7 The "Configuring the Wireless Network" screen will open.
This is where you will need the SSID and Channel of your network. Change the current SSID to match the one provided by your wireless router. Also, change the Channel to match that of your router as well. Once those are changed, you can also change Wireless Operation to Client. Click Next to continue.
8 This will take you to the final page of the Setup Wizard "Setting Up Wireless Security."
Here is where you need the Encryption type and Passphrase/Network Key. Enter the Encryption to match that of your router, if applicable. If you do have encryption, you will have a Network Key or Passphrase, depending on the Encryption type. Select Passphrase if you use WPA or WPA2. Select Hex if you are using WEP. Once the Network Key or Passphrase has been entered, click Finish.
9 Power down your computer and remove the AP+4. Plug the AP+4 into the Ethernet port of your gaming console. Follow the instructions that came with your gaming console to set up your Internet connection. The AP+4 will appear to be a Wired Connection to your Gaming Console.
For a PDF version of this answer, with screenshots, click AP4_Setup_GamingConsole.pdf in the File Attachments area below.
Nov 02, 2010 | NetGear WGR614 Wireless Router
Engenius eap-3660 access points channels chashing.
This is a massive and expensive network, which appears to require a full signal and configuration audit. It's quite possible that many of your problems are stemming from the APs you have already deployed being situated in suboptimal and conflicting locations, which is an issue with three-dimensional wireless networks.
I really don't see your problems being debugged by anyone short of an experienced on-site wireless network technician. I'm saying this as a person who tuns a one-man company serving two rural communities with wireless internet service.
Sorry.
May 07, 2010 | EnGenius EAP-3660 802.11b/g Wireless...
Air station keeps cutting out - client manager advises to change channels! How do I do this?
first i would download and install this program http://www.xirrus.com/library/wifitools.php that will tell you all the networks being broadcast and what channel they are on ideally you want to be on channel 1 or 6 or 11 - as they do not overlap
you should be able to download a manual from here http://www.buffalo-technology.com/support/downloads/
you need to login to the router and then goto the wireless section and changed the channel there
looking at this model http://www.buffalo-technology.com/products/wireless/wireless-g-125-high-speed/
Mar 12, 2010 | Buffalo Technology Buffalo AirStation...
I have a Sitecom WL322 (300N Wireless ADSL modem ) router. I can connect unsecured Ok, but no connections successful yet with TKIP or AES encryption. Suggestions?
If the wireless not working with WPA TKIP or AES you can try enabling WEP aas the wireless security for your network and lets see if that will be working with that level of security....
Dec 09, 2009 | Computers & Internet
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
WAP54G's as repeaters
Are you trying to setup both access point to repeat the signal of the router?
The correct way to setup the AP's as repeater is to access the setup page of your router go to status and go to the wireless subtab, check what is the MAC address that is what your suppose to configure on the AP's not the LAN MAC address which is on the local networks subtab on status.
Access the setup page of the AP's and go to AP Mode, make sure that you choose the repeater and copy down the Wireless MAC address you obtained from the wireless router. To enable roaming, meaning your wireless computer/device will connect to the AP/router closest to its location, change the wireless channel on all three device for example WRT54G will be on channel 1, 1st AP as repeater on Channel 6 and the last AP to Channel 11 but the other settings must be the same(Wireless name(SSID) and Wireless Security).
Note: Setting up an AP as repeater to repeat or extend the signal of another AP that is set to repeater is not recommended since the signal will deteriorate due to the number of hops the packets will be sent.
Hope this will help you setting up those WAP's which for me is quite useful since you can set it up to act as a repeater, AP client and a bridge to a WRT54G router.
Regards,
Sep 10, 2008 | Linksys Wireless-G WRT54G Router
AP Mode Problems
Probably you have to learn that there are various people looking for an access of the internet through your facilities. Anyway, inorder to solve your problem these are the following recommendation I made just for you. Hope this will be helpful.
PHASE I
1.) How do I reset the EOC-3220 / EOC-3220 EXT / EOC-3220+ back to factory default settings? An RS-232 null modem serial cable is required for this procedure.
(where to buy it : http://www.keenansystems.com/store/catalog/product_info.php?cPath=3&products_id=221)
1. Connect the EOC-3220 to your computer with a null modem serial cable.
2. Start a HyperTerminal session: Click Start and then select Programs -> Accessories -> Communications -> HyperTerminal.
3. After the HyperTerminal window appears:
a. Give this new connection a name. Ex: EOC-3220.
b. Select correct COM port. Ex:COM1.
c. Set baud rate as "38400", data bits "8", parity "none", stop bits "1", and flow control as "None". Then press “OK” to bring up the HyperTerminal window.
4. Wait until the "#" is displayed in the HyperTerminal window.
5. Type "flash reset", then hit enter.
6. Type "reboot", then hit enter. After the device reboots, all settings will be at factory default.
Phase II
1.) Since that you already reseted the AP you need to use the default IP which is 192.168.1.1 user: admin password: admin
2.) Make it sure you need to use different IP such as 72.10.251.xxx and the subnet: 255.255.255.xxx
3.) The idea of configuration in come from your own desire which was no body can no longer try to match your network IP so that there will be no body access your AP anymore without your knowledge.
4.) You need to make you SSID invisible to everyone inorder no body no longer able to reach your SSID by setting up basic setting which is transparent to everyone.
5) And lastly change the default user and password of your AP.
Good Luck
Nov 24, 2007 | EnGenius EOC-3220 (EOC3220)
Loses connectivity
Hi, a couple of ideas: 1. maybe out of range or too many obstruction, how far is the client from the AP or are there any objects in between. it's gotta be line of sight; 2. with 200mW power output and 5dBi external antenna, should be adequate, if not maybe slightly directional performance (no longer perfect omni). try rotating the device and more or less guesstimate max signal at a particular orientation (pointed towards the client). Netstumbler would be good enough for signal strength; 3. consider the optional integrated 9dBi patch antenna; 4. for the client having a hard time with the AP, manually enter the TCP/IP settings and not auto obtain. numbers should of course match AP settings except for the last digit(s) of the IP add; 5. try moving the client away from any RFI sources like cordless/wireless phones, microwave ovens and others; 6. at one time, signal strength to a client improved by moving the AP a couple of feet away from the original installation point. of course if your unit is mast mounted, then you have to move the mast as well or put up a new one. Hope this works for you. Good luck and pls post again how things turn up.
May 24, 2007 | EnGenius EL-2611CB5+ (NL2611CB5)
Arris SURFboard SBG900 (49402201900) Modem Logo
276 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
