Question about Koss KS4102 System
Koss Ks4102 video problem
When I select the DVD player, I get no video output to the tv.  The screen on the receiver says DISCMENU.  When I press play, the disc plays but no video to the tv, and the audio is choppy.  On the receiver display everything looks normal. In the lower left hand corner of the receiver display, it looks like some small letters, the letters look like the ones for the component output(red, green,blue).  AV 1 and AV2 work just fine.
thanks for your help
  • 133 Answers
You have chosen the progressive scan option. In this option you will not get a composite video out to your TV using a single cable. you need to switch off this option by connecting the DVD player using three single cables namely Rr, Yy, Bb. this is possible only if you have this input option on your Tv. once you do this you will be able to see the display correctly and do the changes of switching off the progressive option. refer to the manual it is explained
Posted on Nov 01, 2007
I have a koss ks4102 home theater system, i can not get the tv sound to play through the home system speakers
Source the TV-related audio from the Cable Box,. Treat it like any other audio device.
Mar 14, 2011 | Koss KS4102 System
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
My remote control for Koss dvd player [KS4102] doesn't work. how can find another remote for the player
1)take the remote & check in electronic market (or)u can get universal remote.
Jun 03, 2010 | Koss KS4102 System
Cannot find dvd code for my koss dvd player
the three digit codes are 216 or 573
Mar 14, 2009 | Koss KS4102 System
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Koss ks4102 pal/ntsc output
try to unplug the system for about 20min to see if it will reset the system
Dec 01, 2008 | Koss KS4102 System
DVD Region 2
1. Press the "menu" key
2. Press the numbers 1,6,7,1,9
3. A menu should appear on the upper-right corner of the tv screen asking which region you wish to play
4. Press the number of the desired region ( 0 for regionfree ), wait a second or two and you should be able to load and view the DVD
Aug 03, 2008 | Koss KD365 DVD Player
Video difficulty
You've probably given up on getting an answer since it has been some months but in case you haven't axed both yet . . .
You might try the DVD player on someone elses TV to isolate the problem to the player or the TV.  Or the reverse; one of the two is not synchronizing right and it is the TV's job to tweak itself to lock the picture from an external source.  It is unusual for any modern TV to have problems synchronizing with another device, even if they aren't too stable so I would suspect the DVD player first.
Jun 07, 2008 | Koss KS4102 System
Dvd player won't play-shows "bad disc" on screen
it did the same thing to me, it started to work again. it may be a memory issue. my koss player started to work again after it was unplugged for a while. Its something to do with the dvd disc not the player. if i find out , i will post again. good luck
Dec 25, 2006 | Koss KS4110 DVD Player
Problem with surround working with just the t.v. on
What type of plug from the TV are you hooking up to the sound system? Its has to be a HDMI or a scart. If its not and your using the rca red and white. The reciver has to be on the synth surrond setting or look in the owners manual, it will tell you what setting the reciver has to be on when using a non surround set or hookup
Sep 16, 2006 | Koss KS4102 System
Koss KS4102 System Logo
113 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Rick
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
