SOURCE: Fabric conditioner still in draw after wash cycle
This is usually a matter of pulling the drawer right out (it is designed to let you do this) and taking it to bits (it's designed for this too). Most front-loaders have a bit of a design weakness in that the bit that gets blocked with conditioner isn't immediately obvious without a little bit of prior dismantling. Once you get the top off the drawer, you'll almost certainly find the siphon tube gummed up with old conditioner. Clean this up under a hot tap, then reassemble and all should be well. A.
SOURCE: Fabric conditioner drawer
Try cleaning inside the the machine where the soap dispenser drawer fits into. Sometimes this builds up with lots of soap and fabric conditioner residue and stops the conditioner from going through.
Take the drawer back out and look inside where it goes to see if there is a build up of soap etc...
hope this helps
SOURCE: washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by
the machine during the softening cycle, so that the machine does not
completely fill the softening tray; only when the softening tray is
filled beyond the 'max' mark does the siphon action works. A partially
filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the
softening action is that the water inlet of the machine is partial
blocked (you can try to fix that) but it is simpler to just added more
water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every
time (after adding the softener to the softener tray of course) is to
top up the softener tray with extra water, top it up to the 'max level'
line (keep a bottle of water by the machine). That way, even if only a
little water is added to the softener tray during the softening cycle
by the machine it is enough to trigger the siphon action and the tray
will empty!
Works for me every time, and no need to remove any parts - I used to
take the tray out, clean it, scrub the outlet holes that fill the tray
etc, but they used to gum up again quite quickly!
Hope that helps
