JVC 1pcs Gumy Gummy Earphones Earbuds Headset HA-F150 Logo
H
Heather Shewman Posted on Feb 03, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My gumny earbuds not both of them only my right earbud. how do I fix this
My head phone been working for hearing out of both ears but now I can only hear out of my right ear
Level 3:
  • JVC Master 19,187 Answers
  • Posted on Feb 03, 2014
JVC Master
Level 3:
Answers
19187
Questions
0
Helped
4345787
Points
82261
Buy new ones. The wires in those are very fine and break,.
3helpful
9answers
How do I pair both i7 TWS earbuds? I can only get one to work
After connecting one, turn on the other. Then while both are powered on? Press and hold the button on both earbuds until they connect to one another.
3answers
I can not hear anything out of my right ear bud
Hi there thobe47!
Please test the pair with a different audio device and see if the problem goes away first!
Firstly, make sure you are pressing the plug all the way into your audio device jack. Most are designed with two tiers, so only one ear will sound if only one tier of the electrical connection is fully established. Once you've tried that, continue!
Most earbuds are created with very small working parts with equally small electrical connections. If you have lost sound in one side, the most likely cause is a loose connection somewhere.
If it still doesn't work, your options are sort of limited. I would recommend first gently "jimmying" the wire leading to the bad earbud around while it is in your ear and music is playing. If you manage to get the sound to be restored, wrap sticky tape tightly around the wire and the tapered part of the bottom of the earbud in an attempt to maintain the new connection. It is not a permanent fix but might buy you a bit of time with the pair.
If you can't get it to work in that way, your remaining options are pretty much to either open the earbud and attempt to reestablish the connection (difficult, small parts, and could damage the earbuds if you don't know what you are doing), or to buy a new pair. You can get some pretty nice earbuds for under $5 at most megastores, and anybody who could fix them and would charge you will charge you much more.
If you must try to open the earbud (I don't recommend it!), I have a generic set of steps here. I take no responsibility for damage of your earbuds or devices that may follow!
Gently peel back the gelly cover of the earbud, starting under the top seam and pulling it off.
Unscrew or "pop off" the portion of the earbud that has the small grating. There may be an inner retaining system involving more plastic rings. Just keep these safe and remember the order in which you took them apart.
You will now probably be seeing the speaker of the earbud, looking like what you might see on an uncovered subwoofer speaker (just much smaller!)
Being careful to not touch the flat portion of this disk and avoiding anything magnetic (including your laptop / desktop), see if you can pinch it by the sides and gently pull it out of the casing -- probably less than a quarter centimeter. If you can, look for any severed connections between the solder points on the bottom of the speaker and the wires coming from the bottom of the bud. Soldering these would be extremely difficult, but you can attempt to fix them with small pieces of tape.
Nestle the speaker back into the housing, replace any retaining disks in the correct order, screw/pop the outer clip back on, and slide the gelly back into place.
Hope this helps!
1helpful
When i put my ear monitors on i only hear on one side i bought a nother pair of ears but now when i sing the music in my ear cuts out?
You may have bought "noise cancelling" ear buds and those cancel out local noise... NOT the type you want for this application !!!
The wires to earbuds are really tender and easily damaged... Make sure the replacement earbuds are the right type for use with your wireless... if necessary, call the vendor to verify.
I have the GC-1020 Element mp3 player..i have had it for 3 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why...
I have the GC-1020 Element mp3 player..i have had it for 2 months.All of a sudden i can only hear the music out of one ear of my ear buds,i have tried my earbuds on something else and they work fine..why won't sound come through both ears anymore?
37helpful
3answers
My left earbuds on my JVC gummy earphones went out.
I have this problem all the time with my JVC earbuds. This may sound a little gross but it will work. I put the ear phone in my mouth and **** on the end of it pretty hard. What I have found is that sweat or even wax will plug the little hole and prevent the sound from coming out.
5helpful
2answers
Only One Ear Bud Works
It is likely that your right stereo channel has either been severed somehow or there is a severe short in one of the cables. What you can try to do to test this theory is first turn on your music. Then wiggle the cable at the very base of the right earbud. If nothing happens wiggle the cord right where it connects to the stereo jack. If still nothing happens run your fingers along the right earbud audio cable bending and twisting it. If at any point you hear music again then you likely have a short. If it is near the earbud then it is going to be difficult to fix since these earbudfs have a large gauard. If the short is at the stereo jack then the fix is simple. A standard 1/8" stereo jack can be purchased from any electronics or audio store. You can then fairly easily seperate teh old stereo jack and solder this new one in place. Search the internet for tutorials on how to do this if need be. Even if you do not get any kind of sound when wiggling it at the base of the jack this is the most likely culprit since this is where most of the stress on the headphones occur. Be wary though, if you do attempt a stereo jack repair you will void whatever kind of warranty your earbuds may have so check before you try. But, in teh end you may end up saving a 60-100 dollar set of earbuds for 5-8 dollars. Hope this helped.
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
