Question about Canon BJC S630 InkJet Printer
Stopped printing and isn't recognized
Hi, I recently cleaned my printer and replaced everything then printed a few sheets of lables. the printer was out of Yellow so I replaced it. Now it just refuses to print...at all...no other colors..It says "printer not responding"
I have uninstalled the driver and re-installed the printer/driver. My OS is Windows XP...HELP!
  In Windows XP print jobs can get caught in the print spooler, this will cause pending print jobs not to print. It may also hinder the user from uninstalling the printer driver. Usually you can delete the print job by opening the print spooler in the System Tray but this may not work with this problem. NOTE: This fix below also solves the problem of "The Printer Queue Is Full" error message.
One solution is to restart the spooler in Windows XP to clear it. Follow the instructions below to do this:
Click Start, then Control Panel.
  1. For Category View:
    • Click Performance and Maintenance.
    • Click Administrative tools.
    • Double-click Services.
  2. For Classic view:
    • Double-click Administrative Tools.
  3. In either, locate the print spooler on the list-->right-click-->choose Restart.
  4. A progress message will appear and the spooler should be clear.
You should now be able to print or remove the printer driver as you choose.
Posted on Oct 25, 2007
I am printing out labels, but it will only print out blank pages, although everything is set up properly. Please advise.
1.check weather its printing color/mono print out other than lables..
a. if it is not printing, give demo print from printer
b. if not printing perform prihead nozzle clean,check which colour is not printing, replace related print head.
2.If not printing labels/doc check drivers,
Sep 08, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Tip
HELP!!! A few days ago I was using my printer and it was doing okay, then all of...
Greetings,
This information is intended for those of you that are getting support from the Fixya.com expert community, for your printer. There are a few things you may wish to consider, prior to posting a request for assistance.
A. It's absolutely vital that you use the correct model number and maker's name for your request. Without that, no expert will be able to access their extensive information pool of techniques.
B. Speak just to the current issue. A reference to how long it's been working, is fine, yet presents little valuable information to an expert seeking to refine their response.
C. There are four major areas that represent nearly 99% of all printer issues. They are:
1. Ink issues. This usually happens when the cartridges are changed. It's vital to do a clean and calibrate, just after installing new cartridges. Try that first, and then a test page.
2. Paper jam issues. Visually inspect the inside of your printer, and focus on little slices of paper(comes from those papers with perforations).
3. Communications errors. Check all the cables for secure connection(they do come out sometimes, for no reason). Also, make sure that you have the most current drivers from the makers website.
4. Actual Print output issues. These are across the board, and without all the first 3 issues resolved, would simply add to your potential problem.
Most of the experts are good at what they do, and are willing to help you out. Help them, Helpya.
And, also, it's part of the experts program here to get constructive feedback from all helpees. Please consider adding your comments to the problems, so that we can all learn more about how to be better experts.
Thank you for your courtesy.
Patrick the Printer Man
IB4G2008 Fixya Wizard
on Apr 26, 2008 | Lexmark X4270 All-In-One InkJet Printer
I've just bought a new kodak printer ESP3250 last week, and installed everything and got it set up fine. It was printing fine after I installed it but suddenly stopped after I had printed a few sheets. The...
Sounds like there is a sheet of paper jammed in it. Try taking off the roller access panel in the back (not the access panel by the cartridges). Make sure to only use clean sheets with proper humidity level to avoid jams. Also fan the sheets before feeding to disperse any static.
Mar 28, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Does not print
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Streaking problem on print out
You have a bad drum cleaning blade. There is no way to replace it without buying a new toner cartridge.
Jan 06, 2009 | HP LaserJet 4700 Printer
WILL NOT PRINT LABLES
Maybe you have the type of file blocked on your printer/computer. If not im not sure what the problem is..
Mar 08, 2008 | Brother HL 5140 Laser Printer
Just trying to print 2181 Avery Laser Labels - "Paper Size or type is incorrect"
I have had this same problem trying to print DVD lable sheets.
I spent hours trying to work it out, HP support said it was the software(hmmm)
The answer to the problem is, the printer senses the printed block colour band on the preprinted lable sheet. I am using Fellowes - Neato DVD tempate sheets which have a black, block of colour on the leading edge, I'm not sure about Avery.
I found the quick fix is, turn the sheet around end for end against the manufacturers instructions. The opposite end is plain and goes through OK. You may have to calibrate the software to compensate if the printing starts in a different position this end, my sheets are the same within about 1mm.
You could also cut the block colour off the sheet if the direction was critical, and make allowance for the starting position.
I find the printer is good apart from this problem.
I hope this helps, it worked for me.
Regards, Rob.
Feb 18, 2008 | HP Photosmart C7180 All-In-One InkJet...
Canon BJC S630 InkJet Printer Logo
147 people viewed this question
old marine
old marine
