Question about Canon Pixma MP500 All-In-One InkJet Printer
Removable disk My removable memory stick keeps informing me that the pictures are read only and write protected. Therefore I cannot edit or delete them. I have tried copying over the pictures and reformatting it by enlisting the aid of the Sony people. After numerous experiments they say there is nothing wrong with the stick. It has worked perfectly until two days ago. Can it be a fault in the printer?
    Genius:
  • 1,601 Answers
Is there a lock (small switch) on the memory stick?
Posted on Nov 02, 2007
Camera keeps telling me to reinsert the memory card. I've tried to new cards. When I put the memory card I was replacing because it is full, it goes back into the camera just fine.
As a last resort you could copy the full card to a computer and then delete the pictures on the card and use that again.
Here is the error list from the camera manual.
This is all I can suggest from here.
"Reinsert the Memory Stick Error"
Insert the "Memory Stick Duo" correctly.
The inserted "Memory Stick Duo"cannot be used in your camera
(See below).
The "Memory Stick Duo" is damaged.
The terminal section of the "Memory Stick Duo" is dirty
Compatible cards.
Memory Stick Duo (without MagicGate)
Memory Stick Duo (with MagicGate) *1 *2
MagicGate Memory Stick Duo *1
Memory Stick PRO Duo *1 *2
NOT compatible
Memory Stick (without MagicGate)
Memory Stick (with MagicGate)
Memory Stick PRO
Some Memory Stick Duo have a write protect switch on the back.
You cannot record, edit or delete images if you
slide the write-protect switch to LOCK with a
fine-tipped object
*1
"Memory Stick Duo", "MagicGate Memory
Stick Duo" and "Memory Stick PRO Duo" are
equipped with MagicGate functions.
MagicGate is copyright protection technology
that uses encryption technology. Data
recording/playback th
at requires MagicGate
functions cannot be performed with this
camera.
*2
Supports high-speed data transfer using a
parallel interface.
Oct 12, 2014 | Sony Cybershot S650 Digital Camera
Write protected memory stick
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 20, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Pictures were taken with my SONY CYBERSHOT 10.1 camera - but there was no memory stick in the camera. Now the picture are in the internal memory. I've tried to delete them, but I get messages that say they...
first of all remove any memory card you may have in the camera.. Then connect the camera to your computer using the USB cable provided. Then Switch on the camera, Once windows has recognised your camera, open up My Computer. There will be a removable disk icon appeared, open it up. Open the DCIM folder, then open the 101_SONY folder. This now has given you access the area where the camera stores you photos. select the first file by left clicking on it, then hold shift and left click on the last file, they should all now be highlighted. Now right click on the last file. and select properties from the menu. On the window that appears, deselect read-only checkbox and click Apply. Your photos will now no longer be write protected and can be deleted.
Hope this helps
Jun 05, 2010 | Sony Cybershot DSC-T77 Digital Camera
Need to delete protected pictures
Try to remove first the memory card of your camera. After you remove the card you can see a small button at the side of the memory card. Just slide the small button to unprotected. Insert your memory card back to your camera and try to delete pictures.
Apr 25, 2010 | Kodak Easyshare M753 Slim Digital Camera
I used Windows to format 4gb memory stick PRODuo, now what?
your 4gb drive has definately a partition virus.
i recommend u to use net protector a virus removal software to tackle this problem
may be demo version will not remove the virus but clean any malware and inform you about the virus.no other software may help as this 4 gb has a partition virus and there is an unseen partition (hidden one) on the drive... which the net protector will delete.
datarecoveryfactory
Sep 06, 2009 | Sony 4GB Memory Stick PRO Duo Memory Card
I have the sony s950 camera with 2gb san disk stick. I have managed to take plenty of pictures in it, but when i try to turn it off and turn it on again, it keeps asking to reinset memory stick. i try to...
you can recover pictures from camera with asoftech photo recovery program.
http://www.asoftech.com/articles/how-to-recover-deleted-photos-from-camera.html
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Jul 07, 2009 | Sony Cybershot DSC-S950 Digital Camera
"disk is write protected" receiving message on external hard drive and memory sticks
it might be in your security settings
right click on the drive in my computer-->properties-->security tab then click "edit" to change permissions check each user, system ,administrator and, your account name make sure it looks like these pictures2296299.jpg6b25e6a.jpg5b159b0.jpg
May 10, 2009 | Computers & Internet
Sony Cyber-shot with Magic Gate memory stick
there is a switch on the back of the memory stick to lock or unlock switch to unlock.
Feb 18, 2008 | Sony Cyber-Shot DSC-S75 Digital Camera
Deleting protected content
I have a SE K310i. It is the "spiderman3" edition and has a few pictures and a trailer of that movie which are protected( i.e cant be deleted by users like me). delete?
Oct 12, 2007 | Sony Ericsson K310i Cellular Phone
Images on memory stick downloading everytime although camera says no images in folder
Best thing to try is to format the disk - save anything you want to keep somewhere else first. If you need info on how to format the disk please post again with details of your operating system on your pc. Formatting should remove this problem, here is the link to the manual if you need it; http://pdf.crse.com/manuals/3082146111.pdf If formatting doesn't solve the problem, try deleting them from a card reader on a different pc - just might help, but if it doesn't format then the memory stick is probably dying. Hope this helps :)
Mar 26, 2007 | Sony Cyber-Shot DSC-P72 Digital Camera
Canon Pixma MP500 All-In-One InkJet Printer Logo
123 people viewed this question
old marine
old marine
