Cars & Trucks Logo
George Gardner Posted on Feb 02, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emc computer oil leaking out of emc
_-__-___-_
Level 3:
  • Toyota Master 20,706 Answers
  • Posted on Feb 03, 2014
_-__-___-_
Toyota Master
Level 3:
Answers
20706
Questions
Helped
6804405
Points
57965
What car. what model, what year, what engine,
what the hell is an EMC.
at the least say, im inside car and pointing where?
or in the engine bay and point to where.
125 meanings and counting
http://www.acronymfinder.com/EMC.html
1helpful
Transmission does not shift has the emc fuse have any thing to do with it
I would hope so if the EMC is not fried and if the fuses are burnt.
Emc computer
What county (LHD or RHD, left hand drive car?)
what car
what year what model.
as you can see no 2 cars are the same, 99% of time.
cars can have up to 8 engine options and 4 transmissons.
first learn what are driving.
if in the USA say so and post the VIN, putting 3 xxx at end for privacy.
Idling won't stop
check for vacuum leaks
Had emc rebuilt, now wont start
Try a complete unit from scrappers complete with transponder and the chip from the key
My 99 buick regal will start fine and idle fine but when i put it in gear it dies.Why
there is a vacume leak to you emc from pvc valve located out of valve cover follow line to a round valve make shure it is hooked up and there r no leaks check all you vacume lines
1helpful
EMC wire problem (wire purple) is stopping injectors from working. wire has 60 ohms of resistance. what is EMC and where is it?
HI ECM is the computer that controls your engine ,electronic control module .its behind your glove compartment .
2answers
My car was running poorly then 3 codes shoed PO320 PO700 PO725
Sounds like you have a transmission problem. Make sure the fluid is full. If you have neglected your transmission services, you will most likely need some trans work, which you will not be able to do on the side of the road.
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
