Question about HP Md5880n 58 in. HDTV
Multiple images and old image remains on screen
I have a problem that the service company and extended warranty company could not solve.  My HP has developed a double and sometimes triple image and after awhile it then becomes old image that remains on the bottom half of the screen.
2 Suggested Answers
  • 227 Answers
SOURCE: No Image on PL4260N HP Plasma Tv
Posted on Jun 24, 2009
  • 1126 Answers
SOURCE: Blurry image, flickering and 6
It is the convergence module that is bad, need to change the convergence IC's, or the buy a new convergence module at
Posted on Feb 07, 2011
0 characters
1 Points
How do I remove burn images from a Sanyo TV?
I am assuming this is a Plasma TV? If so, Once an image is burned into the screen,there is now way to remove it. There are some ways to remove temp burn-in images like playing a white screen,and a screen wipe program. But,this only helps if you see a burn-in after watching the same image for a few hours. If the image has been played over a long period of time. "Like a store demo, security camera, ESPN like at a bar" There is no repair for this. And the screen will need to be replaced,and the cost of the replacement is sometimes more than buying a new TV. Sorry to have to give you this bad news. If you bought a extended war.? It may cover the burn-in. Some warranties
will cover that. It is worth a try.
May 04, 2014 | Sanyo Flat Panel Televisions
What can I do to repair the yellow blotches on the screen of my 55" Sony wega and not to mention about a dozen broken pixels scattered on the screen?
This looks like impact damage :( If it was changing with the image I could tell you sure, it's a digital issue and probably is a result of bla bla bla...but because it remains perfectly static no matter how the image beneath it is changing, I regret to inform you I believe this damage is physical.
Likely caused by an impact to teh screen - you're only option is to purchase a new one or get it serviced, hopefully you have a warranty! :(
Nov 13, 2012 | Flat Panel Televisions
Have multiple images on screen also verticle lines
Sony is now extending the warranty on the LCD display and will fix the problem for free through September 30, 2012. See: Call their customer service number and they will give you a case number. Then call one of their authorized service centers and they will fix it free, in home.
Jun 19, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Samsung S4253- No Image, Only Multicolored Pixels; Sound OK
I had the same problem. Luckilly I had an extended warranty. Repair tech said it blew three main boards inside and to fix it out of pocket would have been more than the screen was worth. Hope this helps.
Jun 24, 2008 | Samsung HP-S4253 Television
LG RT-42P245V-Band of pink
The PDP (plasma) panel has gone bad and need to be replaced. This is not a user serviceable part and cost about 1/3 of buying a new unit plus the cost of labor for a two-man job. I would hope that this unit was purchased less than 1 year as warranty for parts and labor is 1 year. If not I do hope you purchased an extended warranty or paid it with a MasterCard (some MC card provider extends the warranty by another year). Cost of repair for flat screen TVs are high so it really a wise investment to purchase extended warranty. Fixya offers extended warranty on your future electronics purchase. Hope this helps.
Jan 11, 2008 | LG 42PX4DR 42 in. Plasma TV
Samsung 42in Plasma 1 year old
VS is vertical scan of course it is controlled by applying voltage, lower or higher you affect the scan, it appears as focus or sharpness, if it is outside the specifications listed on the back cover(inside) then it will not function properly. definitely get with samsung on this and get a ticket number so they can not just blow you off, if you have an extended warranty they might have to replace the tv as this sounds like it may be a tube issue not just a scan issue, also don't let the tech leave until the tv has warmed up and the image is either the way you like it of he stays.
Jan 09, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung HP S5053 Static / Grainy Image
Try to adjust the Vscan or/and Vs down about 5-10V on the Power Supply board. If you got extended warranty, just let the warranty depot shop help you to do it.
For the "humming" noise, may need to replace the Power Supply board to fix it.
Dec 30, 2007 | Samsung HP-S5053 Television
HP Md5880n 58 in. HDTV Logo
35 people viewed this question
Top HP Flat Panel Televisions Experts
 Mike M
Mike M
Are you a HP Flat Panel Television Expert? Answer questions, earn points and help others
