Question about Frigidaire FRU17G4JW Refrigerator
Fridigaire FRU17G4JW - all refrigerator unit not cold
I have an all refrigerator Fridigaire FRU17G4JW refrigerator that is 2 1/2 years old.  Initially, it the temperature was set too hish and it froze some of the food in the lower bins of the refrigerator.  I reset it lower but it now does not seem to be getting cold enough.  I have reset the temperature to max cool and it does not seem to be that cold. I''ve read the manual which does not provide any useful information and have checked that the fuses are ok in my breaker box. I pulled it out and dusted the back of the refrigerator.  What might be the problem or do I need to call someone to fix it?
  • 2 more comments
  • Anonymous Nov 06, 2007
    not getting cold
  • Dortega Dec 09, 2007
    Air is blowing in the freezer and refrigerator but it is barely cold. Have temperatures on both to the coldest but it still is not blowing very cold air.
  • Anonymous Nov 27, 2008
    not  cold me to
  • Anonymous Dec 08, 2008
    My Frigidare refrigerator is only two years old. It sat in a climate controled storage unit but when I recently got it out and plugged it in, it doesn't seem to be getting cold??
  • 291 Answers
Things to check
Check .
for Frost build up and if Fan is blowing,
Check condenser...
To make sure clean, and the fan is blowing by compressor & IF it is running
Check Recirclating Vents in refrigerator... to make sure theres no blockage,
CONTROLS ...should be in the middle setting,
Posted on Oct 26, 2007
Fridigaire 26 cuft side by side fridge/freezer
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 28, 2011 | Microwave Ovens
New Refrigerator Past Warantee Not staying cold
It sounds like your condenser coils need to be swapped.
Replacement parts are available from the manufacturer and aftermarket suppliers. More conveniently, you may be able to find replacement parts through the retailer that sold you the refrigerator or at an appliance parts store.
Please let me know if this helps. Good luck!
Feb 29, 2008 | Refrigerators
Our fridigaire is running extra cold(some items are freezing) on the icebox side & the automatic water despenser is not working.when we turn down the control from setting 3 to setting 2 or 1, we can...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 06, 2011 | Frigidaire Refrigerators
Refrigerator seemed to run quite often and at max temp kept things cool at best. The refrigerator (refrigerator only no freezer in unit) is 2 years old and it stopped cooling all together yesterday after...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 16, 2010 | Kenmore 60721 Refrigerator
I have a top mount Fridigaire refrigerator and the freezer will not kick on. The location of the refrigerator is in an outdoor kitchen that is exposed to cold temperatures, but not rain. The unit is 1...
Good day,
Recommended minimum temperature for a refrigerator to operate properly is approx. 55 degrees.
If it is colder than that where it's located, then the first problem you'll encounter is a freezer too warm.
This is by design. The thermostat that controls the whole machine is located in the fresh food compartment. As the temperature in the room approaches 35 to 40 degrees or colder, the machine will not run.
Dec 12, 2009 | Frigidaire FRT8IB5EW 30" 18.2 Cu. Ft. Top...
Milk and other items keep freezing in my side by side fridigaire
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 22, 2009 | Frigidaire FRS23H5AS Side by Side...
Refrigerator door won't shut
Check to see if the door gasket has forzen water that is preventing it from collapsing like it should and wedging the door open. This would most likely be on the hinge side of the door.
Also make sure the gasket is not bent or warped and binding as it closes.
Let us know if you find nothing wrong there and we can look further.
Dec 07, 2008 | Frigidaire FRU17G4JW Refrigerator
Refridgerator problem
Low refrigerant level is a common cause to this problem. Try a lower setting and if that doesn't work, you'll have to call the repairman :( Best regards, Denis
Oct 09, 2007 | Refrigerators
Frigidaire FRU17G4JW Refrigerator Logo
251 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
