Question about Refrigerators
GE Refrigerator: GSS22SGRF SS - Not Cooling; Not dispensing ice or water; clicking noises
The problem started with the frige not dispensing water or ice... when trying to get ice or water the lights would dim but nothing would come out... Then, about a week later it stopped cooling and with this it started clicking like crazy. The clicking noise is coming from the back behind icemaker behind the light. If I open the frige/freezer doors, the lights are on and if I adjust the temp controls the frige/freezer will cool again for a while but it eventually stops. The frige is only 2 years old byt is out of warranty except for the sealed system (compressor, condenser, evaporator). My dad says the compressor is working because the frige is cooling. I will call GE for service if this problem sounds like it's under warranty otherwise i will call Sears. Please advise... Thanks!
  • rlhollowell Oct 26, 2007
    thank you!
  • rlhollowell Nov 01, 2007
    So GE doesn't bring good things to life? %$#@!
U need a new wr51x10101 heater harness 35.50 $ there is an ice build up on your coil defrost coils replace the heater harness U should B good to go
Posted on Sep 07, 2010
  • 4 Answers
I was having the same issue. Had GE tech come out and turned out to be the same thing zabu011 mentioned. Part # WR51X10101. List price is $62.70 through GE, labor was 163.15 (included an $80 charge for comine out). So, if you have this issue, you can save yourself some money and find the part online, which I have since done and see it listed for $30.
Posted on Oct 18, 2012
  • 3 Answers
I am having this same problem and I have diagnosis that the compressor is working, the compressor fan is working, but the evaporator fan is not working. My coils have frost on them showing that they are cold and the bottom of my fresh food section is freezing milk. But the upper part of the fresh food and freezer section is warmer than it should be. Any other recommendations as to what the problem might be? What controls the evaporator fan?
Posted on Dec 13, 2007
  • 473 Answers
If it does cool then it isn't a sealed system problem.  Most likely it is a bad mother board.  It is fairly common on this one.  I would call Sears and they will probably offer you a smart agreement which will be cheaper than the repair and give you a 1 yr warranty.
Posted on Oct 25, 2007
2 Suggested Answers
SOURCE:
Sea Breeze
  • 4655 Answers
SOURCE: GE GSS22sgrf ss - Side-by-side refrigerator
I need to make sure that your refrigerator model and make numbers are listed correctly. Im having trouble with the information listed above your comments. I have GE data base and want you to look at the hyper link listed below.  and let me know if this or I can help lead you in the correct direction, Thanks, Sea Breeze
http://www.appliance-parts-warehouse.com/general-electric-parts/General-Electric-Refrigerator-Parts-Page-6901.cfm
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
My frige does not dispense water or ice
If when you attempt to dispence ice/water the light dims and the refrigerator seems to shut down unitl you let off the dispenser the main board is bad. http://appliance-repair-it.com/GE-refrigerators.html
Sep 07, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model GSH25JSRF SS is clicking non stop, the click comes from a small panel on the back right of the fridge. Started out that the water and ice dispenser didn't dispense. Then the clicking just came...
Is it still cooling? I had an issue where there was a clicking noise from the back panel and the fridge did not cool. Pulling off the panel the noise seemed to from a box on the circuit board. Turns out there was a problem with the controler board and after some research I found that the board was covered under a recall. GE ended up sending a guy out to replace the board at no charge. Pretty cool being that if was after the warranty had expired; but I guess it makes sence since there was a recall. Good luck.
Dec 10, 2009 | GE GSH25JFR Side by Side Refrigerator
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge profile side by side fridge
THIS IS CAUSED MORE COMMONLY BY A FAILURE TO THE MAIN PROCESSING BOARD NOT SENDING PWR TO THE DISPENSER RELY BOARD
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
May 29, 2008 | GE GSH22JSRSS Stainless Steel Side by Side...
Ge side by side refrigerator
what is your serial #
Jan 06, 2008 | Refrigerators
Clciking noise
I was having the same problem.
I read on fixya that there is a reliability issue with many models.
I called GE customer service. They sent a repair guy who swapped out the motherboard at no charge even though it was out of warranty.
Works great now.
2 of my neighbors' friges went out in the summer here in Las Vegas. They both lost all their food.
He said I was lucky because after the clicking noise begins, the motherboard usually crashes the next day. Mine clicked for a month.
Nov 21, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Oct 25, 2007 | GE GSS22JFMWW Side by Side Refrigerator
Refrigerators Logo
970 people viewed this question
Top Refrigerators Experts
Sal De
Marvin
Marvin
