Power Off: First, make sure the projector is powered off.
Control Panel: On the projector itself, locate the control panel with buttons. You should find buttons like "Menu," "Enter," "Up," "Down," "Left," and "Right."
Access Menu: Power on the projector and press the "Menu" button on the control panel. This should display the on-screen menu.
Navigate Menu: Use the arrow buttons (Up, Down, Left, Right) to navigate through the menu options until you find the "System" or "Settings" menu.
Unlock: Within the System or Settings menu, look for an option related to the system lock or security settings. Use the arrow buttons to select it.
Disable Lock: Once you've highlighted the lock option, press the "Enter" or "OK" button to access its settings. You may need to enter a password if it's set, so try default passwords like "0000" or "1234." If none work, you might need to contact Sharp support for a password reset procedure.
Unlock: After accessing the lock settings, disable or unlock the system lock.
Exit Menu: Exit the menu by pressing the "Menu" button again.
Test: Power off the projector and then power it back on to see if the system lock has been successfully removed.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Go to the playback menu and select it (you may have to adjust the circular option know to get to the playback menu). Once there, scroll to the picture(s) that are locked by using the sideways selection arrow buttons. Then select the up or down arrows, which will lock or unlock your picture. You can also erase any locked pictures, in case you want to, by formatting the xD card. Hope this helps.
You may wish to try this (my model AOC g2016wa2) 1. push MENU button 2. scroll to Advanced 3. push MENU button 4. scroll to Factory recall 5. push MENU button It resets the power button locked setting but you lose all other settings.
You are having problems with the main board, switching controls. This could be a component failure problem or a problem with the controlling IC. You can call Envision customer support at this telephone number. 1-888-838-6388. they should be able to help with getting service for your problem. I hope this information helps you with your problem.
i am imran
and i have also buy sanyo tv kit 360 ch fit in my old bpl 20"tv and i know for unlock tv channel.
try this this code definetly is solve your problem.
1st go to the locked channel.
and then press menu>system>child lock
and then press and hold down tv/av key and press swap key.
and see locked channel is unlock.
i have coming soon post for service code menu in short coming days.
please reply me to [email protected]
