To repair a broken wire in the left ice/water door of the Bosch B26FT50SNS fridge, it is possible to disassemble the left door water/ice dispenser. However, it is important to note that this process can be complicated and should only be attempted by someone with experience in appliance repair.
To begin, unplug the fridge from the power source and remove any items from the door shelves. Locate the screws that hold the dispenser cover in place and remove them using a screwdriver. Carefully pry off the cover and set it aside.
Next, locate the wire that needs to be repaired and determine where it is broken. Cut away any damaged sections of wire and strip the ends of the remaining wires. Twist together the ends of the wire that was cut and use electrical tape or wire nuts to secure them together.
Reassemble the dispenser cover by aligning it with the door and pressing it into place. Replace the screws that hold it in place and tighten them securely.
Finally, plug the fridge back in and test the ice/water dispenser to ensure that it is working properly.
In summary, to repair a broken wire in the left ice/water door of a Bosch B26FT50SNS fridge, you can disassemble the left door water/ice dispenser, locate and repair the broken wire, and reassemble the dispenser cover.
HI, Check the arm that the door flop connects to. Make sure there is no other causes. The door just snaps on to the arm. Just be gentle and look at configuration .
This is common in these units. When the dispenser lever is depressed, an auger motor rotates the auger wire. When the auger rotates, it pushes the ice toward the dispenser door and chute. When the auger is defective, it isnt able to push the ice out of the dispenser. You need to check the auger to determine if it is broken or disconnected from the auger motor. If the auger is broken, replace it.
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Voetball, I lost you in chat. You will need a repair kit for this unit to fix the broken clip in the ceiling of the dispenser housing. Can you tell me what color your fridge is so I can find the right kit for you? ALSO, make sure you plug up the hole where the flapper goes until you get this kit!! Don't let warm air come in there and make a mess out of the freezer!!
Your door probably is not closing good. There is a solenoid that operates the door that
could have stopped working. Can you hear it?The hinge on the door could be broken or the
bracket it goes in could be broken. You'll have to look to see what's
wrong.
Remove the dispenser cover by gently prying starting at the
bottom going round and round a little at a time to prevent from breaking it.
When it's off the screws will be exposed to access the other components
There is a solenoid that operates the door that could have stopped working. Can you hear it?
The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
The Ice chute door is seems to be broken. It doesn't open when the Ice is coming through the ice shoot. The Ice chute door just flops around in the ice shoot.
