Question about Kenmore 98702 Stacked Washer/Dryer
Dryer is working but wont tumbel
I just got a used stackable and it worked fine then the dryer stoped tumbling.  Could it be the belt.... it was making a banging noising while it was going around then a big bang and stopped moving.
  • 100 Answers
Sounds like another problem occured causing your belt to either break or slip off the motor
Posted on Oct 31, 2007
Stackable dryer wont heat
Well if it still tumbles the fuse is fine, most likely the element is broken. To get into the machine you remove the top (unplug it first) then drop the splashplate between (washer and dryer). Next remove the controls. They have quick connects. Get the front off the dryer and then remove the drum. Note: an access hatch behind the dryer will allow you to release the belt from the idler. Suggestion: take a photo of how things come off with your phone so you can see how it all goes back. DRYER REPAIR PHOTOS
Jun 18, 2012 | Kenmore Dryers
My dryer heats up but does not tumble. I replaced
Sounds like worn tub back bearing.
take the belt off and spin the tub by hand to see if it is binding.
check that the pulley isnt loose on the tub back and also the motor pulley, feel if the motor spins free.
Finally check the tub itself for objects poking through or lodged in the outer tank.
Good luck
Mar 18, 2010 | Dryers
Whirlpool dryer froze and wont tumble just makes noise where try
Hi, This dryser only has 1 belt. When you chacked the belt, was the belt located in the middle of the drum?
This model has an idler pulley that is no longer being used. They have went back to the roller style idler which is easier on the belt.
Raise the top and then remove the 2 screws holding the front to the cabinet. Remove the front cabinet and locate the idler next to the motor pulley. Look at the belt while you have the front off and see if there is any bad spots in it.
I hope this helps you. Please let me know if I can assist you further.
Jul 02, 2009 | Whirlpool LER4634J Electric Dryer
Dryer heats but wont tumble/electric
Broken belt due to bad rollers or idler or simply rotten belt. GUIDE
Jun 30, 2009 | Kenmore 63942 Dryer
Tumble dryer not working
sounds like a broken belt ;it has to be un plugged from the power source . most belts can be accessed thru the panel on the back o f the dryer.
Jun 12, 2009 | Dryers
Westpoint tumbel dryer no hot air coming out
you need to replace heating element
Apr 21, 2009 | Dryers
Dryer wont turn
Yes, it will save you alot of money and work just fine. You will have to shut off the dryer, turn off the gas and/or electric(disconnect it to be sure it is power free). Look at dryer carefully as you may be able to access the belt from the lower front. The belt is easily available at Sears Parts Stores. Do not use it until fixed as it might overheat!
Dec 09, 2008 | Kenmore 63942 Dryer
This does sound like the belt has broken. Is the Defy autodryer the one that made the sound and then stopped tumbling?
Nov 11, 2008 | Dryers
Wont fill and agatate
sounds like the water valve check for supply taps make sure there on test solenoid's on valve for ohms Resistance or closed circuitif open replace water valve
Aug 29, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
94 people viewed this question
Sal De
 Brian Main
Brian Main
