Question about RCA D52W19 52" Rear Projection Television
Adding HD I have purchased an ota hd antenna, the lacrosse from antennadirect .com    Do I need to have an HD tuner to recieve an hd signal?
    Genius:
  • 1,694 Answers
YES- and very few TV's have an on-board tuner, some MIts.
did and others,perhaps......................very expensive....T.
Posted on Nov 16, 2007
I want to use an RCA F27645 for OTA channels only. What type of converter/antenna do I need?
If you are in the US, you will need a digital decoder box along with a digital antenna. You set has an analog tuner installed and is no longer compatible with broadcast signals, thus the need for the digital decoder box. Although the channels are digital, they will not be HD; your set is not capable of handing HD resolutions. Thus, you will only get SD broadcast channels. That will limit you to what you can watch as many broadcasters have gone full HD, while others still broadcast the 480i signal as well.
Aug 10, 2016 | RCA Televison & Video
I have a Toshiba Regza 52XF550U which I purchased in late 2008. Recently we ditched the satellite carrier and switched over to digital OTA programming. The tv was working great getting nice HD picture...
Be sure that the setting in the TV is set to "AIR" NOT CABLE. After switching back, you'll probably have to re-scan. I'd bet that one of your connectors isn't crimped quite right. A single strand from the shield can kill the signal completely. If the center wire is too short or too long it can kill the signal. It should extend 1/16" to 1/8" beyond the threaded barrel part.
Apr 03, 2017 | Toshiba Regza 52XF550U 52 in. LCD HDTV
Tried to hook up a HD antenna but it won't work
HD is pretty critical and if a indoor antenna do not expect much or anything for that matter.
Jun 17, 2012 | Televison & Video
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
How do I change my pro-730 HD to a digital signal?
You need a set-top box with a digital tuner. (For HD, you will need an HD digital source if you have cable or satellite. For OTA, you need one of those HD tuners; the digital-to-analog converters available with the government coupon last year were SD units.) You may be able to use a computer with a USB or PCI card tuner. However, you may be limited to the VGA input on the TV unless you use a converter or have a video card that can output in a TV format. (I can't find the specs for the DVI on the TV to tell if it is compatible with the RGB of the default computer signal.)
If you are getting an OTA signal, you will need an appropriate antenna pointed at the transmitter. Use antennaweb.org or tvfool.com to find out the direction of the stations you should be able to receive. antennaweb is very conservative in the list it provides even though it assumes an outdoor antenna. tvfool gives more information on the antenna for each station in your area. Note: tall trees and buildings can block the signal even if you should get a signal. Digital signals are either enough for the tuner to read or no signal. An amplifier may be needed if you share your signal between several devices.
I hope this helps.
Dec 02, 2010 | Televison & Video
Today was the HD switch..I get nothing on my HDTV?
This wound be due to a bad tuner and nothing else. Speacially with those pop's in the audioCheck and see if your still under warrentee if not give www.teexp.com a try they will work with the manufacture so you can get some of the cost down in the repair. Now OTA signals is diffrent then cable/sat so please check and make sure when your scanning for OTA that its see on antenna if it is and your still hearing pop's the tuner is gone.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jun 12, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Combining output from dish home distribution with ota antenna
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Sep 18, 2008 | DISH Network Televison & Video
Maxent lcd
Your TV is an "HD-Ready" television. What this means is that your TV is ready to accept HD input from an outside source, but doesn't have the ability to produce the content itself. It is a monitor and does not have a digital tuner. Without a digital tuner (or for cable a QAM tuner) you will not receive OTA broadcast HD.
You need to purchase a High Definition capable set-top converter box. The converter box will have HD component out and may have HDMI out, either will feed your HD Ready TV.
Apr 08, 2008 | Sony WEGA KLVS23A10 23 in. HDTV-Ready LCD...
How to see local channels in HD with a traditional antenna?
If your set does not have an ATSC tuner, for HD, then you need to be using a suitably equipped STB.
Your satellite STB - box - should take in OTA channels and display them as part of its normal operation, tho. It takes in the antenna signal from your roof antenna and displays the HD version of your OTA channels, if it is an HD STB, along with the HD channels it gets from the satellite overhead.
Mr Bob
Dec 19, 2007 | Mitsubishi WS-65809 65" Rear Projection...
No OTA channels
This television has an extremely weak tuner. It is very sensitive to both ghosting (multipath) and weak signal conditions, which cause it's digital decoder to "error out". Coupled with this is the decoder's long set-up time (time to actually begin a decoded video stream after signal is selected)and you find that every time the decoder loses sync it takes several seconds to reestablish normal decoding. The net result is the possiblity that the tuner will be continually restarting and never display anything. An extremely directional antenna may help. Otherwise, find a good external tuner box and use that.
Oct 03, 2007 | JVC HD-52G886 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
