Question about Texas Instruments TI-84 Plus Calculator
Graphing I just purshase the ti-84 and I can,t get any graphing done on the x,y points that i have date for.
  • 3 Answers
Press STAT, go to Edit, then enter x values in L1 and y values in L2 (other lists can be used too, but these are the default ones).
Next, go to STAT PLOT, pick a plot, turn it on, select the type, data lists (x and y should be L! and L2 already; if not, change them), and mark type.
Finally, hit graph. You may need to adjust window settings to see all of the points. If you get a DIM MISMATCH error, check to make sure that there are the same number of entries in each list, and that only the plots that you are using are turned on.
Posted on Nov 09, 2007
  • pyrophorus Nov 09, 2007
    That should be L1, not L!. This site needs an edit button.
When i press graph on my ti-84 it only shows me the plot points and not the line?
At first, 2nd then stat plot. Then select plot option which you want to use. Press enter for On option and after that check plot type
Apr 04, 2013 | Texas Instruments TI-84 Plus Calculator
How do I send my graph from my 84 plus silver edition to my computer?
  1. Install the TI Connect software on the computer.
  2. Connect the calculator to the computer using the Silver Link cable or the USB direct cable.
  3. Run the TI Connect software and let it recognize the Calculator.
  4. Once this is done, create the graph on the calculator, and click the screen capture button in TI Connect.
  5. Save image in jpeg format.
  6. Send it to the printer to print or insert it in a text document which you then print.
Dec 15, 2010 | Texas Instruments TI-84 Plus Silver...
When I try and graph on my TI-84, "ERR: INVALID
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Dec 09, 2010 | Texas Instruments TI-84 Plus Calculator
Doing precal work, graphing a problem, (3x^2-3X)/(x^2 x-12). The TI 84 does not show what actually happens as the graph crosses the (6,3) point. The book says to graph it for -4 <= x <= 60 and 2.5...
You need to adjust the range of your graph. On the graph menu press range then enter the values of x and y. Set Xmin to -4 and Xmax to 60, and ymin to 2.5 and ymax to 3.5. IThis should adjust it properly, as you say.
Happy Calculating
Aug 29, 2010 | Texas Instruments TI-84 Plus Calculator
TI 84 won't graph more than one function. How do you change the settings so more than one function will graph at once?
If you have used or just run the Transfrm Application, you will no longer be able to draw more than one graph.
To restore the native OS graphing capabilities Uninstall the Transfrm Application. Here is how to do it.
  1. Press the [APPS] key.
  2. Scroll Up to reach the bottom of the list faster.
  3. Point to Transfrm and press [ENTER].
  4. Select [1:Uninstall]
Note: Do not worry about Uninstall, it will merely kick the application from memory. Transfrm will still remain in calculator.
Apr 13, 2010 | Texas Instruments TI-84 Plus Calculator
Can the TI 84 calculate second derivatives?
I am sorry to disappoint you, the nDeriv ( function can only calculate numerical derivatives of an expression at a point. The dy/dx can do the same thing (calculate the first derivative) at one point on a displayed graph. It can be activated for graphs by pressing TRACE, then [2nd][CALC][6:dy/dx]. If you need the derivative at more than one point you have to press [2nd][CAL] [6:dy/dx] again.
What I said above concerns the native abilities of the calculator. There may be applications you can install to allow computation of 2nd derivatives. look for them on the TI site, or the archive section of ticalc.org. Try deriv
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-84 Plus Calculator
Graphing a set of points
First click on the Y= button and enter an eqation or goto stat and hit enter and type the points. Afterwards goto Y= then hit plot1 so it is highlighted and hit zoom and then zoomstat and you will have grphed your points.
Mar 02, 2009 | Texas Instruments TI-84 Plus Silver...
Dim Mismatch
That is because you don't have the right amount of points. Either delete one point or add another point. Then try to graph it.
Jan 10, 2009 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
249 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
