Question about Onkyo TX-8511 Receiver
Onkyo receiver model tx-8522
Radio shuts on and off intermittently while playing.  this problem does not occur while playing cd's
  • Anonymous Mar 20, 2014
    How do I get my radio to play on my receiver tx-sr313
  • Anonymous Mar 22, 2014
    I want to play iphone through onkyo receiver and display on tv
  • 1,512 Answers
It may be muting due to a fluctuation signal. Do you have an appropriate aerial connected to the FM tuner?. a length of speaker wire pulled apart into a t shap for about 1m will do. Get a splitter and use you television antenne coscket to provide better signal for your tuner
Posted on Dec 14, 2007
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
How do you connect a sub woofer to a Onkyo TX-8522?
Since it does not have a dedicated subwoofer pre-out, you would have to use the "TAPE" outputs. If your powered sub (I'm assuming your using a powered sub) has only one input, you could either just use the left tape out of the receiver, or use an rca splitter to convert the left and right to a single jack. (I'm not a fan of that method, though).
Jul 01, 2011 | Onkyo TX-8522 Receiver
I have an Onkyo TX-8522 stereo system. I am trying to connect my iphone to it so that i can play music there (both from Pandora and from my own music from itunes). I was wondering if this was actually...
Yes it is possible. Any audio device with an earphone out jack can be connected to a receiver by using the CD input or the AUX input jacks (white and red) on the receiver. All you need is an adapter cable with the stereo 3.5mm plug on the iPhone side and the 2 RCA connectors on the receiver side. You can get these for $2 or so at Amazon.com or at Radio Shack. Adjust the volume and select on the receiver, the input you used to connect and enjoy.
http://www.amazon.com/RiteAV-3-5mm-Stereo-Male-Cable/dp/B000V0G2C4/ref=sr_1_1?ie=UTF8&qid=1306765483&sr=8-1
See above link for one example of the cable.
May 30, 2011 | Onkyo TX-8522 Receiver
ONKYO TX8522; Using it as a 2nd receiver to push zone 2 (4 speakers) in basement. When TV, LG BluRay, iPod, or radio selected for receiver 2 zone 2, it works great! When I select Padora thru the same...
I've seen some posts that talk about an incorrect or too high digital audio bit rate causing this. If it's only digital sources I'd look at that.
Feb 04, 2011 | Onkyo TX-8522 Receiver
Monitor buttons do not work right``````````how to get another monitor ?????
Do you understand what that Monitor Button means?
Only Tape 2 can be monitored.(Page 24, diagram on page 25)
http://www.retrevo.com/support/Onkyo-TX-8522-Receivers-manual/id/469ci860/t/2/
Jan 12, 2011 | Onkyo TX-8522 Receiver
In my Onkyo receiver, it normally just says Video but for some reason it says Video T2 On and there is no audio coming out. Any ideas?
T2 IS selection for EQ. ( TAPE MONITOR LOOP )Hold the T2 button down long enough and it will switch it to OFF. Karl
Jul 29, 2009 | Onkyo TX-8522 Receiver
Onkyo TX-DS575 - intermittent audio
You have a problem that was inherent with all Onkyo receivers from this period. You need to contact Onkyo because the microprocessor needs to be replaced. Last I checked, its about $80 from onkyo.
This is NOT an isolated incident as darn near every Onkyo receiver model had this problem.
Good luck...
Rob
Nov 15, 2008 | Onkyo TX-DS575 Receiver
How connect subwoofer to onkyo 8522
does it have speaker wire in and out use then from fronts
Feb 04, 2008 | Onkyo TX-8522 Receiver
Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Nov 15, 2007 | Onkyo TX-8522 Receiver
Onkyo TX-8511 Receiver Logo
191 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
