Question about Pioneer SD-533HD5 53" Rear Projection HDTV
Not turning on
I have the following:  Model: Pioneer SD-533HD5  Manufactured: April 2002    About four months ago, my TV would not go on.  When the power/standby button was pushed, the LED would turn green for a second and then go immediately back to red.  I searched the internet and found that it was likely a fuse.  Sure enough, I was able to find the fuse and repair it myself. It blew the same fuse about four times over the past four months.  I kept fixing it.  When blown, a red LED on the board within the TV is lit up.
  • Anonymous Nov 12, 2007
    TV was on stand by now no green light ie stand by and will not turn on.
    tried the unplug replug to no avail
  • jmstef Nov 23, 2007
    When I turn tv on it turns right off. I checked fuses and they are all fine. How can I fix this? Thanks, Joe
    Genius:
  • 1,694 Answers
Power supply board pull,then remove original solder on 5 volt
regulator pins then resolder + replace 4 amp fuse........T.
Posted on Nov 20, 2007
What does it mean when I have double vision on all channels and dvd on my pioneer sd-533 hd5 big screen floor model?
follow this steps and fix it. God bless you
Configuration Problems
Improperly configuring TV setting can cause problems. Verify the TV settings are set correctly. First, brightness and contrast should not be set to high or to low because this can cause poor picture images. Second, adjust the color on the TV when the picture displays colors poorly. Third, if you are having sound issues then check to make sure the volume is not muted or turn down all the way.
Nov 04, 2013 | Pioneer SD-533HD5 53" Rear Projection HDTV
Cannot use convergence on remote for Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-532HD5Pioneer SD-533HD5 53 in. Rear...
Ur convergence it dead.Must know how to solders.Tries these Websites.Tv Repair World.com,Tvrepairkits.com to buy a convergence kit.
Dec 29, 2009 | Pioneer SD-533HD5 53" Rear Projection HDTV
My television has a green tint to the picture...help
go into the tv picture settings and there should be an option for colors and try turning the green down, sorry its not an exact solution but i dont own one so just trying to help
Dec 30, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
My pioneer model sd-533hd5 shuts off after 5 mins and goes to stand buy
Replace Both of your STKs ,if it has the STK392-110s do not go back with these they do not hold up use STK392-180s for parts call Electronix Parts 1-800-223-3205.
Dec 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Red convergence bowing
Replace both of your STKs if they are STK392-110s upgrade to STK392-180s these are the convergence ic big black ics 2 of them. Electronix Parts 1-800-223-3205
Dec 15, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
My sd-533hd5 keeps blowing the 5 amp 125v fuses
Yes! it sounds like a power supply problem! or the flyback in the main board needs replaced ( part is in the $70.00 range
Dec 12, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer projection blurry picture
Sounds like you lost the converigence. Have you tried to realign the convergence through the user menu? Try that first and see what happens.
Jul 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
50" Pioneer TV blacks out and has shadow on the bottom third
yes it is worth fixing.if you r getting it repaired for the first time.
but you will have to wait for some long time to get it repaired as the tv is very old its very difficult to get the parts for reparing it.
the problem what you r facing is the problem of the convergence in your main board of the tv.
it has to be repaired.
i will advise you to get it repaired as it will work.
for doing it your self you can try clicking this link and following the given instructions in it
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
Jun 25, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-533HD5 53" Rear Projection HDTV Logo
290 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
